Page 43 of 71
5 misc. freebies
Posted: Sat Mar 25, 2017 2:27 pm
by mikehalloran
Izotope DDLY Dynamic Delay free through April 2.
Posted: Sat Apr 01, 2017 2:00 pm
by mikehalloran
It's a bit strange—nothing else quite like it. And the washed out interface... who knows what the hell they were thinking? Isotope offered it as a freebie when it was introduced and it's free again for a couple of days. I can't see paying the regular price of $49 but free? If you only use it once, it's worth the effort.
https://www.izotope.com/content/izotope ... rm=April+1
Vinyl is always free. I know someone who swears by it on drums. Ok...
https://www.izotope.com/en/products/cre ... vinyl.html
Re: Izotope DDLY Dynamic Delay free through April 2.
Posted: Sat Apr 01, 2017 2:43 pm
by stubbsonic
I like Vinyl. It has come in handy a couple of times when I needed to create audio for a period piece and needed a convincing low-fi sound. I guess if a person had a nostalgia for lo-fi drum sounds, it would make sense- probably evokes a bygone era.
Posted: Sat Apr 01, 2017 4:56 pm
by mikehalloran
Probably the most famous use of the first version Vinyl, again sync'd to persussion:
https://www.youtube.com/watch?v=nbW3lEl ... ExYn1IFYQG
Re: The free VI's/plugs list.
Posted: Sat Apr 01, 2017 8:15 pm
by stubbsonic
That album had left my memory. What a lovely band with a rare baritone (?) lead vocalist. That drum effect was pretty effective.
Plug-In Alliance bx-subfilter for free
Posted: Wed Apr 12, 2017 8:36 pm
by James Steele
Here's the link about it. You may have to create a Plug-In Alliance account if you don't have one already.
https://www.plugin-alliance.com/en/prod ... ilter.html
Free World textures for Kontakt
Posted: Wed Apr 26, 2017 3:23 pm
by Basstrup
Soundethers offers this freebie, you just have to send an email to them via their site...
http://soundethers.wixsite.com/soundeth ... free-world
Volko Audio free NTI Nightpro EQ3D EQ emulation
Posted: Wed Apr 26, 2017 3:25 pm
by Basstrup
Volko Audio has released Q3D, an emulation of the NTI Nightpro EQ3D rack mount equalizer.
This 6 band eq has an extremely wide Q. One of the bands is AIR that is a hi shelf filter. You can change the AIR frequency and boost. It has a modern, easy-to-use user interface. In the past, it has been used for very famous recordings and generally for vocals.
Q3D features six bands. The first four peaking bands have the center frequencies 10 Hz (SUB), 40 Hz, 160 Hz and 650 Hz. Each band is 2.5 octaves wide. The fifth high-frequency shelving band has a cutoff frequency of 2.5 kHz.
The sixth "air" band is a -boost only- high-frequency shelf with five selectable cutoff frequencies:
2.5 kHz.
5 kHz.
10 kHz.
20 kHz.
40 kHz.
The amount of boost or attenuation is continuously variable from -15 dB to 15 dB on all bands except the air band which has an amount of boost that is continuously variable from 0 dB to 20 dB.
More:
Extremely High Processing Efficiency.
Proprietary topology which is optimized for low latency, low noise and high dynamic range.
Supports sampling frequencies up to 384 kHz.
Clickless parameter update.
https://www.volkoaudio.com/product/q3d-eq/
free stereo width tool
Posted: Sat Apr 29, 2017 9:08 am
by Basstrup
http://www.quikquak.com/Prod_UpStereo.html
Using three basic basic systems:
1. A fixed frequency EQ designed to lift the highest audio frequencies, and boost the bass.
2. A stereo width unit, for expanding stereo sounds so they appear wider and fatter. At extreme levels other characteristics are also brought out of the sound, so this can also be used as a tonal control for individual instruments. This also has a mono setting, useful for squashing up those aggressive samples that take over the mix.
3. A Loud switch that raises the waveform to the limits in a smooth curve. This saturation gives the mix a more perceived loudness, without clipping.
There's also an option for overdriving this effect, distorting the waveform towards the maximum, and can be used to create a raw punch to the sound.
These stages create an overall loudness effect on the final output, so a gain control is included to keep the limits in check.
The main 'bubble' display on the plug-in is really a basic meter, when one of the stereo halves flash red, then the output is being clipped. Try and keep the levels so the red flashes only occasionally, this enables the loudness control to work at its maximum.
Colour and light changes are achieved by dragging the central meter-ball, using ctrl or shift to flow through colours. Maximum right/up drag returens the colour to white.
Re: Volko Audio free NTI Nightpro EQ3D EQ emulation
Posted: Sat Apr 29, 2017 2:41 pm
by bayswater
Basstrup wrote:Volko Audio has released Q3D, an emulation of the NTI Nightpro EQ3D rack mount equalizer.
2.5 kHz.
5 kHz.
10 kHz.
20 kHz.
40 kHz.
More:
There was a bug fix on this very quickly
We fixed an important bug for Q3D. Please update your version of Q3D to 1.0.1.
3 Free Kontakt Libraries
Posted: Tue May 09, 2017 9:46 am
by mikehalloran
Impact Soundworks Super Audio Boy Kontakt Instrument
Channel Robot Grid Machine Free Chain - Drums
Dream Audio Tools Dream Box
http://www.emusician.com/gear/1332/this ... ents/62696
Posted: Sat May 20, 2017 1:52 pm
by Elio
Posted: Sun May 21, 2017 10:38 am
by billf
Thank you for the tip, this looks like a nice plugin.
BTW, grab this soon, the website states that it will be free until June 8th.
Posted: Sat May 27, 2017 7:47 am
by terrybritton
Well, someone on the Native Instrument's "Maschine" forum posted that they saw this on the Ableton forum, so I'm sharing it here!
This is a post highlighting eight free VST's. The last one is a nice loudness meter, and there are other useful and/or interesting ones also. Not sure if they all work on Macs.
http://blog.outro.io/free/2017/5/5/8-fr ... gn-plugins
Terry
Posted: Sat May 27, 2017 7:50 am
by terrybritton
Thanks, Elio - the "Diffuse" plugin is a very interesting take on combining reverb with delay. And it is indeed free until June 8.
Terry
