stubbsonic wrote: ↑Mon Oct 16, 2023 4:06 pm
But to play devil's advocate....
In one scenario, let's say (hypothetically) we had a gtr to MIDI converter that did an effective job of capturing velocity and duration on the all 6 strings independently (a la divided pickup). And we captured, a reasonably complete selection of strumming gestures.
It could be kind of fascinating to hear non-guitar sounds strummed with kind of guitaristic gestures. It would be especially cool if the instrument (whatever it is) had some way of adapting to the upcoming strum business.
Hypothetical indeed. Gtr to MIDI is plagued by latency, often latency that differs by frequency, that makes it pretty much impossible to capture a performance properly.
With all the pickups and versions I had, I could only ever get a reasonable approximation by playing octave up, and that presents its own problems.
I concur. OTOH, their's nothing like real fingers on real strings. As a keyboardist, I am jealous of the range of expression available to guitarists. But then I pull out my breath controller and the pain subsides...
HCMarkus wrote: ↑Mon Oct 16, 2023 9:28 pm
I've played guitar for about as long as I've played keyboard/piano in years, but have logged more hours on guitar, and even more hours on bass guitar. A not insignificant number of hours has elapsed on trombone as well. Dynamic expression is not something I will ever take for granted.
I enjoy using a B.C. very much, but getting the air flow to feel right is a challenge. Trying this plumbing diverter.
The TEControl is on one side of the diverter. I blow in the tube, the air vents out the other side of the diverter. I use a USB extension cable (female A to male A)-- to plug it in.
stubbsonic wrote: ↑Tue Oct 17, 2023 8:58 am
Wow. Looks like it will work, but definitely a bit unwieldy.
Do you know the TEControl mouthpiece has a valve you can adjust to allow air to bypass the tube...
The mouthpiece has an adjustable bleed valve similar in concept to that found on the famous - and now discontinued - Yamaha BC3 breath controller.
stubbsonic wrote: ↑Tue Oct 17, 2023 11:00 am
I got my TEControl before they had that kind of mouthpiece. The one I got had a plastic aquarium valve. (Mine was used, so it had extra flavor-- j.k.)
I had been holding out for the longest time to get a Photon. But that project appears to be on indefinite hold.
I bet they'd send you a replacement with the bleed valve for not too much... OTOH, your contraption could certainly be a conversation piece in the studio. And it probably works just fine.
The bleed valve is, IMO, essential to get the best from a BC.
