Crossfading soundbites- Automatic?
Re: Crossfading soundbites- Automatic?
Phil O wrote:
MIDI Life Crisis wrote:Yet another good reason to use multiple tracks. Seriously, one track editing like this really seems dumb to me...
I tend to agree with this. There are only rare occasions when I use crossfades in DP. For punch-ins, copy/paste operations, basic slicing and dicing, etc. I zoom way in and carefully adjust seams to line up with a zero crossing. It's usually an easy point to find and it always sounds good. For long crossfades (say 500ms or longer) I use MLC's technique. I just find it easier to get it exactly as I want. YMMV
Phil
Like you, I edit at the null point and never use a fade to cover a sloppy edit—with DP there is no need once you learn how. As you point out, it’s easy.
Cross fades are always special effects for me. For that reason, I prefer two tracks as it lets me have independent control of both sides. I rarely want an even cross fade which is what you get with a single track.
funkyfreddy
Post by funkyfreddy »
Interesting how different people look at crossfades. I rarely use 2 tracks but can see the advantage of it.
I will certainly start using 2 tracks more often as the fades get complicated....
MacBook Pro (16-inch, 2019) 2.3 GHz 8-Core Intel Core i9 16 GB RAM OSX 11.2 Big Sur
UAD Apollo Quad DP11.22 some Waves, Soundtoys, Digital Performer 11.2, Reason 12, iZotope 11, and lots of real instruments to play :)
funkyfreddy wrote:Interesting how different people look at crossfades. I rarely use 2 tracks but can see the advantage of it.
Same here. There's a lot of flexibility in the crossfade dialog, including independent fadein and fade out, and four edits points on each curve. I prefer having things that go together logically in the same track. If for some reason, these are not enough, you can supplement with Bite Volume curves.
