h all,
I just installed msi V1.1.2.
the stand alone is working fine,
when i tried to lunch it for the first time with logic 6.4.1 i used multi channel,
I could'n hear anything (no MIDI signal coming in), after a while it began crashing, and now i can't see it anymore in the multi channel, only stereo, and if i open it, logic instantly crash ...!!
please help !!
I'm in big hurry to finish a very big orchestral project
I'm very stucked...
thanks.
Msi Crash / logic pro !! please help
Mine's working fine with Logic 7.2.2. If you need to finish your project quickly, I suggest you to downgrade to your previous version if it was working. If you have anothe DAW (like DP ) you can tried opening a stereo rough mix of your project, do your MIDI with MSI and then go back to Logic with audio track of the orchestral part.
Good luck!
Mat
Good luck!
Mat
Imac Intel core 2 duo 2.33Ghz-2G ram / Macbook Pro 17" core 2 duo 2.33Ghz-2G ram/DP5.12/Logic 8.0.1/M5/MSI/BFD/828/RME Fireface 800/EMU 0404/Dynaudio BM5A
