how many internal harddrives will the g5 take?
i need extra hard dries for my g5 but as far as i can tell it can only take 1 more. i need at least 2 more to run audio and samples from. how can i do this?
cheers
paul
cheers
paul
If you're willing to give up a PCI slot, you can get up to 5 in there. I have 4 in mine.
www.g5drivebracket.com
Yeah, I don't understand why they went backward with the G5. My PowerMac G4 holds 4 internal HDs, but the G5s only hold 2? Doesn't make sense.Frodo wrote:Apple's internal hd expansion limit still concerns me. External drives are fine, but having a third internal drive would be more than a matter of convenience.
- Timeline
I did the bracket with a scsi card. running 15k spin drives. It's amazing!swiftness wrote:No, you can't put them in PCI slots, but you can buy a bracket to mount additional drives inside the case. You need a PCI slot for a SATA PCI adapter to get the data off your drives.
A lot of people are already using all their PCI slots for UAD/Powercore and audio interfaces.
i went w/ external sata drives via pci card ..Firmtek Seritek,they are great!you put drives in bundled enclosures
i use boot drive for apps ,2nd internal for samples and external drives (2 in each encosure) set up in raid array ..2nd enclosure serves as as backup,i did not mirror enclosures as this would slow things down as i understand it.
this is a good solution,i did not feel good about cramming 4-5 drives in G5 enclosure designed for 2 drives too many heat/fan /noise related issues potentially check out @ OWC
Re: how many internal harddrives will the g5 take?
macsrock wrote:i need extra hard dries for my g5 but as far as i can tell it can only take 1 more. i need at least 2 more to run audio and samples from. how can i do this?
cheers
paul
check out www.sonnetech.com jive drive. i believe it lets you add five drives to a g5 tower.
yes i just checked this is correct here is a link http://www.sonnettech.com/product/g5_jive.html
