Strange plugin problem
I'm facing a weird problem: All motu's own plugins don't show the numbers in the plugin window. So for example the Dynamics plugin doesn't give me my ratio. The plugin works, I can turn the knobs, but cannot 'read' them.
Anybody knows what I can do about this?
One more thing: My MW Equalizer plugin doesn't have a name anymore. It's in the plugin list, appearing as an empty line...
some weird things...
Marcel
Marcel
iMac | fast! | OS 10.6.7 | Ultralite MK3 | DP 7.22 | too many plugins
- daniel.sneed
I get this bug each time I don't turn power in proper order :
For my system : Mac, then usb soundcard1, then firewire souncard2, then run DP4.6.
DP dislike very much any audio hardware change (power on or off) while running.
I tried everything till OS re-install, DP re-install, to not avail.
I finaly found a trick :
Download a little free OSX utility called OnYx
http://www.titanium.free.fr/
Choose and download accordingly to your OS (Panther or Tiger)
Install it.
On cleaning page, just run the font-buffer cleaning, reboot and voila.
All your plugins are back and working !
Tell us if this is working for your system
Good sounds on you !
dAn
Install it.
dAn
- chickmagnet
Re: Strange plugin problem
dude, U need to say more. Have U installed junk lately? Messed with fonts? Upgraded anything? What's your system config?GMarcelK wrote:I'm facing a weird problem: All motu's own plugins don't show the numbers in the plugin window. So for example the Dynamics plugin doesn't give me my ratio. The plugin works, I can turn the knobs, but cannot 'read' them.
Marcel
My system is a Dual 1.8G5, 10.4.6, 1,25GB Ram, no Junk.
The only thing I have installed recently is probably a bundel of freeware plugins (digitalfishphones).
Can I re-install DP from the CD?
How can reset the settings of DP, and probably have DP rescan my plugins?
Marcel
Marcel
- daniel.sneed
I use english DP4.61 and french OSX.
But I don't feel language is related to this issue. Who knows ?
But shure this issue comes up each time I make unusual changes in hardware - powering on or off my audio cards - while DP is up.
Whenever possible I even avoid opening a DP project with a missing soundcard, if this one was used for this last saved project.
I have red on his forum DP is very picky about hardware type of things. That's also what I experiment.
By the way I had no issue at all by the days I was using only one single Motu 828 soundcard.
Repairing permission, trashing preference, re-intsalling DP is no cure to this issue.
But font-buffer cleaning with OnYx and reboot is a quick and good workaround on my system.
What's next ?
dAn
____________________________________
DP4.61, Titanium 667, OSX10.4.6, 750MoRam, 828mk1, Novation X-Station, Yamaha 01V-adatCard, Studer A1, Yamaha SW10
What's next ?
dAn
Get rid of iSight or at least disable it. My recent quirks started up again-- and I'd forgotten that when I updated to OS 10.4.5 a few weeks ago, I'd forgotten to disable the newer version of iSight and Widgets. Tossed these out and quirks stopped immediately.
6,1 MacPro, 96GB RAM, macOS Monterey 12.7, macOS 10.14, DP9.52
- daniel.sneed
The real words are "font-caches cleaning".
This is done very quickly by an utility named OnyX
free download at
it offers several maintenance utlilities
I use it almost every day
it helps keeping my system clean and responsive
Good to know you're out of this issue.
dAn
___________________________________________________________
DP4.61, OSX10.4.6, Titanium 667, 60Go7200rpm, 750MoRam, 828mk1, Novation X-Station, FastlaneUSB, Yamaha 01V-adatCard, Studer A1, Yamaha SW10
free download at
dAn
