MSI 1.1.1 - Notes Sticking in Sonar
Discussion of all things related to the MOTU Symphonic Instrument.
ittango
Post by ittango »
Hello, all. Just installed 1.1.1 (previous versions didn't work for me) and I'm having a sticky note problem. If MIDI playback is stopped during a phrase all MSI notes stick, and I have to click my reset button.
Any Ideas?
Thanx!
ittango
Fuhnetik
Post by Fuhnetik »
Mine stick too but not durin playback. When I first play a note I get a sound of another note and then it normalzies to the actual note Im playing. Help?
fastelder
Post by fastelder »
Same thing here. Reset audio button only cure. Happens mostly on instruments with sustain (sus) I see other posts that fault reverb for high CPU usage, but no reply to the sticky note situation.
Squirrel Court Studios
Instrumental backtrax for my chuch choir
3.2GhzP4 3G RAM 7200RPM SATA drives
WinXP-sp2
Dual 19" Veiwsonics (sweet!)
PreSonus Firepod
Sonar HomeStudioXL
MOTU Symphonic Instruments
Edirol Sound Canvas
DanAE
MSI Note Sticks
Post by DanAE »
I haven't had any problem with notes sticking while working within Sonar 3. I am using MSI as A VSTi plug-in. I have never had any luck with DXi. NOTE: All sounds are on a seperate hard drive than the MSI program. Also, I use GPO as a VSTi plug-in within Sonar and I have no problems with that program either.
Below are the specifications to my system.
Intel P4, 3.06 GHZ, 3 gig RAM
80 GIG SATA Hrd. Drv. & 120 GIG SATA Hrd. Drv.
NVIDA Quadro FX 500 Video Card
Windows XP PRO. SP2
DanAE
MSI Note sticks
Post by DanAE »
I should have mentioned in my previous post that I am running my anti-virus software at the same time too.
