Samples Don't Play Accurately On Fast Parts -DP and Musio Strings
- Primary DAW OS: Windows
Hello ! I've been having trouble playing back the string samples from my Musio Library. It either holds the notes for an ungodly amount of time (it literally never stops until I pause it) or it changes the rhythms like in today's example. I already followed the advice in other threads: to fix the clock in the MIDI keyboard, change a tiny part of the duration of the note so they don't overlap. Quantizing has helped me solve this issue in the past. I'm not sure why the string samples don't work well from Musio to DP. All my Logic friends have never had this issue before ... can someone help me please? Thanks so much!
Re: Samples Don't Play Accurately On Fast Parts -DP and Musio Strings
Are these samples recorded dry or with effects?
I have the same exact issue-Musio and DP don’t play well together. Response is laggy in real-time when playing/recording, and playback can be randomly inaccurate.
My fix is to use MIDI time delay inserts on the MIDI track mixer insert to move all the data early a number of ticks-experiment to see the exact amount needed. (I’m doing between 75-125 ticks depending on buffer size).
However this doesn’t address the playback timing inaccuracies. So, yesterday in fact, I just switched to my more dependable Opus East West Hollywood string libraries and everything was much better.
I did notice there’s a new Musio plug-in update, I believe it’s 1.27, they are updating fairly often, so hopefully they’re aware of this and are working towards a solution.
Last black Friday I bought the lifetime membership for access to the entire library. I’d like to be able to use Musio more but so far it’s proving to be a bit challenging.
Mac Studio Ultra, 64 GIG RAM, Apollo Quad, OS 13.4.1 Ventura
DP 11.22, Yamaha Motif XS8, Novation MoroderNova, UAD Apollo and FX plugs, Lots of PLAY/OPUS libraries, Ivory 2, lots of Arturia titles, all 4 Spectrasonics titles, NI Komplete 13, BFD2-3, Addictive Drums 2, MachFive 3, Pianoteq 6, lots of UVI Workstation titles, All 5 MusicLab guitars-RealGuitar, RealStrat, RealLesPaulCustom, RealRickenbacker and RealEight.
I see the OP is on a Mac. They may be better off posting in the Mac troubleshooting section. Another possible solution if you are on DP11 might lie in the Articulation Map Output settings by adjusting the Note Length or Delay settings.
Good point! I didn’t notice that. I have moved it.cuttime wrote:I see the OP is on a Mac. They may be better off posting in the Mac troubleshooting section.
I wasn't able to tell from the example, but do the "missing" notes happen if there is a repeated note (of the same pitch)?
If so, that may be related to a DP bug that we've discussed pretty extensively.
As a test, you can put an insert effect on the MIDI track to change duration and subtract about 6 ticks from all durations. See if that improves anything. If this not related to that bug, I'll show myself out.
I can verify that in my usage, the Musio issues are not from repeated notes, or the associated DP bug. My Musio woes are evident when playing back a series of different notes--and the rhythm is not correct. For example, last week I had a violin line of simple eighths and sixteenth notes--the playback rhythm was that of triplets, even after close repeated examination of the actual note time stamps. They were on the straight beat divisions, not the triplet time stamps. Nonetheless less, Musio could not play that rhythm correctly.
I switched to Opus Hollywood Strings, violin patch (Musio patch was also a violin patch) and the playback was perfect. Exact same MIDI track, assigned to the new VI.
Musio is not ready for prime time. Disappointing, as I love the voluminous library provided. Slow to play via MIDI (latency), and occasional incorrect rhythms on playback.
I've yet to update to the latest version, will do so in the next day or so--I'll report back if behavior improves.
