No audio after the last update
nickysnd
Post by nickysnd »
Hi,
I haven't used DP in a while and I forgot how to set it up. It seems to work just fine except no sound. I would really appreciate your help. All my music applications are working except DP.
DP 11.31, Mac mini, Apple M1, MacOS 14.4.1, Focusrite Scarlett Solo.
Mac mini Apple M1 ♦ 8GB RAM ♦ MacOS 14.4.1 ♦ Focusrite Scarlett Solo ♦ DP 11.31
Re: No audio after the last update
MOTU really needs to make this more explicit:
viewtopic.php?t=74002
828x MacOS 13.6.7 M1 Studio Max 1TB 64G DP11.31
nickysnd
Post by nickysnd »
cuttime wrote: Thu Apr 04, 2024 2:38 pm MOTU really needs to make this more explicit:
Thanks! It was checked. I disabled and then enable it again. Still not working.
nickysnd wrote: Thu Apr 04, 2024 3:42 pm
Bummer... that usually does the trick. Check your Bundles inside of DP perhaps?
nickysnd
Post by nickysnd »
James Steele wrote: Thu Apr 04, 2024 3:52 pm Bummer... that usually does the trick. Check your Bundles inside of DP perhaps?
I forgot how to do that. Where are they and what should I see there?
nickysnd wrote: Thu Apr 04, 2024 7:48 pm
Launch DP and load a project. Then hit Command+U and it will open the Bundles window. Check to make sure the main stereo outs in your project are routed correctly to a valid output in the Bundles window. Again... just a shot in the dark here, but I've had this setting get messed up before.
nickysnd
Post by nickysnd »
James Steele wrote: Thu Apr 04, 2024 8:12 pm Launch DP and load a project. Then hit Command+U and it will open the Bundles window. Check to make sure the main stereo outs in your project are routed correctly to a valid output in the Bundles window. Again... just a shot in the dark here, but I've had this setting get messed up before.
Here is a screenshot of the Out bundles, the Audio MIDI setup, and the Sound in System Settings. Initially the bundles only showed Main Out L-R, and when Adding it only gives me the option BlackHole, when what I need is Scarlet Solo. When I click those up down arrows to make changes nothing happens. What should I do?
Screenshot 2024-04-05 at 13.33.26.png (287.19 KiB) Viewed 241 times
