Can the MSI dat file reside on any drive on my system (including external firewire drives) or must it reside on the system disk?
Reid C
MSI DAT file to any drive?
Re: MSI DAT file to any drive?
I know you can place .dat files for other apps on other drives. I do it for Atmosphere, Ultra Focus and Charlie to name a few. Presumably, this works for MSI too.reidc wrote:Can the MSI dat file reside on any drive on my system (including external firewire drives) or must it reside on the system disk?
Reid C
You do have to make sure you create an alias of the .dat in the appropriate /Library/Audio/Plugins subfolder. I'd assume MSI will want its alias in the MAS folder since it's MOTU, but check your manual to confirm. If not, then the Components folder.
...thats right..but
some of us have had problems with MSI 1.1 and doing just that with the DAT file. The solution is to keep the DAT file in the default folder (whatever that is..)
Macbook, Leopard 10.5.1, Logic 8.01, MOTU Traveler.
http://www.smoothbeatsonly.com
In that case I would advice inspecting file owner and privs, this is best to do in Terminal.app.alexff wrote:some of us have had problems with MSI 1.1 and doing just that with the DAT file.
I have had cases when stuff on external FW disk has wrong access privs or wrong group. That has been enough to mess things up.
Luckily there are cmod and chown commands to help out.
+372 56222285
