Solo does not work correctly when I work with two screens.
Belushi
Post by Belushi »
Good evening,
I work with two screens. On the first I have the sequence or the editor window with a channel strip. On the second I have the MIDI Editor. Now when I press on the first screen in the channel strip solo this does not work correctly. When I switch from MIDI editor to mixer in the second monitor it works. Anybody know that?
Greetings and Happy Christmas, Denis
G4 1,6 GHz Dual MDD, OS X 10.3.9 Pro Tools 6.41 Mix +, G5 OS X 10.11.6, DP 10.13, Logic 9.18 & 10 ;Melodyne,EZdrummer,V.Guitarist-2,Raging Guitars,NI Komplete, Roland JV2080,S760,ATARI STE,...
Re: Solo does not work correctly when I work with two screens.
Belushi wrote: Thu Dec 21, 2023 10:06 am Good evening,
Hi Denis,
Solo is one of those everything affects everything else functions. I clicked on the wrong box accidently once and it probably took me a half hour going through the pdf manual, looking at every mention of Solo and making sure that it was working the way I wanted when I was done.
https://cdn-data.motu.com/manuals/softw ... +Guide.pdf
No one here is going to know the correct solution without seeing your setup. Searchable PDFs are your friend. You can also access it through the Help menu.
Belushi
Post by Belushi »
Hello,
I found the problem. Under Preference > MIDI Options > MIDI Solo Setup, you have to disable "Solo front-most MIDI edit window."
I find the solo department in DP... how should I say that... quite complicated. Simple is sometimes more.
Have a nice Christmas season and a healthy year 2024, Denis;
