I’m wondering if I did something wrong or am just suffering from extraordinarily bad luck.
I have a 1248 and 16A both about 4 years old.
The 1248 suddenly started to show all analog input levels pegged to the top constantly. No audio was available, nor did it output a sound…just pegged meters. The meters pegged even when there was nothing physically plugged into the unit besides a power cable.
I eventually pulled it and replaced it in my setup with an old 828mk3 hybrid.
About a month later, my 16A started to have trouble getting through its start up sequence. After 2 - 4 of the “undulating bar patterns” at start up, it would simply stop and freeze. Turning the unit on an off would eventually get it to boot and it operated normally.
However, this rare event turned much more regular and, eventually, successfully completing the start up sequence became the rare exception. I pulled this unit too.
I called MOTU tech support for help diagnosing or perhaps shipping the units to them for repair. The tech guy didn’t know what was happening and told me that since the units were out of warranty, they wouldn’t take them.
I have a local repair shop here that does good work. They opened the units and told me that ALL of the caps on the 1248 need to be replaced and that one of the caps on the 16A needs to be replaced.
So my question is: What cause capacitors to go belly up? So many in one unit is odd. Did I do something wrong?
- Power surge? I don’t think a power surge happened as nothing else was effected, and the units are plugged into an expensive APC power tower with battery backup.
They are mounted in an argosy rack unit next to each other and I rarely turn them off. Did they just get too hot?
Was it just a bad batch of capacitors that happened to get stuffed into the 1248 and just plain bad luck on the 16a?
Anyway, if you’ve made it this far, thank you. Any thoughts appreciated.
