Hi there.
Just wondering if DP 10 will run on a computer with an M2 Pro chip running Ventura?
Or, only DP 11 will run on a M2 pro/Ventura setup?
I checked the MOTU website, and it appears only DP 11 is compatible with Ventura. Or perhaps DP 10 will run on Ventura, but that it's just not optimized for it? (if that makes sense?)
Thank you for any input, David.
DP 10 compatible with Ventura?
2018 Mac mini, 3.2GHz i7, 32GB Ram, OS 10.15.7, DP 10.13, Motu 828mk3 FW.
Re: DP 10 compatible with Ventura?
DP 11 is Apple Silicon Native compatible.
DP 10 is not and needs to be run over Rosetta 2.
Running DP 10 on Apple Silicon over Rosetta 2... generally speaking, will there be a drop in 'performance' or any 'bugginess' in doing so (versus running DP 10 on Intel/Catalina?)
Or theoretically, DP 10 should run relatively smooth over Rosetta 2?
IIRC, DP10 introduced Apple Silicon Native compatibility.
