Thanks for your input. Yep... I ruled out using a VESA mount and having it take the place of one of my "wing monitors" early on as holding my arm outstretched to work with it would get tiring quickly as someone else pointed. out.nk_e wrote: ↑Wed Jul 05, 2023 4:37 am Hi James.
I’ve had a Raven for a while. In fact, I had two for years but sold one when I noticed I really was not using the second that much.
A couple of thoughts:
- I would recommend against using a VESA mount. The monitor is heavy for one, and you really do want it to be on a firm surface.
- It has a pretty wide range at which you can angle it, but I think laying it flat or near flat would prove problematic visually due to perspective and visual distortion. It would also just eat up a lot of desk space. Mine is somewhere around 45 degrees. YMMV
By complete chance I found the pic below in an advertising email that AudioScape sent to me this morning:
My desk below (excuse the mess on the floor... ugh...) is very similar:
I plan to put the Raven MTi2 where the MC Mix and MC Control are in that picture at angle that is very similar. I will still need to raise the center monitor (43" Samsung 4K TV) higher so the bottom part of the screen is not blocked by the Raven. That presents an other ergonomic problem, because if I raise it, the top edge of the Samsung will be higher than eye level when I'm seated. To get around that, I'm going to move the Samsung to my bedroom to use for a TV as it was intended, and replacing it with a 40" Ultrawide *monitor* that will have less resolution (3440 x 14400) but will probably be easier on the eyes and the top edge of the monitor will not extend as high as the Samsung would have.
In fact, the 40" Ultrawide (I had it sitting in my Amazon cart since last night) just went on sales on a "lightning deal" for $399. https://a.co/d/emExHR1 I can return it if it's not that great, but it's getting some decent reviews so crossing my fingers.
That may be the case. I think it's so certain things pop up where the should be.... but I think I can run things where each monitor has it's own space and thus there's a menu bar in each monitor and it shouldn't be an issue for DAW work.- For a long time, Slate required that the Raven be designated as your main monitor in a multi-monitor set up. This may no longer be the case, but I’ve had one so long that I do that now out of habit. Maybe Michael Canavan can verify whether or not this is still required.
Yep... I've done some research on that. Seller, I'm pretty sure, has a Pro Tools license, not DP. So he will need to initiate the transfer with Slate, plus I will have to pay a $25 fee to iLok for him to transfer that license to my iLok account. THEN... on top of it, I will have to purchase a DP license from Slate for $99. So all together I'm looking at not $500, but $649. But given it's $999 new and this seems to be in good shape and I won't have to be paying tax or shipping, seems like still a good deal. These NEVER pop up on my local Craigslist.- Remember that you will need to buy a $99 DP license from Slate unless the seller can transfer his to you. As I recall from the time I sold my second one, he will have to be the person to initiate the transfer.
This, I'm sure, is true. One thing that I like about my proposed placement of the Raven, is that I will still have my keyboard and mouse in front of me and when I'm in a hurry I can probably opt to work the old way. It's actually going to be an *additional* monitor and nothing else will have changed with my setup except for the MC Mix and MC Control going away. (I'm still going to need to get some sort of TB hub as I've already used up all my TB ports!) I seldom used more than one fader at a time on those, so if all I do is update my Window Sets so DP's mixer window is up full on the Raven at all times, if I want to do a fader adjustment, I should be able to just pull the fader down on the Raven... as well as adjust plugins if I want. Those simple things might be possible without even running the Raven software?- Learning to use it is a commitment. It’s not hard, but it does require one to change old, really ingrained habits.
Yep... I expected this, and again, my keyboard and mouse will be pretty much right there where they have always been.- You will still be quite reliant on a mouse. Some things are just quicker to execute with a mouse instead of touch. Also, some plugin and DAW interface elements are just too small to hit reliably with a finger.
Thank you!! I very much appreciate your helpful input!Anyway, a few thoughts from a long time user. If mine suddenly broke. I’d replace it immediately.
