Mac Studio "happier" with smaller buffer?
Re: Mac Studio "happier" with smaller buffer?
Thanks HC, all good info. I do run a UA tape emulation on my master bus- but I doubt that’s causing my latency. It’s running off my UA hardware— but I’ll certainly A/B to find out.
Good news , I just ran a mix with the new NI Guitar Rig 6 Apple version and it worked great- seemed like less processor hit and less latency. That’s probably one culprit removed..
Greg.
Greg.
Mac Studio Ultra, 64 GIG RAM, Apollo Quad, OS 13.4.1 Ventura
DP 11.22, Yamaha Motif XS8, Novation MoroderNova, UAD Apollo and FX plugs, Lots of PLAY/OPUS libraries, Ivory 2, lots of Arturia titles, all 4 Spectrasonics titles, NI Komplete 13, BFD2-3, Addictive Drums 2, MachFive 3, Pianoteq 6, lots of UVI Workstation titles, All 5 MusicLab guitars-RealGuitar, RealStrat, RealLesPaulCustom, RealRickenbacker and RealEight.
Re: Guitar Rig 6 - Apple Silicon
Just updated to Komplete> Everything seems good (Apple Silicon-Native FX suite is now here) except Guitar Rig 6. AU of Version 6.2.4 is not being located by DP.greg328 wrote: ↑Wed Aug 31, 2022 10:22 am Thanks HC, all good info. I do run a UA tape emulation on my master bus- but I doubt that’s causing my latency. It’s running off my UA hardware— but I’ll certainly A/B to find out.
Greg.
Digital Performer has encountered an error.
Mas,1 error reported by Mac Audio Unit Support
Failure: Initialize 275-10868 (-10868)
Re-installed after deleting NI-specified files.
Trashed the Audio Unit Info Each 64 Bit; DP re-scanned and shows AU FX and MFX Versions and VST3 version "Guitar Rig 6", no FX or MFX versions.
AU versions pull same error.
If enabled, VST3 version will open a window when instantiated as a plugin, but displays no data.
EDIT:
Thanks for connecting with us. This is a current known issue in DP, something our team is working on alongside with Native Instruments to resolve.
Best,
Matt - MOTU
- Guitar Gaz
Mine appears to work better on 512 - I tried mixing on 1024 and even on 2048 and the machine stuttered at times whereas with 512 there is much more stability. I can even record guitars at 512 although for vocals 256 is better. Have to remind myself to switch back to 512 when done recording.mikehalloran wrote: ↑Sat Aug 27, 2022 8:52 am Every setup seems to have an ideal buffer setting, IMO. DP on my iMP thrives on 32. My buddy’s M4 with Performer Lite on his 2014 Mini works fine with 512 — took awhile for me to find the right balance.
Gary Shepherd
____________
iMac 27" 3.3 GHz Intel Core i5, 32 GB Ram, Monterey 12.7.4, 64 bit, Digital Performer 11.3, Studio One 6.6 Professional, Reason 11, Melodyne 5 Editor, Korg Legacy Wavestation and M1, Arturia minimoog V, Helix Native 3.72, Bias FX 2 Elite, Superior Drummer 3, EZkeys, EZbass, Nektar Panorama T4, Motu M4, Faderport 2018, Gibson Les Paul Standard, James Tyler Variax JTV-59 and other gear.
____________
Hi , Did you get this resolved ? I'm having same issue with Guitar rig 6.2.4 and 6.3 . If I revert back to 6.2.3 it works fine no crash .HCMarkus wrote: ↑Wed Sep 28, 2022 5:55 pmJust updated to Komplete> Everything seems good (Apple Silicon-Native FX suite is now here) except Guitar Rig 6. AU of Version 6.2.4 is not being located by DP.greg328 wrote: ↑Wed Aug 31, 2022 10:22 am Thanks HC, all good info. I do run a UA tape emulation on my master bus- but I doubt that’s causing my latency. It’s running off my UA hardware— but I’ll certainly A/B to find out.
Greg.
EDIT:
Best,
Matt - MOTU
Bass Guitar , Digital Performer 11.1 , iMac Pro , Motu M4 , Mac os 12.3.1 Icon Platform M+
Re: Mac Studio
Is the Apollo Quad still in the loop? What version?greg328 wrote: ↑Sun Aug 28, 2022 9:25 am I’ve got horrible latency on my new Mac Studio ultra, even at small buffer settings.
Mostly heard through live mic input, and virtual instrument MIDI triggering.
I think I’ve gone through and removed all non-Apple Silicon ready plug-in so I’m not in Rosetta 2 mode.
Not sure what’s going on, but pretty disappointing so far.
experiencing the same error when upgrading to guitar 6.3 ... not even sure how to revert back to 6.2.3Z car guy wrote: ↑Fri Feb 24, 2023 3:04 pmHi , Did you get this resolved ? I'm having same issue with Guitar rig 6.2.4 and 6.3 . If I revert back to 6.2.3 it works fine no crash .HCMarkus wrote: ↑Wed Sep 28, 2022 5:55 pmJust updated to Komplete> Everything seems good (Apple Silicon-Native FX suite is now here) except Guitar Rig 6. AU of Version 6.2.4 is not being located by DP.greg328 wrote: ↑Wed Aug 31, 2022 10:22 am Thanks HC, all good info. I do run a UA tape emulation on my master bus- but I doubt that’s causing my latency. It’s running off my UA hardware— but I’ll certainly A/B to find out.
Greg.
EDIT:
Best,
Matt - MOTU
Same issue here after updating to 6.3 guitar rig .. is there a fix ? Also, I am unable to revert back to a working versionZ car guy wrote: ↑Fri Feb 24, 2023 3:04 pmHi , Did you get this resolved ? I'm having same issue with Guitar rig 6.2.4 and 6.3 . If I revert back to 6.2.3 it works fine no crash .HCMarkus wrote: ↑Wed Sep 28, 2022 5:55 pmJust updated to Komplete> Everything seems good (Apple Silicon-Native FX suite is now here) except Guitar Rig 6. AU of Version 6.2.4 is not being located by DP.greg328 wrote: ↑Wed Aug 31, 2022 10:22 am Thanks HC, all good info. I do run a UA tape emulation on my master bus- but I doubt that’s causing my latency. It’s running off my UA hardware— but I’ll certainly A/B to find out.
Greg.
EDIT:
Best,
Matt - MOTU
