I haven't really figured out how to stop it. When I had the MTP/AV, I tried all sorts of settings from the front panel and couldn't get it to stop. These are the messages it was sending out:Michael Canavan wrote: ↑Sun Nov 13, 2022 8:35 am There's a way to kill it on the hardware MTP/AV unit. The SysEx message sent here is always the sync message.
As I may have mentioned, it seems that this behavior only seems to happen when there is a DAW currently running (happens in DP, PT and Logic). If there is no DAW running in the background it does't do this. It seems like it's some sort of sync thing, or the MTP/AV (and later MIDI Express XT) is sending some sort of status to the DAW letting it knows it's there and connected I guess.
There might be some strangeness as has been mentioned with the Mac Studio in particular. I have power cycled the MIDI Express XT and then launch DP and DP does not seem to "see" it. Running Clockworks seems to re-establish the connection and then these little messages start up again until I quit DP.
It's not really that big a problem now and if I need to record a bulk sysex dump from a hardware module into Sysex Librarian, I just have to make sure I don't have DP open in the background and then I can get an "unpolluted" capture.
Again... don't regret getting the new interface. Yeah... I might have spent money I didn't need to, but I'm fully in the modern age now I guess.
