2408 MK3 with Adobe Audition CS6
CHICAGOAUDIO
Post by CHICAGOAUDIO »
Well, in addition to the timecode issue I'm having with the 2408 reader, I'm also experiencing issues using Adobe Audition CS6 with a 2408 MK3 and PCI424e card.
Irregardless of whether I use the internal PCI clock or an external clock, I have huge problems with hash and dropouts. Adobe works fine when using the internal computer card. And the 2408 MK3 is fine doing a conversion from TDIF in standalone mode. It's only a problem when trying to record using Audition via the Audiowire connection to the PCI card.
Have tried changing the sample size, which changes nothing. All input routing seems fine. Have CueMix FX app closed.
Have tried two different units, both with the same result. The input to the TDIF is solid.
Running Windows 10 Pro 64 bit. MOTU driver version 4.0.6.6814
