Lights out on 828MKIII
apanacci
Post by apanacci »
Hey anyone have this happen to your 828MKIII. The LCD on the Channel,page,parameter and value front of the unit has died. Everything works though. Just wondering what to do. I have an eq setting on the mix out section. It is saved. Wondering if a reset would help. Thanks !
2009 8 Core 5.1, 2012 6 Core MacPro,s , (32 gigs Ram) Mojave 14.6, Radeon 570, MacBookPros 2011, 2017 , 828MKIII Hybrid, 828X, MicroBook II, 8Pre, Nuendo 8ch A/D converter, PreSonus DigiMax LT ,DP11 , PT 2022.12, Cubase Elements 10.5, Peak 7, Logic 9 ,WaveLab 11, Reason 10, DSP-Quattro 5 ,many plugins , mics and synths. http://www.panaccimusic.com
Re: Lights out on 828MKIII
If you can shine a light into the display from the front and see a readout, the display is fine but the backlight or the circuit leading to it is the problem.
Google is your friend. Search for motu 828 backlight repair and you'll see a few hundred links, videos etc. Some of them will have part numbers and sources for them.
apanacci
Post by apanacci »
Thanks Mike ! Will have a look
apanacci
Post by apanacci »
Hey Mike I see the read out. Will Google away. Thanks again !!!
