Hey Mac OS Wizards.......
I recently added a nice, 32" 4k LG monitor for my single-monitor setup (late 2013 Mac Pro, Big Sur). I have the display scaled down to 3360x1890. On startup, the white Apple icon and progress bar start larger, then—about halfway through the startup process—they switch to the correct size. Consequently, all my app windows get moved every time I start up my machine.
Is there anyway to get the Mac to boot up at the resolution it's set to (without switching resolutions during startup)?
Monitor Shifting Resolutions on Startup
Re: Monitor Shifting Resolutions on Startup
Normal if you haven't selected the Default profile and/or resolution. My iMac Pro does that every time I boot.On startup, the white Apple icon and progress bar start larger, then—about halfway through the startup process—they switch to the correct size.
Ok, that's weird. I've not seen that unless I've booted up in a different mode first such as Safe or Recovery — then my windows open on the center screen and I have to put them back to my side monitors.Consequently, all my app windows get moved every time I start up my machine.
There might be a setting somewhere but nothing is coming to me.
You've changed the resolution but are you using the Default Profile? If so, try changing to another and see what happens.
Thanks, Mike, for the reply and ideas. I tried a couple different color profiles, but no effect on the resolution of window movement.mikehalloran wrote: ↑Sat Mar 05, 2022 1:36 pmOk, that's weird. I've not seen that unless I've booted up in a different mode first such as Safe or Recovery — then my windows open on the center screen and I have to put them back to my side monitors.Consequently, all my app windows get moved every time I start up my machine.
To be more specific, I like to tuck the control panel for my Apogee interface into the bottom right corner of the screen. After startup, it's floating up and to the left, as if it repositioned itself into the bottom right corner at the lower resolution, and then was left hanging closer to the middle after the resolution self-switched to a higher setting.
