What's the best method for connecting a second computer to my MOTU M4?
My setup currently is:
MOTU M4 <- PC
MOTU M4 Input 1 <- XLR Mic
I'd like to somehow get the audio from my MacBook into the interface so I can listen to both sources at the same time.
Currently I've tried a few USB -> Dual 1/4" cables into Inputs 3&4, but the sound isn't very good. If I plug into Inputs 1&2, it sounds better but then it seems to cancel itself out for some reason? And this is also problematic since I'm using Input 1 for XLR. I also tried a USB -> Single 1/4" out, but then it's just Mono replicated to both channels.
Is there a proper way to do what I'm trying to achieve? Not super versed on the ins-and-outs of audio stuff, so any help is appreciated.
Connecting two computers to MOTU M4
Re: Connecting two computers to MOTU M4
Mac Headphone Output > Inputs 3/4 on MOTU might work nicely.
I'll grab one and see if that works.
So far I've found that this cable is working best out of the ones I've tried. Minimal noise/hum.
Maybe. Those inputs are -16dB Line ins. If the signal is nice and clean but the input level is just not high enough, you'll need an active stereo DI
https://www.sweetwater.com/store/detail ... vel-driver
or a step up transformer.
https://www.sweetwater.com/store/detail ... el-shifter
I have used both of these on Line Ins 3 & 4 of an M4 and they work well (and are dead quiet) but the active DI gives you a hotter signal with a level control.
The Morley can sometimes be found used as the Ebtech Line Level Shifter with TRS jacks only—those with XLRs are wired parallel. Same otherwise (Morley owns Ebtech). A large number on eBay right now.
https://www.ebay.com/sch/i.html?_from=R ... r&_sacat=0
Let me add that the direct outs on my Yamaha P125 were useable but not as hot as I wanted into 3 & 4 through the Morley/Ebtech but splitting the headphone out gave me adequate levels. YMMV
Thank you for the suggestions! I picked up a used Ebtech on eBay and it seems to be doing the trick in conjunction with the 3.5mm -> Dual 1/4" breakout cable. For some reason it didn't work when I did USB -> Dual 1/4", it actually got quieter with the Ebtech.mikehalloran wrote: ↑Fri Jan 21, 2022 11:05 amMaybe. Those inputs are -16dB Line ins. If the signal is nice and clean but the input level is just not high enough, you'll need an active stereo DI
Glad it’s working for you.
The Morley/Ebtech LLS is a simple 2 channel (or 8 channel) step up/down transformer but I’m quite impressed by the low end response and lack of noise—both signs of high quality and excellent shielding. In addition, these eliminate a potential distortion issue that can occur with the M2/4 if the wrong cable is used with unbalanced sources (described in the MOTU manual).
I’ve had the chance to A/B against other passive DIs costing many times more. I imagine that I’d see a small difference in the bottom end response on an oscilloscope but I can’t hear one and that’s good enough for me. With bass, kick drum, low notes on a piano etc., anyone can easily hear the difference between good and not good enough when it comes to transformers—the worst are also noisy.
