My new Motu 4 and sound problem listen to this
- Primary DAW OS: Windows
Guys
I am new with Motu. Today I got my Motu 4 and this is what I get from time to time. What is the problem?
[YouTube] https://youtu.be/BVSs0Ins6K8 [/YouTube]
Thanks in advance
Re: My new Motu 4 and sound problem listen to this
Sounds like a Problem with your Samplerate/ System Clock.
It could also be a buffer size that's wrong somewhere.
Notice how it's slowed down.
It happens a few times a day and I have to open to motu control and ticket or untick
Use lowest latency safety offset tick or untick to make things work again
Should I return this device ?
Thanks in advance
Sorry to offer "annoying" advice. Have you installed the latest driver software? And, have you updated the firmware on the device itself. If the device is on the latest firmware, it will probably just say something like "You're up to date.".
This is my full spec pc and motu 4
Processor Intel(R) Core(TM) i7-10700KF CPU @ 3.80GHz 3.79 GHz
Installed RAM 32.0 GB
System type 64-bit operating system, x64-based processor
Motu Firmware version 2.00
Driver version is 4.0.9.0087
Thanks in advance
There's a new option in the latest drivers to sync Windows sample rate. Without knowing what software you are running and how your system audio is configured, I would try checking or unchecking that. A background app or Windows itself may be switching something behind the scenes. If you are using the M4 for both Windows system and ASIO audio it's always good to set the same sample rate for everything.
LOL I have no idea what you are saying Why life is so complicatedCharlzS wrote: ↑Wed Jan 12, 2022 3:47 am There's a new option in the latest drivers to sync Windows sample rate. Without knowing what software you are running and how your system audio is configured, I would try checking or unchecking that. A background app or Windows itself may be switching something behind the scenes. If you are using the M4 for both Windows system and ASIO audio it's always good to set the same sample rate for everything.
Exactly what should I do now
Thanks in advance
In the M4 Control App check or uncheck the sync to Windows sample rate option - try both settings. If M4 Control is not displayed, you get to it from the bottom right Windows notification area - right click the M and select Show. As far as how your apps and system audio are configured, you might want to check the forums for those apps.
I see , You mean this?
It was already checked by default.
I do not mind playing with sample rate and buffer size for the problem to go away however I can't spend the rest of my life
checking and testing
Thanks in advance
