Hi, I’m new here and I need some help. I’m running an immersive project based on Reaper DAW and MOTU 16A. I have to “feed” 14 individual speakers from 16A analogue outputs and I would like to know how (if it’s possible) to add permanent delay times on every individual output in order to time align every speaker to my listening position.
I prefer to make these settings directly to the hardware outputs. No mater what DAW the host computer running. The 16A must be set and forget!
Thanks in advance for your support.
16A for immersive project
Re: 16A for immersive project
I'm not familiar with the onboard FX but there should be a delay effect you can pop onto each channel, surely?
If so, just set the delay time to the tailored ms value for each channel, set it to 100% wet and turn off repeats.
