Michael Canavan wrote: ↑Tue Jul 20, 2021 12:38 amI don't know when the last time you used DP was, but DP has had the ability to bounce separate tracks as audio files all in one go for a while now.Killahurts wrote: ↑Mon Jul 19, 2021 2:30 pm Pro Tools also has a very simple feature that caused me to make the switch. It's called "Freeze up to this insert." You select the virtual instrument insert in a track, and right click, to get this. It bounces your instrument and MIDI to audio, but only to the point of the instrument, so if you have other inserts following, like EQ/compression, or the fader, etc. those do not get bounced and continue to be tweakable. You've simply traded MIDI for audio, without committing anything else. This is brilliant, and I so wish DP had something like it. It would bring me back. As it is now, it takes several steps and lots of preparation to do this in DP. It's a kludge, and I usually just skip rendering audio in a project, because there's never time.
Sounds like Pro Tools has good take on it, but you would have to set that up for every track right? so it's not going to be that much faster than muting FX you don't want rendered to the track.
I think it is faster for me.
In DP I have to:
Locate the MIDI and virtual instrument tracks, and make sure they are vertically aligned, because both have to be selected for the freeze/bounce. Go to the instrument track and turn off the unwanted plugins, find where the fader is, e.g. -4.61 dB, and mark it down with a pencil, or take a screenshot. Control click the fader to put it at unity. Execute the freeze/bounce. Go to the newly created track and bring it under the MIDI/inst tracks and select them all. Go to the mixer window and copy the plugins to the new track, and activate them. Go to the new track's fader and put it at the value I marked down before, and then turn of the MIDI/inst tracks if the freeze/bounce didn't do it automatically.
In Pro Tools I have to:
Right click the instrument insert and select Freeze up to this insert.
