I need a tutorial to make mastering with Motu AVB Mix Panel. As an example there are many tutorials from scratch how you can mastering a track in logic with plugins etc. But the problem with Motu AVB is there is no metering which you can see the LUFS such as by Yoelean Level Metering 2 plugin. Also the use of compressor i think is not so easy to see if it is clipping or not. Also the use of Leveler at the main output is the same problem for me.
Also the EQ is problem because i can't solo it LOW or MID or High to see what happens on that freq which by Fabfilter that no problem is..
I am really interest how you are using that part of Motu AVB for complete Mastering a track.
Mastering with Motu AVB (Best Practice)
