Strange issue: distortion on soft synth on headphones but not monitors
Arlanda Airport
Post by Arlanda Airport »
Hi - I noticed a strange issue while recording last night in DP. I added an instrument track with Arturia Pigments 2 on it and noticed a cracking static noise on each preset when monitoring through headphones. When I listened to the synth on monitors, the static is not audible. The signal sounds normal. Further, I don’t hear any distortion when playing hardware keys in either headphones or monitors. Just when playing the plug-in. I’m using an 828es. Is there something I am overlooking in routing the plug-in synth? I’m running Catalina, latest versions of Arturia/MOTU software. Thought it could be a sample rate conflict but I would expect to hear the static on the monitors too. Thanks
Gravity Jim
Re: Strange issue: distortion on soft synth on headphones but not monitors
Post by Gravity Jim »
Have you checked your gain staging on the offending channel(s)?
Jim Bordner
Gravity Jim wrote: Mon Dec 28, 2020 12:29 pm Have you checked your gain staging on the offending channel(s)?
The next thing I'd check is buffer size.
DP 11.32; 828mkII FW, micro lite, M4, MTP/AV USB Firmware 2.0.1
2023 Mac Studio M2 8TB, 192GB RAM, OS Sonoma 14.6.1, USB4 8TB external, M-Audio AIR 192|14, Mackie ProFxv3, Zoom F3 & UAC 232 32bit float recorder & interface; 2012 MBPs (x2) Catalina, Mojave
