Fixing phase issues in DP
Hi, I'm wondering if any of you have any tips regarding phase issues and how to fix them in DP.
I'm working on a traditional Irish folk tune employing pipes, acoustic guitar, flute, violin, and various percussion. The main featured percussive instrument is the Bodhran
It was recorded in stereo with microphones on both sides of it, left and right. The player did multiple takes which were edited and compiled. Now we seem to having some phase issues on some of the different takes.
Would any of you have any advice on the most efficient way of fixing this? Rerecording it is not an option at this point. Thanks, Fred
MacBook Pro (16-inch, 2019) 2.3 GHz 8-Core Intel Core i9 16 GB RAM OSX 11.2 Big Sur
UAD Apollo Quad DP11.22 some Waves, Soundtoys, Digital Performer 11.2, Reason 12, iZotope 11, and lots of real instruments to play
Re: Fixing phase issues in DP
Precision Delay is the uh… precise tool you are looking for (pardon the pun). The Plugins have their own manual but this is a brief overview:
Correct delay and phasing issues with one click
Precision Delay
Precision Delay's unique, breakthrough design helps you phase-align complex signals. For example, if you record a guitar amp or an acoustic instrument from two different mics placed at different distances, the time delay between them will likely cause phase issues that make the two channels sound hollow or affected by a comb-filter-like rasp when played together. The solution? Feed both signals into Precison Delay and click the ALIGN button. Precision Delay performs complex, real-time analysis on the signals to determine phase similarities, then instantly aligns the signals with sub-sample precision. You can further manually adjust to find the "sweet spot" to your ears.
And a video
https://motu.com/en-us/products/softwar ... -plug-ins/
I use a similar tool from Eventide but the only real difference is the GUI — it was a giveaway a few years ago. No reason to seek it out and pay the $99 when Precision Delay is included with DP.
https://www.eventideaudio.com/products/ ... time-align
Precision Delay
And a video
DP 11.32; 828mkII FW, micro lite, M4, MTP/AV USB Firmware 2.0.1
2023 Mac Studio M2 8TB, 192GB RAM, OS Sonoma 14.6.1, USB4 8TB external, M-Audio AIR 192|14, Mackie ProFxv3, Zoom F3 & UAC 232 32bit float recorder & interface; 2012 MBPs (x2) Catalina, Mojave
Thank you so so much for your quick reply Mike! I appreciate it very much and will give it a go!
You just saved me some valuable hours!
Motunation.com has been a God send over the years in my humble experience
It's worth mentioning that if you are recording on either side of a frame type drum, then the stereo mics are 100% phase inverted.
For every time the head moves away from mic A, it is moving toward mic B.
You may find that inverting the phase on one of the mics will fix most of it.
It can also be very helpful to zoom way in on the wave form to see both that the wave is inverted, and also that there may also be some micro delay, as well. But start with inverting one, see where that gets you. Pan them to mono (temporarily) and you'll be able to hear if it is immediately better or worse.
M1 MBP; OS 14.5, FF800, DP 11.3, Kontakt 7, Reaktor 6, PC3K7, K2661, iPad6, Godin XTSA, Two Ibanez 5 string basses (1 fretted, 1 fretless), FM3, SY-1000, ...
Thank you Jon! Good to know!
Another question.... When I listen back to the track in Mono I am using the folddown tab on the Master Fader in the mix window and selecting Mono, then selected None when i want to go back to stereo.
Is this how you do it or is there a better way of switching your mix from Stereo to Mono in your opinion?
Thanks again, Fred
Thanks again, Fred
One way to do it…funkyfreddy wrote:Thank you Jon! Good to know!
Many of us use monitor controllers with a dedicated Mono switch. That way you can just hit the button and check quickly without touching your mix. All but the most rudimentary have them beginning with the $69.95 Mackie Big Knob Passive and $58.95 Behringer.Is this how you do it or is there a better way of switching your mix from Stereo to Mono in your opinion?
Thanks again, Fred
https://www.sweetwater.com/c417--Studio ... Management
Many also have a switch that puts your subwoofer in or out (many subs have that function as a footswitch, also).
I use the Radial MC3 but there are many excellent units on the market.
My audio interface has a mixer control panel (that is just open all the time when my interface is on) with a mono button. Alternatively, you could send the tracks to a stereo bus, (panned hard left and hard right), then create an Aux Track with that bus as input. Insert a TRIM plugin onto that Aux track, use the Trim plugin to pan things center. That way you can option click on the insert label in the mixer to bypass the Trim plug-- keep it bypassed to hear stereo. Enable it to hear mono. Delete when you're done with the mono business.
- waterstrum
Thumbs up for the Mono button.
Has saved my butt on numerous occasions.
All is well
