Themes not working - cannot change - all greyed out
Trying to change the theme in DP10.11 Go to preferences, select Display then Themes and everything is greyed out and it is stuck on Medium Light. Restarted DP, no help. Anyone ever have this happen? Any ideas how to get this working again? Thanks.
DP 11.22, Mac Pro 14,8 macOS X 13.5, 128 GB RAM, Apogee Symphony I/O, Apollo x8p, UAD plug-ins, PSP, Waves Mercury, NI Komplete Ultimate 14, Spectrasonics, Hollywood Orchestra, Spitfire; Symphobia, Los Angeles Scoring Strings, True Strike, VSL, real violins, guitars, mandolins, pianos, drums, percussion & lots of other stuff...
- Guitar Gaz
Re: Themes not working - cannot change - all greyed out
What Theme are you trying to switch to? If its an older or 3rd party Theme, or one you customised, these may not work fully in DP10. But until you say what one does not work I can't help you.
If its a DP10 Theme, they may need re-installing. But this sounds like an older Theme to me so far.
Gary Shepherd
____________
____________
No themes are working at all - period. Everything is greyed out.
Just re-installed DP10 - all is good again!
- Guitar Gaz
It must have not installed the Themes properly first time around - a re-install usually does it!rosindabow wrote:Just re-installed DP10 - all is good again!
Gary Shepherd
____________
____________
No - this was not a new install. Some file must have been corrupted - I have been running DP constantly for years and have never seen this happen before. And the more I thought about it, the more I realized that a few other things had not been working correctly as well. The re-install got rid of the corrupt code and everything is running smoothly again (for the moment). Thanks!
