sudo kextutil -v /Library/Extensions/MOTUCoreUAC.kextMIDI Life Crisis wrote:Maybe you still have the Terminal command you can post here?
It goes without saying: caveat emptor.
From the Terminal manual, it looks like this command would diagnose a problem with the .kext, but not fix anything. Did they ask you to report back what you got from running this?b.g. wrote:sudo kextutil -v /Library/Extensions/MOTUCoreUAC.kext
I had a memory fail. I'm sorry. Thinking back, I called MOTU specifically about the loopback inputs not publishing. The Terminal command fixed that. I was so happy that the tech was able to walk me through the fix that I forgot to tell him about the other issue I was having: The M4 was not being recognized as the default audio interface. Each time I launched DP I would have to go to Configure Hardware Driver and confirm M4. The Terminal command seems to have fixed that as well.bayswater wrote:From the Terminal manual, it looks like this command would diagnose a problem with the .kext, but not fix anything. Did they ask you to report back what you got from running this?b.g. wrote:sudo kextutil -v /Library/Extensions/MOTUCoreUAC.kext
Ok, never saw those problems but I’ll take note.b.g. wrote:I had a memory fail. I'm sorry. Thinking back, I called MOTU specifically about the loopback inputs not publishing. The Terminal command fixed that. I was so happy that the tech was able to walk me through the fix that I forgot to tell him about the other issue I was having: The M4 was not being recognized as the default audio interface. Each time I launched DP I would have to go to Configure Hardware Driver and confirm M4. The Terminal command seems to have fixed that as well.bayswater wrote:From the Terminal manual, it looks like this command would diagnose a problem with the .kext, but not fix anything. Did they ask you to report back what you got from running this?b.g. wrote:sudo kextutil -v /Library/Extensions/MOTUCoreUAC.kext
