Export/save an entire project from 44.1k to 48k
Hi all - is there a fast and reliable method to export/save an entire project moving from 44.1k to 48k? Thanks!
DP 11.22, Mac Pro 14,8 macOS X 13.5, 128 GB RAM, Apogee Symphony I/O, Apollo x8p, UAD plug-ins, PSP, Waves Mercury, NI Komplete Ultimate 14, Spectrasonics, Hollywood Orchestra, Spitfire; Symphobia, Los Angeles Scoring Strings, True Strike, VSL, real violins, guitars, mandolins, pianos, drums, percussion & lots of other stuff...
Re: Export/save an entire project from 44.1k to 48k
Yes but not enough info. At which point do you want to convert the project? It's all easy but I don't want to guess what you're looking for and write three solutions when you are looking for one.
Um... change the sample rate and export? Do you have any easier questions?
The files on import? The tracks after import? Keep the project at 44.1 but export at 48? Export at 44.1 for some users but 48 for others (half the projects I do these days)? Something else?MIDI Life Crisis wrote:Um... change the sample rate and export? Do you have any easier questions?
Yes, it's easy — but wadduze want?
Because of Zoom, I have DP convert everything to 48 on import but some of the people I work with have old stand-alone recorders that only work with 44.1. I'm not assuming that's what the OP wants.
But basically to answer the simple question, you have to convert to 48 and export. I haven’t done a project in 44.1 in well over a decade.
