DP synced to other software?
Hello!
Is there a way to slave/sync start/stop, and song position of DP to Ableton? I have rewire set up but would like my VST's to be accessed by Ableton and use DP for audio. (for certain things). With DP as the master it doesn't allow that. I am open to work arounds---
BTW, DP 10 looks great and is working well so far after installing it earlier today!
iMac 27" 4.2 GHz i7 1TB SSD. 40 GB RAM. Apogee One.
- philbrown
Re: DP synced to other software?
I never got this to work reliably and eventually gave up on it after many hours of trying.
That doesn't mean it can't be done, though.
Maybe something's changed or it was operator error.
The furthest I got was using IAC to sync vs. Rewire.
Rewire has serious limitations as I think you've already figured out,
and as Ableton states at the bottom of these articles.
If you get it figured out, please post how you did it.
viewtopic.php?f=1&t=61935
https://help.ableton.com/hc/en-us/artic ... imitations
https://help.ableton.com/hc/en-us/artic ... and-ReWire
I had DP synced with Mixbus back when MB was meant to be used as an external mixer. I used IAC or the version of the same thing that is part of DP, can remember which, but they seemed to do exactly the same thing. I've also done the same with DP and Logic and other pairs of applications. But perhaps as Phil experienced, the sync would work for while, but then fail for no apparent reason, requiring both apps to be restarted. I don't think this was just a DP problem -- the same thing happened with other pairings.
MTC and to a lesser extent MIDI Beat Clock are your options, You can slave either timeline wise to each other over the IAC in Audio MIDI Setup. You can also set up the IAC driver to allow you to use one as a 'host' for VSTi's and the other as the MIDI recorder.Julia123 wrote:Hello!
Getting audio between the two is trickier, Jack OSX is the free option, and there's a few paid ways, barring using the audio outs and ins on your sound card.
None of this is super elegant, and I always hoped for a ReWire 2 Pro or something to come along allowing both DAWs to host VSTi's etc. Now that Reason has audio and VST support that's not gonna happen for sure.
Thanks! It sounds like IAC is the way to go. I see it in the iMac's Audio MIDI set-up (which only shows MIDI devices, not my software), and I see where to select it in Ableton's preferences, but I am not getting the concept of where/how to do this with DP?
Sorry I am still not getting this. I have the IAC showing and on in my Audio MIDI set-up but not sure how to set this up in DP. It doesn't show up in the manual in my searches.
- philbrown
Preferences>Receive Sync>MIDI Beat Clocks :: Sync To Port dropdown menu: IAC DriverJulia123 wrote:Sorry I am still not getting this. I have the IAC showing and on in my Audio MIDI set-up but not sure how to set this up in DP. It doesn't show up in the manual in my searches.
Setup menu>Slave to external sync
Set Ableton to send sync via IAC
EDIT: It's a little confusing because you don't actually set anything up in the AMS MIDI window itself. You can double click on the IAC icon in the MIDI window to make sure, but it's on by default as far as I know. The bus is just there as part of the system. You put it to use by assigning your send and receive apps to "IAC bus" as per the steps above.
