Wanting a solid control surface for DP 9.5
- Gravity Jim
Re: Wanting a solid control surface for DP 9.5
Here's the behavior I'm seeing:
The jog wheel seems to have an On and Off position: when I press down on the wheel, each time it either responds or doesn't, depending on what it was doing before the last wheel "press."
If I scrolled back to zero and kept turning the wheel, I had to turn the jog wheel back "On" by pressing down on it to make it work.
This isn't a big deal for me, as I rarely use the jog wheel. I just wanted sliders and pan knobs.
Jim Bordner
Hmm, behaviour I'm getting is slightly different. Either way, it seems buggy as hell at the moment and I will probably go back to 9.5 until (if) it's fixed. It's disappointing because being able to snap the wiper to the grid is a nice feature and would benefit me greatly.
What I really want is a controller that integrates with a DAW sufficiently reliably that I can actually just use the controller as a remote for my DAW. However, the implementation is generally so half-arsed (either on the software or the hardware side) that I am stills truggling to find a good, reliable solution after a decade of searching.
#grumble
#grumble
MOTU is a hardware company. Why they do not make an integrated custom control surface for DP 10 is puzzling. The Raven works well since DP has screen size adjustments. PT has the S3, PreSonus has the StudioLive... Please MOTU go for it!
waxman
If Motu released a well-integrated control surface, and also worked on further integrating DP with the CueMix functionality in their audio interfaces to support more advanced routing functions, I think they would be in a very unique position in the market
All the components are there, they just need to bring them together.
I'm also thinking (again) about getting a controller. It's along time since I fiddled with this sort of stuff, but it seems that you could (if your nerdy enough and have the time) to almost setup something like the X-Touch in any way you want using something like Max. At least that's what I'm getting from this video (it's about cubase but should apply to DP, too):
https://www.youtube.com/watch?v=esOnlGyvTs4
So I'm still having problems getting a good control setup going with Digital Performer.
The jog wheel still isn't working properly on DP 10.01 with an MCU I bought. It seems there's no way to configure an external MIDI controller to control the record arm / solo / mute status of tracks. And MOTU's own DP Control iOS app seems to have long been abandoned.
So it seems to me that the principal way to use DP is to sit in front of your computer with a keyboard and mouse? Has anyone else found good options for tracking and playing instruments at the same time without constantly having to move back to the computer?
Just get a Raven and get into the Batch Command System. It will take about a week of a learning curve but it is very easy once you have the BC's set up because everything is labeled and laid out great with now page scrolling etc...seedylee wrote:So I'm still having problems getting a good control setup going with Digital Performer.
Raven is by far the best controller out there until you jump up to a $20k Protools system. Then there is that.
waxman
- terrybritton
- Primary DAW OS: Windows
I may have posted this earlier, but if you can find an old Behringer BCF2000 controller, I have mapped its Mackie emulation for DP in this article here.
viewtopic.php?f=30&t=65913&p=560116&hil ... 00#p560116
Terry
Terry
MOTU 828 mk3 hybrid
MOTU 828 mk3 hybrid
I had the BCF2000. It would have been fine but the moving faders were loud and annoying. Sounded like a model train going down the tracks. That was a deal killer for me.terrybritton wrote:I may have posted this earlier, but if you can find an old Behringer BCF2000 controller, I have mapped its Mackie emulation for DP in this article here.
Terry
waxman
Another option is an iPad and VPro... that gives you faders and a few options. Just kind of small. There are other options. For mixing in ITB Andrew Schepps just uses a single fader pro and a laptop. I like that combo because of the trackpad on the laptop keeps everything ergonomic and the fader pro gives that tactile feel. But for tracking it's kind of clunky. For all-around performance, the Raven is the best option.
waxman
I agree. I have one and it’s useful to write in ramps, fades and such, but you don’t want it working all through a mix.waxman wrote:I had the BCF2000. It would have been fine but the moving faders were loud and annoying. Sounded like a model train going down the tracks. That was a deal killer for me.
May I ask exactly how you did this? I've been trying for hours with no success. If I go into commands and press a button on the X-Touch One, DP doesn't seem to recognize it. If I manually input a value (such as Eb0 to assign cycle), the X-Touch One still doesn't execute the command. There are other buttons sending useless commands, such as a button that isn't the transport playback button causing playback to start. What mode do you have your X-Touch on? How did you reprogram the buttons? Thanks.seedylee wrote:The Behringer X-Touch works pretty well in DP 9.5 in Mackie Control mode, with a few caveats.
Firstly, you need to remap several of the controls on the X-Touch so that the printed functions match DP 9. This is because Digital Performer itself had different mappings on the original Mackie Control for which they had no overlay, and also because the X-Touch doesn't have the complete set of MCU buttons. This is pretty easy to do, but requires having a copy of the original Mackie Control layout and a copy of the DP overlay for cross-reference.
Krakadon
aka Dave Williams
Rock, metal, Camas, WA
* 15" Mid-2019 MBP 2.4 GHz 8-core i9, 32GB RAM, Ventura 13.6.5. TB: UA Apollo QuadFW w/TB card, Satellite OctoTB2 & OctoTB3, PreSonus Quantum 4848 TB2; USB 2.0: Ext USB3 drives, Fractal Audio Axe-Fx III , Revv Generator 120 MK3; USB 3.0: Stream Deck XL, M Audio Oxygen 49, Akai MPD218, Console One Mk3, SSL UC1, X-Touch U; HDMI: 34" 16:9 & 32" 2K Monitors
* DP 11.31
aka Dave Williams
* DP 11.31
It's a bit of a pain, but essentially the issue is that Digital Performer had its own overlay for the original Mackie Control Units, which means that even on the original Mackie Control, the functions printed on the control surface don't match what they do in DP.
The Behringer is sending the correct commands as printed on the fascia, but there's no overlay included for the X-Touch. Also, the subset of buttons implemented on the X-Touch isn't so useful for Digital Performer.
The trick is to use the "MC Custom" mode on the X-Touch, which you can enable by holding Stop and pressing the pan knob in. Once you do that, you can change the Mackie command sent for each button. What you'll need to do is check the DP manual to see how DP responds to each of the Mackie commands and map them accordingly.
Me? I gave up with control surfaces and just ordered myself an analogue mixer. Unless you get a specific combination, they often don't work (and I've tried many combinations).
So if anyone wants a near-new Behringer X-Touch cheap, let me know!
Gravity Jim....Gravity Jim wrote: ↑Tue May 14, 2019 10:05 am I'm using an Icon Platform-M controller, and the jog wheel works with DP10. Not as smoothly as I might like, but it does jog by one-measure increments, as described above.
The rest of the sliders and knobs work flawlessly.
I just updated to DP10. Wondering if you're still happy with the Platform M as I've been considering going in that direction. I'm really just looking for a small-footprint controller that enables me to ride faders in a mix and my single-channel FaderPort is no longer reliable.
Thanks.
- Gravity Jim
Yeah, I'm running DP 10 and the Icon Platform M is still cooking.
Jim Bordner
