Why do you say that? If you look at the contents of the app package, you still see only the two sets of images, regular and double res for retina, that have been there for a long time. I don't have extensive edits in my themes, but for those I have, all I had to do was edit the regular images, and then create a double size image with no interpolation, and it all worked with the new scaling feature. Some stuff I used in 8 and 0 doesn't work because the basic images and layout changed in10 so I had to create those over again, but only the two versions.dix wrote:Shooshie wrote:From what I understand MOTU painstakingly created separate graphics for each scale level for each skin, which is why even when huge the graphics remain sharp.
E.g. look at
/Library/ApplicationSupport/MOTU/DigitalPerformer/Themes/MoTools.bundle/Contents/Resources
or any bundle other than MoTools.
This is the one I use most often, and I've edited about a dozen of the files in this bundle, but again, only the two versions of each png file (and a few lines in the html files to change some background colours).
