Repairing Severe Clipping
I'm mixing a live concert where there was no time for a sound check. The drum OH track clipped on the start of the first piece:
MP3: http://minormodemusic.com/misc/2-DrOH.mp3
I have RX 6 Advanced and would appreciate suggestions on how to fix this.
Thanks.
**Leigh
Thanks.
**Leigh
I don't care what you play. I care how you play.— Karl Berger
iMac Pro 3 GHz 10-Core Intel Xeon W, 128GB RAM, Mac OS X 14.2, DP 11.3
Re: Repairing Severe Clipping
I'd just cut & paste a couple different ride cymbals from a couple beats later.
Doesn't RX have a de-clip plugin? I'd play with that and see what it's made of for starters. Also, some creative automation of level and EQ at the hits might give you a sound that's forgiving. Stubb's solution may be your best bet but getting it to sound seamless might be an issue, because of the bleed I'm hearing from other instruments. Only way to know is try it.
Declip does not perform miracles but I would give it a try as well as Spectral Repair.
You might send a few seconds to Izotope to see if they can be more specific.
I have some lite version of RX I got free or cheap because I had some other of their products. I applied a Declip to a live recording with a lot of overloads, and I'd say the result was a miracle. I don't know how it figured out what to replace a long series of "1's" with but it made a pretty good guess.mikehalloran wrote:Declip does not perform miracles but I would give it a try as well as Spectral Repair.
- Sean Kenny
Firstly, I would try riding out the clip using trim automation to smooth it out
Sure the clip will still be there, but can you actually hear it? Modern day converters can be quite forgiving
If not then you're done.
Second, try pasting other rides over but I would apply a hp filter to the pasted rides to avoid any 'nasties' from the low frequency bleed from other instruments.
On my monitors (which are pretty tasty) it doesn't sound that nasty here i.e. I think you may get away with the first option.
Cheers
Sean
Cheers
Sean
Mac Pro 3 GHz 8-Core Intel Xeon E5 - 32 GB Ram 1867 MHz DDR3 ECC - OS X 10.12.4 - DP 9.13 - RME HDSPe Madi card - iz ADA converters 24 i/o - Antelope Orion 32 i/o - Audient desk - Miller & Kreisel Monitors - Wunder Mic Pre's x 8 - very understanding wife!
http://www.ten21recordingstudios.co.uk/
Thanks for all the suggestions.
The clipping was too severe for RX to fix. I ended up cutting out the offending few seconds of the drum track and replacing it with a corresponding section cut from the voice track with some compression to bring it up enough. I put the clip on a second track. It's a busy enough piece that all this worked well enough.
**Leigh
**Leigh
