Both Halion and Halion Sonic crash DP every time I disable and re-enable the audio system, without fail. Also whenever I switch chunks if the chunk I'm going to has Halion in it.
Once I restart DP, it'll load up just fine.
Halion 5 (2.2.7 build 111), Halion Sonic (2.2.5 build 18). Dp 9.51 on Windows 10.
Does anyone else have this problem?
Crashes with Halion & Halion Sonic
- Primary DAW OS: Windows
DP 10 - Win 10 - Ultralite AVB
Re: Crashes with Halion & Halion Sonic
Oof. Nevermind. Appears it was a dongle issue.
Updating license control seemed to have solved it.
Hmm...seems I spoke too soon.
Still getting crashes when I switch between sequences that use Halion. If I first disable the audio engine, then switch, then turn audio back on, it works. Otherwise I get a MAS error [-108], followed by an immediate crash.
Put a ticket in with Steinberg since I assume it's Halion's fault, not DP's.
Anybody seen an error [-108] before?
Mike
Mike
