SSD Performance Question
Is there any speed or efficiency advantage to using two internal SATA SSD's in a Mac Pro for loading and streaming samples and VI's in DP (different orchestral sections on different drives, etc.) rather than having them all loaded on their own single SSD? Using 7200 RPM SATA drives I know it was better performance-wise to break up the samples across multiple drives but with the much faster SSD's I'm curious if doing so matters.
iMac 20,1 10-core, 3.6Ghz, OS10.15.7, 128GB RAM, DP 10.13, VEP7
Re: SSD Performance Question
No.
In fact, the 3G buss speed makes using two drives slower. Being audio, it’s unlikely that anyone will notice this in the real world. If you have 2 SSDs working fine, no reason to consolidate to 1 drive if that’s all you’re trying to accomplish.
All of this ‘better on 2 drives’ goes back to PATA on the G4 and earlier when it was a real thing involving single vs multi threading. With the low capacity, slow HHDs and 66/100 bus speeds of the day, yea, it made a difference.
DP 11.32; 828mkII FW, micro lite, M4, MTP/AV USB Firmware 2.0.1
2023 Mac Studio M2 8TB, 192GB RAM, OS Sonoma 14.6.1, USB4 8TB external, M-Audio AIR 192|14, Mackie ProFxv3, Zoom F3 & UAC 232 32bit float recorder & interface; 2012 MBPs (x2) Catalina, Mojave
In my case, I keep my VIs on a separate 2T drive because a 4T drive is over $1,300. Two great 2T SSDs is $1,000. Being faster on paper will not translate to better performance irl.
Thanks for your replies, Mike. How much performance increase do you notice having VI's on SSDs vs having them 7200 RPM SATA drives?mikehalloran wrote:In my case, I keep my VIs on a separate 2T drive because a 4T drive is over $1,300. Two great 2T SSDs is $1,000. Being faster on paper will not translate to better performance irl.
- supersonic
I use the Thunderbay Mini with 4 500GB SSD drives in RAID 0. I get over 1000MB/S this way but is this really any better? I've no clue. I haven't tried with the 4 of them separate with the libraries spread out.
Music is movement in silence
I’ve done some ssd speed tests on our MacPro 6,1 Trashcan internal 1TB factory v external 1 TB 6g OWC in an OWC TB dock using Blackmagic. The internal drive is always faster but the external SSDs are certainly fast enough for sample streaming and audio
Frank Ferrucci
http://www.ferruccimusic.com
- supersonic
Even big orchestral libraries like the Hollywood, LASS, Spitfire etc?frankf wrote:I’ve done some ssd speed tests on our MacPro 6,1 Trashcan internal 1TB factory v external 1 TB 6g OWC in an OWC TB dock using Blackmagic. The internal drive is always faster but the external SSDs are certainly fast enough for sample streaming and audio
It depends. Bouncing etc. are notably faster. Streaming in real time, not really. File transfers and other tasks I’ve moved to the external, no question, there’s a large time savings.Rusty Shackleford wrote:Thanks for your replies, Mike. How much performance increase do you notice having VI's on SSDs vs having them 7200 RPM SATA drives?mikehalloran wrote:In my case, I keep my VIs on a separate 2T drive because a 4T drive is over $1,300. Two great 2T SSDs is $1,000. Being faster on paper will not translate to better performance irl.
My studio runs cooler having gone to SSDs for everything except Time Machine. Never going back.
For a 6.1 MP, HHD platter speed is your bottleneck unless multiple drives in a TB RAID 0 array. USB 3 is your next speed limit but you can’t hit it unless using an SSD. With TB, 6G is your limit for SSDs unless using multiples in a PCIe in a RAID 0 array. Be seated when you see the costs on those TB/PCIe extenders. You need fewer SSDs than HHDs to achieve the same speeds and SSDs will run much cooler with less fan noise.
What’s the benefit if your primary medium is audio? None that I know of. Commercial video is different—those users need the big guns.
My 2010 rig has a 3G SATA/eSATA limit. I’m good with it for now. A 2011 or later bumps me to 6G if I did nothing else. I’m looking at upgrading my 8 year old system to get more horsepower (cores) as I use more VIs. Speed is not my issue.
Your 6.1 has PCI speeds internally—OWC can bump this to 2 or 4T (not cheap). A single SSD in a TB dock gives you (theoretical) 6G transfer/streaming rate. A 2T WD Blue 3D or MX500 will set you back around $500 plus the cost of whatever TB dock you like. No need to go with the higher cost 850/860 EVO since it will never be your primary drive.
LASS full heresupersonic wrote:Even big orchestral libraries like the Hollywood, LASS, Spitfire etc?frankf wrote:I’ve done some ssd speed tests on our MacPro 6,1 Trashcan internal 1TB factory v external 1 TB 6g OWC in an OWC TB dock using Blackmagic. The internal drive is always faster but the external SSDs are certainly fast enough for sample streaming and audio
Frank Ferrucci
It should be pointed out that the internal SATA ports in 4,1 and 5,1 Mac Pros are SATA2, half as fast as the SATA3 interface current SATA SSDs ship with. Although the SATA3 drives are compatible with the Mac Pros's SATA sports, the potential for throttling does exist. It is my understanding that the max total combined throughput for all SATA ports is 600MB/sec on these Mac Pros.
In my rig, I have a bunch of SSDs. The newest, fastest ones (Samsung 850 and 860 EVO drives) are connected to a PCIe SATA3 card, an inexpensive one like this https://www.ebay.com/itm/PCI-E-Express- ... SwHUhaEMXT that maxes out at about 500MB/Sec due to it running at PCIe 1x slot speed.
No matter what they are attached to, all the SSDs work very well for audio, much faster than spinners. Like Mike, the only spinners I run now are Time Machine and Session Backup drives.
