Problem assigning foot pedal to start playback.
JLEpperson
Post by JLEpperson »
I'm using DP 9.51 for live performance with a band for backing tracks. I use a Focusrite 18i/20 interface with a novation keyboard connected. MIDI out from the Kybd to in on the interface and a foot pedal connected to the sustain port. In commands I select play toggle start/stop and press the foot pedal. It excepts and shows the command so I know DP is seeing the information coming from the kybd. Still, nothing happens when I hit the pedal. This has been working fine up until I changed computers and upgraded from 8 to 9.51. Any suggestions? Am I forgetting to do something in DP? Midisetup? Interface? Kybd?
JSmith1234567
Re: Problem assigning foot pedal to start playback.
Post by JSmith1234567 »
Have you checked if the Transport Masters section in the commands window is enabled?
OSX Big Sur (latest). Mac Pro Late 2013 ("trash-can"), 3.5 Ghz 6-Core Intel XeonE5, 64GB RAM. Motu DP 11.03, Vienna Pro Server, Presonus Notion, Osculator, Keyboard Maestro
JLEpperson
Yes transport and master are selected. I also tried it without the master selected.
Are you sure that the pedal is showing #64?
https://www.snoize.com/MIDIMonitor/
JLEpperson
Yes
JLEpperson
I tried to assign it to a key on the keyboard as well. Note shows in the commands but doesnt start playback.
Call MOTU and you will probably get a quick fix.
JLEpperson
It works if I assign it to just play. When play/toggle it plays for about quarter of a second then stops.
i did call motu and I was on hold for an hour. Finally got tired of waiting.
gseibert
Post by gseibert »
Have you tried using MidiMnitor to examine what the Novation actually produces? Is your pedal just a simple switch? Some sustain pedals actually are continuous controllers and not switches producing values of 127 or zero. Releasing the pedal may not produce a value zero and that confuses the process.
2020 iMac 10 core 32 g ram, Catalina, DP11.04, UA Apollo X4, MTP/av usb, Komplete Ultimate 13,Albion One, BBCSO Core, TX81Z, SPX90, Digitech Studio Quad v2, Tascam DA20 mkII, Alesis ADAT, Roland s750, Mackie line mixer, Korg Z1, Roland A80, DX7, Kurzweil K2500X, Kurzweil K2000R, Kurzweil PC3, Korg 168rc Event 20/20 bas, Mini-Moog, EMS Synthi aks
JLEpperson wrote:It works if I assign it to just play. When play/toggle it plays for about quarter of a second then stops.
Folks say a morning call is best.
