Hey All,
This is driving me crazy...livid...furious...
DP 9.51 and MachFive3, El Capitan:
I set my MachFive3 pans and volume levels and as soon as I hit the play transport they ALL reset to defaults. What the heck?
Thanks.
DP 9 and MAchFive3
- FMiguelez
Re: DP 9 and MAchFive3
it works fine here (same software versions as you). We need more details...
My first trouble-shooting step would be to make sure there is not some kind of hidden automation in your tracks.
This is a common problem that happens with VI's. I'm guessing you're setting the volume and pans in MachFive instead of in DP's mixer. Whenever you hit play, DP is sending the pan and volume fader position for the MIDI track targeting the VI. I'm not in front of DP right now, but the way to fix this is to go to the Track Overview and for each of your MIDI tracks that target the VI, double click the automation setup column, and then set the automation so that it set to "Only" and then not add any controllers. Either that or choose "All except" and add volume and pan. I'll need to go into the studio and launch DP so I can check the exact way to do it if you need more help.
Moving this topic to the Troubleshooting forum.
