I picked up an original 828 Fire Wire and my PC Laptop only has USB 3.0 ports.
Has anyone found a fire wire to USB adapter or an interface that was functional.
Im basically recording one track at a time so Latency should be such an issue. I was just wondering if it work at all with a USB port. I have received mixed information until this point and I may have to take my chances and experiment.
828 original Fire Wire to USB Interface ???
Re: 828 original Fire Wire to USB Interface ???
No.Has anyone found a fire wire to USB adapter or an interface that was functional.
You'll need an 828mk3 Hybrid, 828x or 828es to provide USB connectivity.
I emailed Dave at MOTU and according to him the 828 will connect to FW 400,FW 800, and Thunderbolt and Thunderbolt3 using the correct OEM Mac Adapters.
BTW the 828 will work with GarageBand.
The 828 will also connect to a PC with card slots running Win7,8,or 10 if I insert a FW 400 adapter card that uses a Texas Instruments controller chip. SIIG Brand controller cards have proven to be reliable.
I still want to find out if it will work at all using a FW to USB Interface with a dongle. I have to experiment with that one I guess. If the computer recognizes the console thru the interface I shouldn't get to much latency if bottlenecking became an issue at all. I am mostly just doing home recordings one track at a time.
You could be correct about the USB Ports however.
Just trying to narrow down my options here and see if I can get this 828 up and running. Technology 10 or 15 years ago was still better than anything the
Beatles had.
Thank you for responding I will heed your advice.
Beatles had.
I could have entitled the post "Can I connect 828 to a PC with USB ports"
Purchasing an older Mac Pro might be a good option that has built in FW or TB.
I read somewhere that a Mac can process Audio and Video 100x faster than a PC whether this is due to the infastructure of the Processor, the OS,or both.
Dave answered a question that you didn’t ask.
I answered your original question. Again, the answer is no.
Both of us are correct.
There is absolutely no way to hook up a FireWire only device to a USB port. Best case—it won’t work at all. Worst case—you’ll fry the unit, your motherboard or both.
I read somewhere that the earth is flat.dayogiman wrote:I read somewhere that a Mac can process Audio and Video 100x faster than a PC whether this is due to the infastructure of the Processor, the OS,or both.
Relative performance of macOS vs Windows aside, you can pick up older Mac Pros for very reasonable prices these days. Because audio is much less demanding than video, even an older Mac can perform very well, offering power of which the Beatles could only have dreamed. All Mac Pros except the latest (6,1 - Thunderbolt to Firewire adaptor will work) provide Firewire ports, although you may have to purchase a Firewire 800 to 400 converter cable to connect your 828. Recommended models of the Mac Pro are 4,1, 5,1 or 6,1.
