I may have to buy a new Mac (Yeuch) but I still use an older MOTU 896HD which uses Firewire exclusively.
How do the Thunderbolt -> FW adapters work for this?
Thanks,
Thunderbolt > Firewire adapters on older MOTU hardware?
-Todzilla
Huge sound generation & capture facilities
On the banks of the River Eno
__________________________________________________
DP 8!!!, OSX 10.7.3, 15" MacBook Pro w 16G RAM 256G SSD & 630GHD, MOTU 896HD, MX4, Komplete 8, Apogee Symphony I/O, Neumann U-89, pair of Peluso P12s, Seventh Circle & Demeter preamps, Lava lamp, stuffed frog playing bongos
Re: Thunderbolt > Firewire adapters on older MOTU hardware?
I'm using an Apple TB>FW adapter on a first generation Traveler with zero problems. I have been for years. The only caveat is that bus power is not reliable, but that is not an issue in your case.
TB passes a maximum of 7.7V bus power (and good luck getting that) while FW spec is 24V minimum. Apple battery powered laptops with FW supplied 9.8V bus power on one port only.cuttime wrote:I'm using an Apple TB>FW adapter on a first generation Traveler with zero problems. I have been for years. The only caveat is that bus power is not reliable, but that is not an issue in your case.
Thanks guys! Sounds like a non issue, as long as I can find my Focusrite Sapphire 14 wall adapter. It's for my Studio B.
-Todzilla
