Never let it be said that MOTU doesn't plan these things in accordance with the Universe!cuttime wrote:Funny, that's the same day Nibiru will make it's next planetary pass...MIDI Life Crisis wrote:Sept 15, 2019, 8:30AM, EST... or not.
Anyone know when DP 10 will be released?
Re: Anyone know when DP 10 will be released?
MIDI Life Crisis wrote:Never let it be said that MOTU doesn't plan these things in accordance with the Universe!cuttime wrote:Funny, that's the same day Nibiru will make it's next planetary pass...MIDI Life Crisis wrote:Sept 15, 2019, 8:30AM, EST... or not.
I read everybody's points. Thank you for your feedback.
If you are running on an SSD and upgrade to the current Mac OS, 7.24 will not run–even if already installed.
Any clue as to how a SSD affects that, Mike. Operating system I can understand. Is there other software that you know of with the same issue?
Philippe
Philippe
Judging by Motu's recent focus, probably have another 6 or 7 audio interfaces to release before DP10 hits.
Carlos
DP 9.5
Mac Pro Dual Quad Core 2.8Ghz
24GB Ram
OS 10.10.5 (Yosemite)
MOTU HD192
Carlos
DP 9.5
24GB Ram
MOTU HD192
Funny you should ask. I wondered if anyone would catch that.Phil O wrote:Any clue as to how a SSD affects that, Mike. Operating system I can understand. Is there other software that you know of with the same issue?
Philippe
Although DP 7.24 will no longer install after El Capitàn, it will run on a fusion drive or HHD over High Sierra. This is because APFS does not work on those drives and the installer will not try to update them. Likewise if booting from an SSD connected via USB 2 and updating the OS on that (can’t guarantee it but that’s what happened to me). 7.24 could read the CD and authorize by creating the hidden Authorization File it can use.
When I popped that drive into an eSATA dock, booted into it and reinstalled OS 10.13, the SSD was automatically updated to APFS and 7.24 could not create an Authorization file it could use — nor could it access the one I had already created. The CD was found and spun up but eventually wound down and the Authorization screen kept popping up blank again.
In both cases, I was using the same CD in the same drive and copying the license info from a text file I use for that purpose.
I have no doubt that there are other apps that have issues only if the drive is formatted APFS. I have not found any on my system that didn’t also fail in 10.13 when formatted HFS+ . Finale 2011 failed both ways, for example.
Good to know. As always, thank you, Mike.
Philippe
Philippe
- Gravity Jim
Yeah, because MOTU only has one engineer, and if he's working on interfaces, he can't work on DP.csavetman wrote:Judging by Motu's recent focus, probably have another 6 or 7 audio interfaces to release before DP10 hits.
Carlos
Or maybe, MOTU isn't a single entity, but a company that employs many people, some of whom are working on hardware projects and others working on software projects.
Now that I think of it, I'm pretty sure it's the latter.
Jim Bordner
Just upgraded to 9.5 from 7.24.
Preliminary test shows no issues and works well with Reason 9.5.
Thank you Motunation!
- Mr. Quimper
Hopefully not for a little while as I finally plunked down the cash for v9.
Finally moving from v6 to v9 was a pretty big leap...
2.5Ghz Quad-Core/20GB DDR3/10.11.6/DP 9.5
- corbo-billy
Just updated to version 10; I have a curious impression in terms of the pace of updates.
I'm having a problem with validation in VST3 format, I emit a Techlink.
Not even an answer; a felt opposite for me at the release of previous versions.
There are details ignored by the users but I find MOTU rather discreet and very silent.
Imac M1 24" under Monterey 12.7 & Kontakt 7.6. _ Fireface800 X 2 _ FilterBank2 Sherman & Gibson Explorer Pro _ MIDI Express XT _ Virus C Desktop _ Adrenalinn III & Voyager Moog _ SpeakerPhone 2 _ PolyEvolver Keyboard _ Tempest _ D.P. 11.22 _
