Hello
Is it possible to connect a non-USB (parallel port version in other words) MIDI Timepiece AV MTP to a late 2013 MacBook Pro (running macOS Sierra, 10.12.5)? The MBP pro has just USB and Thunderbolt connections. The native Intel version of Clockworks launches happily enough.
A quick Google tells me there are for example USB to parallel port adaptors but that's no gaurantee it'll work!
I got the MTP for nothing so don't really want to get rid of it and look for the USB version and it's still very useful to me in standalone mode as a digital MIDI patchbay, but it would be nice to take advantage of the features accessible only via software.
Jim
Connect non-USB MOTU MIDI Timepiece MTP AV to modern Mac
Re: Connect non-USB MOTU MIDI Timepiece MTP AV to modern Mac
Well I tried a cheap USB to DB25 adaptor ... well that's £5 and 5 minutes I'll never get back It didn't work, not hugely surprised tbh
There is only one way to do this. You can use it as an extender to an MTP-AV USB with firmware 2.0.1. You also need the correct serial cable to connect the two. No other way works.
Firmware 2.0.1 was the last version and is hard coded in the EPROM. Older versions will not work with Intel Macs. The firmware on the older MTP-AV doesn’t matter.
Thanks Mike
The other option of course is to find a (very) cheap laptop (Win or Mac) of the era and use that
You can also find 2.0.1 units on eBay. Make sure that the screen shot shows the correct firmware. I see sellers saying that 2.0.0 and earlier are “Mac compatible“ — PPC maybe but Intel, no. Tons on eBay right now but only one with the correct firmware for a $180 BIN. That’s what they’re going for these days.
MOTU used to sell upgrade chip sets for the USB but I bought one of the last in 2012. Frankly, I don’t use it anymore.
A serial Mac portable? Yikes — how old would hat have to be? Before the G3... and what OS and version of DP, 3.x or 4.1?
A Windows laptop with an RS 232 port running XP or Win 7 should be much, much easier to find and use.
