Interesting "one time only" success with BIAS Peak Pro 7
mhschmieder
Post by mhschmieder »
With much effort, I found a whole bunch of extra support files that I deleted, commissioned a new download of the installer at the BIAS website as it does seem to be hardware-locked, and launched Peak Pro 7 successfully after deciding to say "No" to configuring the audio preferences for the first time (it crashed any time I said "yes").
I was then able to have a normal session with an audio file using the editing capabilities of the app.
When I quite the app, it crashed with the error message I had been getting for many months now.
Does anyone have an idea how I can get rid of this problem, now that it's clear that it is something to do with it already having audio preferences set at startup time?
It only seems to successfully launch if there are no audio settings and one doesn't try to set them before launch.
But of course it stores them on shutdown.
Probably there is a prefs file that I can delete each time, but that is time-consuming. So maybe someone here has a clue now as to what the source problem actually is, and how to fix it.
Perhaps this is also the problem that is afflicting DSP-Quattro.
Maybe both apps are so old that they are crashing when trying to talk to the most recent updates to the RME Fireface UFX drivers -- though the crashes happen even if that interface is turned off and the computer's audio is set to internal audio.
Guitar Gaz
Re: Interesting "one time only" success with BIAS Peak Pro 7
Post by Guitar Gaz »
As you probably know I have been constantly posting about Bias Peak Pro 7 every time there is a Mac OSX update ever since Bias shut down - partly to prove it still works all these years later despite concerns by users and the need to switch to supported software.
It still works very well on my system - better than some earlier Mac OSX updates - strange. I always expect it to cease working but there it is all these years since it's "decline".
So I can report Bias Peak Pro 7 still works on my system - as does DSP Quattro. We have a similar setup so it must be something in your setup as the software and the OSX seem to work well.
What can I say without seeming to insult your own knowledge ? I presume you have trashed Bias Peak Pro 7 preferences? Then opened it again to start anew? This will remove all your colour preferences etc but may work.
Do you have previously saved files edited in Bias Peak Pro 7? Opening those by double click may trigger a previous preference setup.
Have you tried removing all your plugins (especially VST ones) as there may be a clash with a particular plugin and Bias Peak Pro 7 looks for plugins. You could temporarily store them somewhere else and then startup again and try and open Bias Peak Pro 7. Plugins may be the problem as this is likely to be a big difference between our own setups.
Lastly you could try and download a new version/update from the link below.
http://www.bias-inc.com/downloads/updates/
There is no reason Bias Peak Pro 7 should not work - so VST plugins may be the main suspects. Good luck and keep us posted.
Gary Shepherd
____________
mhschmieder
Yep, I've done all of that multiple times. Like I said though, this final time worked, until quitting the session. So it's clearly nothing to do with the actual installation, the OS, hardware, etc.
I will look at RME's website later today to see if they have new drivers. I had other issues with the previous driver updates and suspect this is where the problems are. Trashing my VST's helped Cubase but not Peak or DSP-Quattro.
mhschmieder
Curiouser and curiouser. There is definitely some sort of conflict on my system, but I can't tell what it is. The evidence is quite clear, but I'm not a Mac developer per se so don't know OS-level stuff (beyond Unix, which I know quite well).
The regular plist file is of course not at fault, as it only has a couple of items related to last viewed directory. And quitting a successful launch without even editing a file also crashes on exit, and then again on restart.
Although I had started trashing this file as well last night (I had to decide where to back it up first, in case it was critical and non-recoverable), the problematic file is created at launch, or at exit (if you say "no" to auto-configure Audio/MIDI during launch).
Under the user account's preferences folder, adjacent the regular plist file is a folder "com.bias-inc.peak" which includes just one file: "ACA P7 Preferences" (no file suffix).
THAT is the file that causes the crash, and furthermore, it is also the reason DSP-Quattro won't launch, for some bizarre reason that I can't comprehend since they are different vendors!
If I double-click the file to try to auto-discover what app can open it, I get the same error message that DSP-Quattro gets on launch, with the DSP-Quattro logo, even though this file is in the BIAS Peak preferences folder!
"Error: It is impossible to assign this folder for New Audio files. Please check if it exists on disk".
This is because that file has somehow auto-associated with DSP-Quattro and tries to launch it. So I think there is some conflict between DSP-Quattro and BIAS Peak Pro 7 on my system, with some shared Audio/MIDI components or files.
At this point, ALL of my VST folders are 100% quarrantined, and I just updated my RME Fireface UFX driver to 3.0.3 which was released on 3 July 2017. I have also rebooted twice.
I'll cut/paste one of the crash logs in another post. They're exactly the same each time, so it doesn't matter which one I show. This is where I have next to no abilities on the Mac, even after lots of studying and analysis of the log. It does look, however, that the problem is related to QuickTime.
mhschmieder
Process: Peak Pro 7 [654]
Path: /Applications/Peak Pro 7.app/Contents/MacOS/Peak Pro 7
Identifier: com.bias-inc.peak
Version: 7.0.3 (7.0.3)
Build Info: Peak Pro-24813~7
Code Type: X86 (Native)
Parent Process: ??? [1]
Responsible: Peak Pro 7 [654]
User ID: 501
Date/Time: 2017-07-10 10:47:32.135 -0700
OS Version: Mac OS X 10.12.5 (16F2073)
Report Version: 12
Anonymous UUID: E5BD3B70-AE07-E5FA-7EEA-98AA7DBE32BC
Time Awake Since Boot: 780 seconds
System Integrity Protection: enabled
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Exception Type: EXC_BAD_ACCESS (SIGSEGV)
Exception Codes: KERN_INVALID_ADDRESS at 0x000000003f800000
Exception Note: EXC_CORPSE_NOTIFY
Termination Signal: Segmentation fault: 11
Termination Reason: Namespace SIGNAL, Code 0xb
Terminating Process: exc handler [0]
VM Regions Near 0x3f800000:
__LINKEDIT 0000000010f1e000-0000000010f25000 [ 28K] r--/rwx SM=COW /Applications/Peak Pro 7.app/Contents/PlugIns/CoreAudio.bundle/Contents/MacOS/CoreAudio
Submap 0000000090000000-00000000a5600000 [342.0M] r--/rwx SM=SHM machine-wide VM submap
Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
0 com.apple.CoreFoundation 0x941feba5 CFStringCompare + 21
1 com.bias-inc.coreaudio 0x10f08e6d AsioCoreAudio::FillInAudioDeviceInfo(AudioDeviceInfo*) + 2731
2 com.bias-inc.coreaudio 0x10f0cd4c AsioCoreAudio::ReadPrefs() + 920
3 com.bias-inc.coreaudio 0x10f0cfb5 AsioCoreAudio::init(void*) + 33
4 com.bias-inc.coreaudio 0x10f074d7 ASIOInit + 200
5 com.bias-inc.peak 0x00122f9e TagLib::List<TagLib::FileRef::FileTypeResolver const*>::List() + 1142142
6 com.bias-inc.peak 0x0008b6b9 TagLib::List<TagLib::FileRef::FileTypeResolver const*>::List() + 521369
7 com.bias-inc.peak 0x000b3456 TagLib::List<TagLib::FileRef::FileTypeResolver const*>::List() + 684598
8 com.bias-inc.peak 0x000103fa TagLib::List<TagLib::FileRef::FileTypeResolver const*>::List() + 16858
Thread 1:
0 libsystem_kernel.dylib 0xa1659cba __workq_kernreturn + 10
1 libsystem_pthread.dylib 0xa173cd06 _pthread_wqthread + 1210
2 libsystem_pthread.dylib 0xa173c826 start_wqthread + 34
Thread 2:
1 libsystem_pthread.dylib 0xa173cb95 _pthread_wqthread + 841
Thread 3:
Thread 4:
0 libsystem_kernel.dylib 0xa165191e mach_msg_trap + 10
1 libsystem_kernel.dylib 0xa1650e93 mach_msg + 51
2 com.apple.CoreFoundation 0x94262276 __CFRunLoopServiceMachPort + 214
3 com.apple.CoreFoundation 0x942616a8 __CFRunLoopRun + 1576
4 com.apple.CoreFoundation 0x94260e1a CFRunLoopRunSpecific + 506
5 com.apple.CoreFoundation 0x942a2511 CFRunLoopRun + 129
6 com.bias-inc.peak 0x002de325 TagLib::RIFF::File::FilePrivate::~FilePrivate() + 62117
7 com.apple.CoreServices.CarbonCore 0x951a4b72 PrivateMPEntryPoint + 51
8 libsystem_pthread.dylib 0xa173d047 _pthread_body + 184
9 libsystem_pthread.dylib 0xa173cf8f _pthread_start + 243
10 libsystem_pthread.dylib 0xa173c84a thread_start + 34
Thread 5:: com.apple.CFSocket.private
0 libsystem_kernel.dylib 0xa165964a __select + 10
1 com.apple.CoreFoundation 0x9429eaf1 __CFSocketManager + 865
2 libsystem_pthread.dylib 0xa173d047 _pthread_body + 184
3 libsystem_pthread.dylib 0xa173cf8f _pthread_start + 243
4 libsystem_pthread.dylib 0xa173c84a thread_start + 34
Thread 6:
0 libsystem_kernel.dylib 0xa1651972 semaphore_timedwait_trap + 10
1 libdispatch.dylib 0xa1510ca8 _os_semaphore_timedwait + 95
2 libdispatch.dylib 0xa1500eb1 _dispatch_semaphore_wait_slow + 76
3 libdispatch.dylib 0xa1500e5c dispatch_semaphore_wait + 35
4 libdispatch.dylib 0xa14fb790 _dispatch_worker_thread + 238
5 libsystem_pthread.dylib 0xa173d047 _pthread_body + 184
6 libsystem_pthread.dylib 0xa173cf8f _pthread_start + 243
7 libsystem_pthread.dylib 0xa173c84a thread_start + 34
Thread 0 crashed with X86 Thread State (32-bit):
eax: 0xbfffe378 ebx: 0x10f083d3 ecx: 0x00000006 edx: 0x10f1c37c
edi: 0x941feb9e esi: 0x3f800000 ebp: 0xbfffe068 esp: 0xbfffe040
ss: 0x00000023 efl: 0x00010282 eip: 0x941feba5 cs: 0x0000001b
ds: 0x00000023 es: 0x00000023 fs: 0x00000000 gs: 0x0000000f
cr2: 0x3f800000
Logical CPU: 1
Error Code: 0x00000004
Trap Number: 14
Binary Images:
0x1000 - 0x373ffb +com.bias-inc.peak (7.0.3 - 7.0.3) <0A8EB9EA-D30B-377D-5CC8-01D65A1FB242> /Applications/Peak Pro 7.app/Contents/MacOS/Peak Pro 7
0x49f000 - 0x4d9a93 dyld (433.5) <96ACA788-B094-3081-ACE1-7CF125D4C435> /usr/lib/dyld
0x518000 - 0x556ffb com.apple.audio.MIDI.CoreMIDI (1.10 - 88) <CE948963-3D58-3AAB-BB7D-74B57672DFF5> /System/Library/Frameworks/CoreMIDI.framework/Versions/A/CoreMIDI
0x57c000 - 0x5a0fff com.apple.DiscRecordingUI (9.0.3 - 9030.4.5) <0A872902-C19D-3B9D-9F8F-979E2B06E38E> /System/Library/Frameworks/DiscRecordingUI.framework/Versions/A/DiscRecordingUI
0x5ba000 - 0x5fdfdb com.apple.DotMacKit (1.2) /Applications/Peak Pro 7.app/Contents/Frameworks/DotMacKit.framework/Versions/A/DotMacKit
0x62a000 - 0x62cfc8 +com.yourcompany.yourcocoaframework (1.0) /Applications/Peak Pro 7.app/Contents/Frameworks/ogg.framework/Versions/A/ogg
0x630000 - 0x64efef +com.yourcompany.yourcocoaframework (1.0) /Applications/Peak Pro 7.app/Contents/Frameworks/FLAC.framework/Versions/A/FLAC
0x65a000 - 0x670ffb libexpat.1.dylib (15) <07256ED1-AF86-3542-935E-41A2A3065B70> /usr/lib/libexpat.1.dylib
0x6dc2000 - 0x6dc2ff7 + (???) <33915D75-07FD-EC06-35F2-D09A745222B6>
0x721b000 - 0x72e6ffb com.apple.AMDRadeonX4000GLDriver (1.51.8 - 1.5.1) <1973E9A0-78B0-3FF8-A018-75734AA7D823> /System/Library/Extensions/AMDRadeonX4000GLDriver.bundle/Contents/MacOS/AMDRadeonX4000GLDriver
0x8000000 - 0x85d6ff7 ATIRadeonX4000SCLib.dylib (1.51.8.1) <B93875A0-CA71-30A8-B944-7ED1188ECE07> /System/Library/Extensions/AMDRadeonX4000GLDriver.bundle/Contents/MacOS/ATIRadeonX4000SCLib.dylib
0xbbeb000 - 0xbc23ff7 com.apple.QuickTimeFireWireDV.component (7.7.3 - 2978.7) <BEEBE36E-5F50-31AF-ACAE-8223421817DA> /System/Library/QuickTime/QuickTimeFireWireDV.component/Contents/MacOS/QuickTimeFireWireDV
0xbc30000 - 0xbc4aff3 com.apple.AppleIntermediateCodec (2.0.4 - 8967.51) <49677895-E16C-3DE5-9CBA-EC00FD0915C3> /Library/QuickTime/AppleIntermediateCodec.component/Contents/MacOS/AppleIntermediateCodec
0xbc51000 - 0xbc55fff com.apple.AppleMPEG2Codec (1.0.2 - 220.1) <2DB75750-76BD-328E-A473-B705BFD97474> /Library/QuickTime/AppleMPEG2Codec.component/Contents/MacOS/AppleMPEG2Codec
0xe5a8000 - 0xe662fab com.apple.AppleProResDecoder (3.0.9 - 9011.51.1) <360488E6-3895-3D3E-97D4-5B5E3665602C> /System/Library/QuickTime/AppleProResDecoder.component/Contents/MacOS/AppleProResDecoder
0xe669000 - 0xe6aaff7 com.apple.AppleVAH264HW.component (3.0 - 3.0) <91FE7568-F898-3893-9E26-FB359C0682D2> /System/Library/QuickTime/AppleVAH264HW.component/Contents/MacOS/AppleVAH264HW
0xe76f000 - 0xe790ff3 com.apple.applepixletvideo (1.2.31 - 1.2d31) <D3BDA1B9-976F-3CC5-84B3-C2FF5C227E9D> /System/Library/QuickTime/ApplePixletVideo.component/Contents/MacOS/ApplePixletVideo
0x107b8000 - 0x107bcfff com.apple.audio.AppleHDAHALPlugIn (279.48 - 279.48) <7EB9BC44-FC8B-3EEA-B4F9-F2C388FEEB52> /System/Library/Extensions/AppleHDA.kext/Contents/PlugIns/AppleHDAHALPlugIn.bundle/Contents/MacOS/AppleHDAHALPlugIn
0x10d00000 - 0x10e81ff3 com.apple.audio.units.Components (1.14 - 1.14) <F8D7F8F3-5F25-37E2-86B2-A37997A1F14A> /System/Library/Components/CoreAudio.component/Contents/MacOS/CoreAudio
0x10f06000 - 0x10f1bffb +com.bias-inc.coreaudio (1.0 - 1.0) <EC3F7503-36F9-5137-6DA3-8D7603C18394> /Applications/Peak Pro 7.app/Contents/PlugIns/CoreAudio.bundle/Contents/MacOS/CoreAudio
0x90028000 - 0x90387ffb com.apple.RawCamera.bundle (7.03 - 912) <234F78C8-222C-38F3-B2FD-5F03EE1D0146> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
0x90caa000 - 0x90cb0fff com.apple.agl (3.3.1 - AGL-3.3.1) <1847F191-5ADA-3D73-9FA3-45CCFD50F262> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
0x90cb1000 - 0x90e58ff7 com.apple.avfoundation (2.0 - 1187.36) <0DA1741A-8E5A-3333-9AA9-AD0AFBA42C82> /System/Library/Frameworks/AVFoundation.framework/Versions/A/AVFoundation
0x90e59000 - 0x90effffb com.apple.audio.AVFAudio (1.0 - ???) <B036C6FC-A3D0-30D3-9620-30D16A149C9F> /System/Library/Frameworks/AVFoundation.framework/Versions/A/Frameworks/AVFAudio.framework/Versions/A/AVFAudio
0x90f00000 - 0x90f00fff com.apple.Accelerate (1.11 - Accelerate 1.11) <42196E3D-3125-3671-B4C8-FDAACA38BE3A> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
0x90f01000 - 0x90f18ff3 libCGInterfaces.dylib (331.5) <FEBA4BB0-463D-3124-A55D-FA57FBC223CA> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/Libraries/libCGInterfaces.dylib
0x90f19000 - 0x9157ffe7 com.apple.vImage (8.1 - ???) <7B0881AC-2D51-3B61-9E9F-A5BF61626B13> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
0x91580000 - 0x916ccff7 libBLAS.dylib (1185.50.4) <9CAD50C4-501C-36D9-9145-B04B70C0E1A0> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
0x916cd000 - 0x916dfffb libBNNS.dylib (15) <B0298D30-EC0B-340E-B7AB-906D9DC7D56F> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBNNS.dylib
0x916e0000 - 0x91a7bfff libLAPACK.dylib (1185.50.4) <346C2F05-E331-3B29-A0CE-9269D8506E40> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
0x91a7c000 - 0x91a92ff7 libLinearAlgebra.dylib (1185.50.4) <CE633CC2-8976-3E6E-895F-86C97344B5FE> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLinearAlgebra.dylib
0x91a93000 - 0x91aadff7 libSparseBLAS.dylib (1185.50.4) <4042DA23-23A7-3BD2-8AB7-9D115D8082D0> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libSparseBLAS.dylib
0x91aae000 - 0x91bfbfeb libvDSP.dylib (600.60.1) <4B55C10A-7F0D-3DEB-9F28-E31507D4141E> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
0x91bfc000 - 0x91cddff3 libvMisc.dylib (600.60.1) <C78A84D7-0982-30A7-895E-0803817713E4> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
0x91cde000 - 0x91cdefff com.apple.Accelerate.vecLib (3.11 - vecLib 3.11) <D5151762-CC10-3F99-B162-37819816A331> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
0x91cdf000 - 0x91f40ff7 com.apple.AddressBook.framework (10.0 - 1756.20) <91834D4E-0171-36F0-BF79-3353DE4DB9CF> /System/Library/Frameworks/AddressBook.framework/Versions/A/AddressBook
0x91f41000 - 0x92ca5fff com.apple.AppKit (6.9 - 1504.83.101) <11FEBC5C-5A04-3ACC-94EE-9BEE77F606DF> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x92cb7000 - 0x92cb7fff com.apple.ApplicationServices (48 - 48) <5E01C894-F1DA-3F91-B69D-7BF59902E3CB> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
0x92cb8000 - 0x92d26fff com.apple.ApplicationServices.ATS (377 - 422.2) <99C0615C-08A5-3BAE-92AB-58E5F1041505> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
0x92dbf000 - 0x92eedfff libFontParser.dylib (194.12) <C211A6FD-569D-3B42-A6A8-D9E8AB579D46> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib
0x92eee000 - 0x92f3aff3 libFontRegistry.dylib (196.4) <A1D44EE8-95AB-3C75-913F-20619767BC3F> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
0x92f3b000 - 0x92f6eff3 libTrueTypeScaler.dylib (194.12) <785EE917-A09E-3C1C-A7BC-567744CF7A41> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libTrueTypeScaler.dylib
0x92f6f000 - 0x92fdaff3 libType1Scaler.dylib (130.2) <767AEBF6-3A3B-3CBC-80A3-5781FDC601E6> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libType1Scaler.dylib
0x92fdb000 - 0x9308bffb com.apple.ColorSync (4.12.0 - 502.2) <17F3BA77-6DF6-3289-B400-558E31AF8013> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync
0x9308c000 - 0x930e3fff com.apple.HIServices (1.22 - 592.1) <C5EA04CF-E250-361C-8C88-65D87A7845C8> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
0x930e4000 - 0x930f3ff7 com.apple.LangAnalysis (1.7.0 - 1.7.0) <86FEA0B2-0308-3C26-971C-C8C1640BFAA2> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
0x930f4000 - 0x9314cffb com.apple.print.framework.PrintCore (12 - 491) <8870E9A1-E705-3DA5-AA14-6184A38AD39A> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
0x9314d000 - 0x931e7ff3 com.apple.QD (3.12 - 313) <DE1DE23A-B209-3B99-9001-8C21CA3C09E1> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
0x931e8000 - 0x931f4ff3 com.apple.speech.synthesis.framework (6.6.2 - 6.6.2) <D5D87F3A-3105-34F1-82B9-59E8CE4E9D49> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
0x931f5000 - 0x933e3ff3 com.apple.audio.toolbox.AudioToolbox (1.14 - 1.14) <8751F84D-9369-3550-B218-1A1FC7C6CE4D> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
0x933e4000 - 0x933e4fff com.apple.audio.units.AudioUnit (1.14 - 1.14) <B07973BD-48BB-38F1-A65C-09222DF4E52C> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
0x93546000 - 0x93901fff com.apple.CFNetwork (811.5.4 - 811.5.4) <70AF1C6F-AA9C-3A8E-A766-02656438A94D> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
0x9391b000 - 0x9391bfff com.apple.Carbon (154 - 157) <2574F3CF-9950-3D38-B3D9-55339C9076B8> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
0x9391c000 - 0x93925ff3 com.apple.audio.SoundManager (4.2 - 4.2) <3CE4F1DF-6E04-35FE-834C-F6F547C6EB49> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CarbonSound.framework/Versions/A/CarbonSound
0x93926000 - 0x9392aff3 com.apple.CommonPanels (1.2.6 - 98) <774D72F5-E2A7-3D41-B9F0-A3B304EA1EF8> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
0x9392b000 - 0x93cc9ff3 com.apple.HIToolbox (2.1.1 - 857.8) <9D2D0E38-1BF5-36F3-A1F9-131A2E1F0038> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x93cca000 - 0x93d1dff3 com.apple.htmlrendering (77 - 1.1.4) <63E24D19-37E0-3168-9044-F03FD48443EE> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HTMLRendering.framework/Versions/A/HTMLRendering
0x93d1e000 - 0x93d21fff com.apple.help (1.3.5 - 49) <26817567-717B-3837-904B-B8B2E9DC937C> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
0x93d22000 - 0x93d27ffb com.apple.ImageCapture (9.0 - 9.0) <4E6D02A0-3146-3DA8-B089-F77D79E872EA> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
0x93d28000 - 0x93dc7fff com.apple.ink.framework (10.9 - 219) <44F4216A-0167-36D2-97D1-7ACF37620D24> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
0x93dc8000 - 0x93e03fff com.apple.NavigationServices (3.8 - 225) <0C2FBA44-C5C4-3AEC-B863-465F9023C147> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/NavigationServices.framework/Versions/A/NavigationServices
0x93e04000 - 0x93e20ffb com.apple.openscripting (1.7 - 172) <50B7261F-3666-38E5-9824-F996426417C2> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
0x93e21000 - 0x93e26ff3 com.apple.print.framework.Print (12 - 267) <73DDC3C0-6D10-3464-B408-4A8D03674987> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
0x93e27000 - 0x93e29fff com.apple.securityhi (9.0 - 55006) <BDCED392-5DF4-36ED-A4CA-3028C1C08A65> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
0x93e2a000 - 0x93e30ff3 com.apple.speech.recognition.framework (6.0.1 - 6.0.1) <C97F9B27-4461-37B3-AAD2-8A76B9E375BE> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
0x93e31000 - 0x93e31fff com.apple.Cocoa (6.11 - 22) <7ED9CC12-AF69-384E-98FF-6CA850B8C8D0> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
0x93e3f000 - 0x93ed5ff3 com.apple.audio.CoreAudio (4.3.0 - 4.3.0) <D03A971D-6EEE-3D03-8D7F-729AB9F347FE> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
0x93ed6000 - 0x93ee8ffb com.apple.CoreBluetooth (1.0 - 1) <3FA355A2-A9A5-3787-BA8F-9245F9BB5880> /System/Library/Frameworks/CoreBluetooth.framework/Versions/A/CoreBluetooth
0x93ee9000 - 0x941d4fff com.apple.CoreData (120 - 754.2) <C194ADF9-DC92-38FA-B078-E52AD65B9618> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
0x941d5000 - 0x941dbfff com.apple.CoreDisplay (1.0 - 1) <67BBAE34-DB8B-3B29-B5C1-550093C058C6> /System/Library/Frameworks/CoreDisplay.framework/Versions/A/CoreDisplay
0x941dc000 - 0x9467cfff com.apple.CoreFoundation (6.9 - 1349.8) <4E5D12EC-C5E7-3DD9-AFE7-CBE1CAE3C153> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x9467d000 - 0x94d25ff3 com.apple.CoreGraphics (2.0 - 1070.22) <D75DB825-B5CD-3415-A339-56119F7C7CF9> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
0x94d26000 - 0x94f5cff3 com.apple.CoreImage (12.4.0 - 451.4.9) <113256F2-0EA3-377E-95CF-E0E9D760EEB8> /System/Library/Frameworks/CoreImage.framework/Versions/A/CoreImage
0x94fcd000 - 0x9507afff com.apple.CoreMedia (1.0 - 1907.59.1.5) <1DBEAA20-1DCC-38A2-AD86-7D57731D12C9> /System/Library/Frameworks/CoreMedia.framework/Versions/A/CoreMedia
0x9507b000 - 0x950caff3 com.apple.CoreMediaIO (805.0 - 4932) <902F0FF2-625B-316E-B5A2-5CDAEFA7511A> /System/Library/Frameworks/CoreMediaIO.framework/Versions/A/CoreMediaIO
0x950cb000 - 0x950cbfff com.apple.CoreServices (775.19 - 775.19) <11C45C1C-C281-33BC-95AA-1EADAC0DFC31> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
0x950cc000 - 0x9511effb com.apple.AE (712.5 - 712.5) <0BDA9D80-3698-39DB-B481-465DE086373F> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
0x9511f000 - 0x95400fff com.apple.CoreServices.CarbonCore (1159.6 - 1159.6) <AA015A43-6E6B-3847-B038-F2A7DB7C118F> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
0x95401000 - 0x95434ffb com.apple.DictionaryServices (1.2 - 274) <CC6AA628-EB43-3B3A-8AE6-805EE2002FF8> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
0x95435000 - 0x9543cfff com.apple.CoreServices.FSEvents (1230.50.1 - 1230.50.1) <7A90D2ED-0691-3B19-8262-7A75D4EFF3C0> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/FSEvents.framework/Versions/A/FSEvents
0x9543d000 - 0x95561ffb com.apple.LaunchServices (775.19 - 775.19) <035E7791-CA95-3F26-9D58-579C70F3023E> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
0x95562000 - 0x95610fff com.apple.Metadata (10.7.0 - 1075.40) <F6A4BEB4-C98D-3076-8039-AD329169EAD8> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
0x95611000 - 0x95671ff3 com.apple.CoreServices.OSServices (775.19 - 775.19) <F7BAB792-64B8-3495-B75A-B281D6216363> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
0x95672000 - 0x956e3fff com.apple.SearchKit (1.4.0 - 1.4.0) <B24493AC-5CF8-350F-849F-AFC86626B6AB> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
0x956e4000 - 0x95729ffb com.apple.coreservices.SharedFileList (38 - 38) <4E430C06-0D25-3C59-8932-C473601076B9> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SharedFileList.framework/Versions/A/SharedFileList
0x9572a000 - 0x9586efff com.apple.CoreText (352.0 - 544.15) <A928083F-A0C7-31BE-9617-A6AC5F3B559F> /System/Library/Frameworks/CoreText.framework/Versions/A/CoreText
0x9586f000 - 0x958a6ffb com.apple.CoreVideo (1.8 - 235.3) <8D6170FA-8A23-3688-93BF-0064515862D9> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
0x958a7000 - 0x95916ff3 com.apple.framework.CoreWLAN (11.0 - 1200.31) <5E2612E8-897C-36BB-A0E7-56B4483CA0BB> /System/Library/Frameworks/CoreWLAN.framework/Versions/A/CoreWLAN
0x95917000 - 0x95921fff com.apple.DirectoryService.Framework (10.12 - 194) <1AAC216E-80C8-3760-8312-2D9E4FF19AAB> /System/Library/Frameworks/DirectoryService.framework/Versions/A/DirectoryService
0x95922000 - 0x959e4fff com.apple.DiscRecording (9.0.3 - 9030.4.5) <62B66AD1-363A-3884-8BE4-CD8F0986C826> /System/Library/Frameworks/DiscRecording.framework/Versions/A/DiscRecording
0x959e5000 - 0x959eeff7 com.apple.DiskArbitration (2.7 - 2.7) <B1FDBE67-397D-3AE2-A616-B9FACD873428> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
0x959f2000 - 0x95d5eff3 com.apple.Foundation (6.9 - 1349.81) <229460F0-E144-3540-8E78-359292A57C40> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x95d5f000 - 0x95d8fff3 com.apple.GSS (4.0 - 2.0) <256987F7-ACFC-34B6-92E6-8E38E7B54482> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
0x95d91000 - 0x95e33ffb com.apple.Bluetooth (5.0.4 - 5.0.4f18) <86541C4F-3B8E-3335-98CA-589A5E922047> /System/Library/Frameworks/IOBluetooth.framework/Versions/A/IOBluetooth
0x95e34000 - 0x95ecffff com.apple.framework.IOKit (2.0.2 - 1324.60.3) <74A80D3B-7F93-32A4-B42D-451B3ED3495F> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x95ed0000 - 0x95ed6fff com.apple.IOSurface (159.7 - 159.7) <A981CAE2-6E1A-3D65-ACEC-4CC766DE51CC> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
0x95ed7000 - 0x95f29ff7 com.apple.ImageCaptureCore (7.0 - 7.0) <2141E4FE-0875-39BE-9950-9A4D4B74BF86> /System/Library/Frameworks/ImageCaptureCore.framework/Versions/A/ImageCaptureCore
0x95f2a000 - 0x9608dffb com.apple.ImageIO.framework (3.3.0 - 1599.10.2) <24A0651C-FE33-31E6-8A9D-80D389C201B1> /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO
0x9608e000 - 0x96091ffb libGIF.dylib (1599.10.2) <A91D96AE-8197-3F58-9B94-CC786DAF5E48> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
0x96092000 - 0x9618aff3 libJP2.dylib (1599.10.2) <370147CD-E954-38A8-B0B8-91C8A962D8B5> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
0x9618b000 - 0x961aeff7 libJPEG.dylib (1599.10.2) <0F9B7E00-FBA8-3644-A250-459D5FFE73C6> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
0x961af000 - 0x961d5ff3 libPng.dylib (1599.10.2) <D7557A23-0F23-38A3-9D68-8298107F100F> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
0x961d6000 - 0x961d8ffb libRadiance.dylib (1599.10.2) <BE58DE47-534D-3C6E-9474-F2481B4D81D3> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
0x961d9000 - 0x96224ffb libTIFF.dylib (1599.10.2) <E4AA8DCA-A7B9-32E6-9AB5-50186F5AE6E3> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
0x96228000 - 0x96a38ff7 com.apple.JavaScriptCore (12603 - 12603.2.4) <EC92C230-2F13-302B-84FC-4584822A3550> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
0x96a39000 - 0x96a51fff com.apple.Kerberos (3.0 - 1) <B97BE0B5-7B7E-377F-BE18-F6CE7B835375> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
0x96a52000 - 0x96a86fff com.apple.LDAPFramework (2.4.28 - 194.5) <8A4F1E19-8C3D-3EF7-B59C-3C1AB46B7BB9> /System/Library/Frameworks/LDAP.framework/Versions/A/LDAP
0x96aab000 - 0x96ab2fff com.apple.MediaAccessibility (1.0 - 97.1.1) <2C902DF8-E57A-37E3-891B-736B16AE074C> /System/Library/Frameworks/MediaAccessibility.framework/Versions/A/MediaAccessibility
0x96ab3000 - 0x96ff9fff com.apple.MediaToolbox (1.0 - 1907.59.1.5) <7840519A-A394-3538-95EF-4D4C83B88D07> /System/Library/Frameworks/MediaToolbox.framework/Versions/A/MediaToolbox
0x96ffa000 - 0x9704fffb com.apple.Metal (87.18 - 87.18) <C7057E59-EC34-3313-8E01-A8F694995F25> /System/Library/Frameworks/Metal.framework/Versions/A/Metal
0x97050000 - 0x97058fff com.apple.NetFS (6.0 - 4.0) <E8D6B0D9-E100-31EA-9C2D-39C118D77AC8> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
0x970bc000 - 0x970c4ff7 libcldcpuengine.dylib (2.8.5) <B519FE3A-E675-38A7-8CD2-BFA6D25205CC> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/libcldcpuengine.dylib
0x97298000 - 0x972e4fff com.apple.opencl (2.8.6 - 2.8.6) <408DB459-B41E-3FEB-9B9A-434811992B96> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
0x972e5000 - 0x972fefff com.apple.CFOpenDirectory (10.12 - 194) <FABB4E0C-9103-3F42-B4D8-DC796B239268> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
0x972ff000 - 0x9730afff com.apple.OpenDirectory (10.12 - 194) <43B21203-FF03-348A-A231-FB7BE6F1B025> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
0x9730b000 - 0x9730dfff libCVMSPluginSupport.dylib (14.0.16) <4D225D40-A98F-3E2B-8B86-7216F0F7F795> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dylib
0x9730e000 - 0x97311fff libCoreFSCache.dylib (156.3) <9AA959E0-5172-392C-862D-45EF56888363> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreFSCache.dylib
0x97312000 - 0x97316fff libCoreVMClient.dylib (156.3) <81A24375-7B31-3751-AB8F-A98D7D7F8B42> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
0x97317000 - 0x97320ff7 libGFXShared.dylib (14.0.16) <497A8F4C-2151-3EBA-AB95-46AD9A33FE05> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
0x97321000 - 0x9732dfff libGL.dylib (14.0.16) <8891E9DF-B56B-306C-BA23-06AA4039199E> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
0x9732e000 - 0x9736bfeb libGLImage.dylib (14.0.16) <C93D675E-B7BF-3819-A921-2F21DBC42746> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
0x9736c000 - 0x974f0ff7 libGLProgrammability.dylib (14.0.16) <859B83F8-AD57-3577-8DF3-56381F716C0C> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dylib
0x974f1000 - 0x97535fff libGLU.dylib (14.0.16) <49E3E4E8-EE7B-33C6-A54A-A616198A1BE8> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
0x97f04000 - 0x97f12fff com.apple.opengl (14.0.16 - 14.0.16) <D7899AAA-A0B5-39F1-81BE-2E69D5AF6D55> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
0x97f13000 - 0x980afffb GLEngine (14.0.16) <11A26FEF-3125-36EB-B3EE-0AF7BA156583> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLEngine.bundle/GLEngine
0x980b0000 - 0x980dcff7 GLRendererFloat (14.0.16) <FC394056-FD68-3735-B42B-DB6502CB2815> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLRendererFloat.bundle/GLRendererFloat
0x98110000 - 0x98262ff3 com.apple.QTKit (7.7.3 - 2978.7) <4DD9AD2F-1520-3749-A1D9-97D925899A01> /System/Library/Frameworks/QTKit.framework/Versions/A/QTKit
0x98263000 - 0x984bcff3 com.apple.imageKit (3.0 - 1023) <FD017807-7234-3633-9B06-AD7681F4F6D3> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/ImageKit.framework/Versions/A/ImageKit
0x984bd000 - 0x9857ffff com.apple.PDFKit (1.0 - 1) <F840178D-4C29-3EE1-A71B-9741E7BFB7BD> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/PDFKit.framework/Versions/A/PDFKit
0x98580000 - 0x98aaaff7 com.apple.QuartzComposer (5.1 - 356) <B6982296-C740-3751-9567-CE417DDB4D21> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzComposer.framework/Versions/A/QuartzComposer
0x98aab000 - 0x98acdff7 com.apple.quartzfilters (1.10.0 - 1.10.0) <6AAC63BE-A4DD-3ED8-943C-8EA524802E8B> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzFilters.framework/Versions/A/QuartzFilters
0x98ace000 - 0x98bb1ff7 com.apple.QuickLookUIFramework (5.0 - 720.7) <7344A4D1-6D43-32F1-9C65-F6302C2D7B9E> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuickLookUI.framework/Versions/A/QuickLookUI
0x98bb2000 - 0x98bb2fff com.apple.quartzframework (1.5 - 21) <7F5010C4-576C-387F-8EB7-BDA0A0915526> /System/Library/Frameworks/Quartz.framework/Versions/A/Quartz
0x98bb3000 - 0x98db4ff7 com.apple.QuartzCore (1.11 - 453.39.3) <326D7A97-1AD7-38CC-948B-95847ED7764A> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
0x98db5000 - 0x98e07ffb com.apple.QuickLookFramework (5.0 - 720.7) <810116E2-8AE9-37A6-93A5-51247C3FCE4C> /System/Library/Frameworks/QuickLook.framework/Versions/A/QuickLook
0x98e08000 - 0x99067ff3 com.apple.QuickTime (7.7.3 - 2978.7) <4AD43712-33CF-3112-8285-B1226FB7AE8F> /System/Library/Frameworks/QuickTime.framework/Versions/A/QuickTime
0x99068000 - 0x99069fff com.apple.SafariServices.framework (12603 - 12603.2.4) <4A49585B-E569-3F2B-9402-4E20D945E18D> /System/Library/Frameworks/SafariServices.framework/Versions/A/SafariServices
0x99081000 - 0x9939dfff com.apple.security (7.0 - 57740.60.18) <90897BBE-8836-3C9B-8928-3479FB4093F7> /System/Library/Frameworks/Security.framework/Versions/A/Security
0x9939e000 - 0x99410ffb com.apple.securityfoundation (6.0 - 55132.50.7) <3D65AA02-C211-3507-9AE4-5836D1C32A33> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
0x99411000 - 0x99439fff com.apple.securityinterface (10.0 - 55079.50.4) <E3DDB7FE-6355-32D2-A540-A3490A6233F8> /System/Library/Frameworks/SecurityInterface.framework/Versions/A/SecurityInterface
0x9943a000 - 0x9943dfff com.apple.xpc.ServiceManagement (1.0 - 1) <C2C3C89E-D269-3905-B3D3-079BD1588167> /System/Library/Frameworks/ServiceManagement.framework/Versions/A/ServiceManagement
0x9956e000 - 0x995dffff com.apple.SystemConfiguration (1.14 - 1.14) <CC03B4D7-5F8A-3259-8A03-DDE62C35946A> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
0x995e0000 - 0x99978ff7 com.apple.VideoToolbox (1.0 - 1907.59.1.5) <F174E90E-4CC6-3133-9D00-D0E59CFA13B9> /System/Library/Frameworks/VideoToolbox.framework/Versions/A/VideoToolbox
0x99979000 - 0x9ac95ff3 com.apple.WebCore (12603 - 12603.2.4) <41C4BCDA-922D-3D4C-9741-EC98A3AB0383> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebCore.framework/Versions/A/WebCore
0x9ac96000 - 0x9ae2fffb com.apple.WebKitLegacy (12603 - 12603.2.4) <5A5075CC-4E5B-32B0-B77D-A032737C9918> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebKitLegacy.framework/Versions/A/WebKitLegacy
0x9ae30000 - 0x9b145fff com.apple.WebKit (12603 - 12603.2.4) <82BA0E36-E9B6-33FF-9421-C737C16479D9> /System/Library/Frameworks/WebKit.framework/Versions/A/WebKit
0x9b8a8000 - 0x9b8c4fff com.apple.AppContainer (4.0 - 307.50.21) <B76C2BBE-D71D-3EB3-BFEF-59E83C5E1227> /System/Library/PrivateFrameworks/AppContainer.framework/Versions/A/AppContainer
0x9b8c5000 - 0x9b8d2fff com.apple.AppSandbox (4.0 - 307.50.21) <6B492B1C-2304-3D5C-A3E3-EC04D9F3C25C> /System/Library/PrivateFrameworks/AppSandbox.framework/Versions/A/AppSandbox
0x9b8d3000 - 0x9b8f7ff3 com.apple.framework.Apple80211 (12.0 - 1200.47) <35F317B3-74AF-3AA8-B3B9-C62FA7498FC2> /System/Library/PrivateFrameworks/Apple80211.framework/Versions/A/Apple80211
0x9b8f8000 - 0x9b902fff com.apple.AppleFSCompression (88.50.3 - 1.0) <1CC777F0-30FD-3432-94A2-1EB8305EAB71> /System/Library/PrivateFrameworks/AppleFSCompression.framework/Versions/A/AppleFSCompression
0x9b9cf000 - 0x9ba0cff7 com.apple.AppleJPEG (1.0 - 1) <BA15D3C3-FB23-3DF3-B025-7CD8ED30F788> /System/Library/PrivateFrameworks/AppleJPEG.framework/Versions/A/AppleJPEG
0x9ba0d000 - 0x9ba26ff7 com.apple.aps.framework (4.0 - 4.0) <3260E180-9CD9-3502-93A3-1B4962A39D9A> /System/Library/PrivateFrameworks/ApplePushService.framework/Versions/A/ApplePushService
0x9ba27000 - 0x9ba30fff com.apple.AppleSRP (5.0 - 1) <52A8DECF-E80A-3990-9C55-40517A393EDE> /System/Library/PrivateFrameworks/AppleSRP.framework/Versions/A/AppleSRP
0x9ba31000 - 0x9ba34fff com.apple.AppleSystemInfo (3.1.5 - 3.1.5) <C5301CA4-BF17-3F68-93EB-E6FB7BD1FF6D> /System/Library/PrivateFrameworks/AppleSystemInfo.framework/Versions/A/AppleSystemInfo
0x9ba35000 - 0x9ba85fff com.apple.AppleVAFramework (5.0.36 - 5.0.36) <96304B83-48E6-30B5-9762-CDA1BFF91993> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
0x9ba86000 - 0x9bb09ff7 com.apple.backup.framework (1.8.5 - 1.8.5) <4E4358E3-F5C2-33AD-964D-71197EB4ABE3> /System/Library/PrivateFrameworks/Backup.framework/Versions/A/Backup
0x9bea9000 - 0x9bed0fff com.apple.CalendarAgentLink (8.0 - 250) <A60C1B96-A145-3FA1-A47D-EF715D08111A> /System/Library/PrivateFrameworks/CalendarAgentLink.framework/Versions/A/CalendarAgentLink
0x9bfad000 - 0x9bfb6ffb com.apple.CommonAuth (4.0 - 2.0) <BB13A6A9-75A4-320F-9E8D-6099B442AE56> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth
0x9bfc9000 - 0x9c016ffb com.apple.AddressBook.ContactsFoundation (8.0 - 2250.10) <438350D7-F869-3F55-A000-45C19473513D> /System/Library/PrivateFrameworks/ContactsFoundation.framework/Versions/A/ContactsFoundation
0x9c017000 - 0x9c037fff com.apple.contacts.ContactsPersistence (1.0 - 2250.10) <75109CE9-7381-395F-A4DD-1A1B05FC9B01> /System/Library/PrivateFrameworks/ContactsPersistence.framework/Versions/A/ContactsPersistence
0x9c038000 - 0x9c350fef com.apple.CoreAUC (226.0.0 - 226.0.0) <4D4DB012-705A-3A4E-8F10-2BD5A82E93FB> /System/Library/PrivateFrameworks/CoreAUC.framework/Versions/A/CoreAUC
0x9c351000 - 0x9c382ffb com.apple.CoreAVCHD (5.9.0 - 5900.4.1) <3FBB1F5F-508D-3EC8-8F15-86F356377B2B> /System/Library/PrivateFrameworks/CoreAVCHD.framework/Versions/A/CoreAVCHD
0x9c3de000 - 0x9c3e6fff com.apple.frameworks.CoreDaemon (1.3 - 1.3) <9B6784D9-7C4D-391F-B1FD-374122C92365> /System/Library/PrivateFrameworks/CoreDaemon.framework/Versions/B/CoreDaemon
0x9c3e7000 - 0x9c3f8ff7 com.apple.CoreEmoji (1.0 - 40.3.3) <EE19390D-6C78-3771-91F8-265CE0D70D71> /System/Library/PrivateFrameworks/CoreEmoji.framework/Versions/A/CoreEmoji
0x9c3f9000 - 0x9c40fffb com.apple.CoreMediaAuthoring (2.2 - 956) <3BFE0D33-EA0E-3649-BCDE-70881073ED48> /System/Library/PrivateFrameworks/CoreMediaAuthoring.framework/Versions/A/CoreMediaAuthoring
0x9c410000 - 0x9c495ffb com.apple.CorePDF (4.0 - 4) <49EF1E20-97DC-3EAC-ABAB-112343EC7563> /System/Library/PrivateFrameworks/CorePDF.framework/Versions/A/CorePDF
0x9c4b2000 - 0x9c4e3ff7 com.apple.CoreServicesInternal (276.2 - 276.2) <A00DD1F8-0733-38F9-A031-B766A6D84789> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Versions/A/CoreServicesInternal
0x9c4e4000 - 0x9c575fff com.apple.CoreSymbolication (62046) <18B3B44B-220E-3C58-8A4E-2F2DF933FB56> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolication
0x9c576000 - 0x9c6a5fff com.apple.coreui (2.1 - 431.3) <8E73F90D-2586-39D0-8201-1B74E9877AEF> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
0x9c6a6000 - 0x9c73dffb com.apple.CoreUtils (5.1 - 510.31) <72ACB894-2108-3D56-A546-D3098EDF4B56> /System/Library/PrivateFrameworks/CoreUtils.framework/Versions/A/CoreUtils
0x9c78b000 - 0x9c7ebff3 com.apple.framework.CoreWiFi (12.0 - 1200.31) <88F8ADB0-D75E-3FC4-A230-4DD19E7A3E9C> /System/Library/PrivateFrameworks/CoreWiFi.framework/Versions/A/CoreWiFi
0x9c7ec000 - 0x9c7fafff com.apple.CrashReporterSupport (10.12 - 827) <82CF35EA-B247-389A-96B5-CFCDF011C06E> /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Versions/A/CrashReporterSupport
0x9c86b000 - 0x9c875ff7 com.apple.framework.DFRFoundation (1.0 - 104.25) <4133CA86-67B8-31A0-8389-F07123073D10> /System/Library/PrivateFrameworks/DFRFoundation.framework/Versions/A/DFRFoundation
0x9c89c000 - 0x9c90bff3 com.apple.datadetectorscore (7.0 - 539.1) <EF3EA170-5FBB-3969-AFFE-6B92A6256618> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCore
0x9c90c000 - 0x9c94cff3 com.apple.DebugSymbols (137 - 137) <0720B1A1-6FB6-32A8-9E31-660AC2CE7C2F> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols
0x9c94d000 - 0x9ca6cff3 com.apple.desktopservices (1.11.5 - 1.11.5) <395D1093-2B80-3803-B4C4-E6AFFF2419DF> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
0x9cbbe000 - 0x9cbc9ff3 com.apple.DisplayServicesFW (3.1 - 380) <A86B3EB6-BD07-303B-A06E-D9FD8001E02D> /System/Library/PrivateFrameworks/DisplayServices.framework/Versions/A/DisplayServices
0x9cc76000 - 0x9d0a7ff3 com.apple.vision.FaceCore (3.3.2 - 3.3.2) <798121FB-1A1D-3629-A0D4-D4938D4AA2AF> /System/Library/PrivateFrameworks/FaceCore.framework/Versions/A/FaceCore
0x9d424000 - 0x9d424fff libmetal_timestamp.dylib (600.0.49.9) <C6CBAAF3-4368-3B41-835A-706391EFC128> /System/Library/PrivateFrameworks/GPUCompiler.framework/libmetal_timestamp.dylib
0x9d430000 - 0x9d43affb libGPUSupportMercury.dylib (14.0.16) <143C71FF-A1C9-362A-A249-2646BD61AEEF> /System/Library/PrivateFrameworks/GPUSupport.framework/Versions/A/Libraries/libGPUSupportMercury.dylib
0x9d6bf000 - 0x9d6daffb com.apple.GenerationalStorage (2.0 - 267.1) <DC2A20B1-1C87-39B6-8FE8-1AAC131E32F3> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/GenerationalStorage
0x9dd7a000 - 0x9ddefff3 com.apple.Heimdal (4.0 - 2.0) <5DCE2A77-3E72-3E92-B6C9-09460E65A5DA> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal
0x9df8f000 - 0x9df95fff com.apple.IOAccelerator (311.13 - 311.13) <93F615C6-D2BF-338B-9239-238F337BC477> /System/Library/PrivateFrameworks/IOAccelerator.framework/Versions/A/IOAccelerator
0x9df96000 - 0x9dfbcffb com.apple.IconServices (74.4 - 74.4) <97583C5E-4B3F-3918-96EE-C1159B32D071> /System/Library/PrivateFrameworks/IconServices.framework/Versions/A/IconServices
0x9dfe0000 - 0x9dfeffff com.apple.IntlPreferences (2.0 - 216) <49702605-D0EB-3C1F-8E89-D2759A90CEBC> /System/Library/PrivateFrameworks/IntlPreferences.framework/Versions/A/IntlPreferences
0x9dffe000 - 0x9e1bcff7 com.apple.LanguageModeling (1.0 - 123.2.5) <E96DA388-C68E-35CF-8E07-C1CAF203BB6C> /System/Library/PrivateFrameworks/LanguageModeling.framework/Versions/A/LanguageModeling
0x9e433000 - 0x9e45bffb com.apple.MultitouchSupport.framework (368.16 - 368.16) <23698273-C910-369C-9F55-C965AA5EA8A7> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport
0x9e45c000 - 0x9e466fff com.apple.NetAuth (6.2 - 6.2) <7FE6A51E-B502-37EA-ABD6-297A5C66DAA7> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
0x9e586000 - 0x9e5c3ff7 com.apple.PerformanceAnalysis (1.148.3 - 148.3) <C36B2698-CF7F-37F6-AD26-6B264420E360> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAnalysis
0x9e5e7000 - 0x9e5eefff com.apple.phonenumbers (1.1.1 - 105) <61A8FF1F-69BD-3D3C-AD7F-EA95C809DEDE> /System/Library/PrivateFrameworks/PhoneNumbers.framework/Versions/A/PhoneNumbers
0x9e64d000 - 0x9e666ff3 com.apple.ProtocolBuffer (1 - 249.1) <9F888605-F294-30D5-B4E9-5E284DD5FB61> /System/Library/PrivateFrameworks/ProtocolBuffer.framework/Versions/A/ProtocolBuffer
0x9e667000 - 0x9e676fff com.apple.QuickLookThumbnailing (1.0 - 1) <4F8DBC74-422B-3DD1-948B-901214DFC8E8> /System/Library/PrivateFrameworks/QuickLookThumbnailing.framework/Versions/A/QuickLookThumbnailing
0x9e677000 - 0x9e69affb com.apple.RemoteViewServices (2.0 - 124) <ED897A3C-10F2-3A44-9984-E2F7DBD25D98> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServices
0x9e6c4000 - 0x9e6c7fff com.apple.SecCodeWrapper (4.0 - 307.50.21) <C20B97A8-DB1C-3F08-AC42-E039CB74CC7F> /System/Library/PrivateFrameworks/SecCodeWrapper.framework/Versions/A/SecCodeWrapper
0x9e6cd000 - 0x9e6faff3 com.apple.Sharing (696.2.67 - 696.2.67) <C17E5CDD-4119-319D-AAFD-3E344F7E5D4B> /System/Library/PrivateFrameworks/Sharing.framework/Versions/A/Sharing
0x9e71a000 - 0x9e795ff7 com.apple.SkyLight (1.600.0 - 170.3) <287AB854-9360-3FA4-AF75-97F8A23B594D> /System/Library/PrivateFrameworks/SkyLight.framework/Versions/A/SkyLight
0x9e796000 - 0x9e7a3ff3 com.apple.SpeechRecognitionCore (3.3.2 - 3.3.2) <01C8A0BE-FF1E-3000-AF50-2D9D44C8FAAB> /System/Library/PrivateFrameworks/SpeechRecognitionCore.framework/Versions/A/SpeechRecognitionCore
0x9ea95000 - 0x9eb02fff com.apple.Symbolication (62048.1) <A36749DD-ED57-34C5-A933-0E75B32637EC> /System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/Symbolication
0x9eb30000 - 0x9eb36fff com.apple.TCC (1.0 - 1) <7D0D74D0-EDB3-3821-A883-3007AA98C74A> /System/Library/PrivateFrameworks/TCC.framework/Versions/A/TCC
0x9eb37000 - 0x9eb4eff3 com.apple.TextureIO (2.8 - 2.8) <D8D6306E-5F72-3C43-BDE2-B8C031E1CFEE> /System/Library/PrivateFrameworks/TextureIO.framework/Versions/A/TextureIO
0x9eb4f000 - 0x9eb50fff com.apple.TrustEvaluationAgent (2.0 - 28.50.1) <A0A65AB2-99F5-39AB-A4A9-9F5FE1F3C12A> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluationAgent
0x9eb51000 - 0x9ecc3fff com.apple.UIFoundation (1.0 - 490.7) <1823A486-DE5F-3BB9-8ABE-42BC116A4301> /System/Library/PrivateFrameworks/UIFoundation.framework/Versions/A/UIFoundation
0x9efa0000 - 0x9f05afff com.apple.ViewBridge (283 - 283) <86746E52-B456-3E97-ADAC-EA35746A4119> /System/Library/PrivateFrameworks/ViewBridge.framework/Versions/A/ViewBridge
0x9f0be000 - 0x9f0c4fff com.apple.XPCService (2.0 - 1) <189D392A-2780-30E9-B5AC-E60C36B57CA2> /System/Library/PrivateFrameworks/XPCService.framework/Versions/A/XPCService
0x9f149000 - 0x9f14bfff com.apple.loginsupport (1.0 - 1) <8CE2E4E1-B94B-3D79-8AF3-9BB672CDCB8F> /System/Library/PrivateFrameworks/login.framework/Versions/A/Frameworks/loginsupport.framework/Versions/A/loginsupport
0x9f177000 - 0x9f19ffff com.apple.contacts.vCard (1.0 - 2250.10) <5288B93F-15FA-32F4-86FB-1A1D6450E9B1> /System/Library/PrivateFrameworks/vCard.framework/Versions/A/vCard
0x9f1a0000 - 0x9fae5fe3 com.apple.QuickTimeComponents.component (7.7.3 - 2978.7) <C587D2B7-FD64-3779-9129-322DBE3F2C25> /System/Library/QuickTime/QuickTimeComponents.component/Contents/MacOS/QuickTimeComponents
0x9fae6000 - 0x9fae8ff7 com.apple.QuickTimeH264.component (7.7.3 - 2978.7) <34DBBF01-71CF-3F8E-A1DC-343C22F15E93> /System/Library/QuickTime/QuickTimeH264.component/Contents/MacOS/QuickTimeH264
0x9fae9000 - 0x9fbebff3 com.apple.QuickTimeImporters.component (7.7.3 - 2978.7) <5CBE56CD-20E7-3F09-9731-DD302CC626D4> /System/Library/QuickTime/QuickTimeImporters.component/Contents/MacOS/QuickTimeImporters
0x9fbec000 - 0x9fc9bfff com.apple.QuickTimeMPEG4.component (7.7.3 - 2978.7) <2C4C3656-8201-3936-98D0-B5A984978CEE> /System/Library/QuickTime/QuickTimeMPEG4.component/Contents/MacOS/QuickTimeMPEG4
0x9fc9c000 - 0x9fcb7ffb libCRFSuite.dylib (34) <5BAC9EFA-7D2F-3D27-B9CE-A4B2D67C2D61> /usr/lib/libCRFSuite.dylib
0x9fcb8000 - 0x9fcc1ff7 libChineseTokenizer.dylib (21) <86CAA68B-DE35-3043-8A06-07BDB30DD2EE> /usr/lib/libChineseTokenizer.dylib
0x9fd60000 - 0x9fd61fff libDiagnosticMessagesClient.dylib (102) <8A7663AE-3DF2-3C59-AA9E-60C64662B502> /usr/lib/libDiagnosticMessagesClient.dylib
0x9fd62000 - 0x9ff93ffb libFosl_dynamic.dylib (16.39) <432336BE-6E32-3059-94A3-32624E25EA3B> /usr/lib/libFosl_dynamic.dylib
0x9ffa3000 - 0x9ffaafff libMatch.1.dylib (27) <387A60EE-0945-3D86-AD31-259571A20C3D> /usr/lib/libMatch.1.dylib
0x9ffab000 - 0x9ffabfff libOpenScriptingUtil.dylib (172) <04E62541-16C8-32FA-8DC5-38571B7C4E2D> /usr/lib/libOpenScriptingUtil.dylib
0x9ffac000 - 0x9ffb0ff7 libScreenReader.dylib (477.40.6) <455F97A5-624F-3B50-9267-7A19C353DD2E> /usr/lib/libScreenReader.dylib
0x9ffb1000 - 0x9ffb2fff libSystem.B.dylib (1238.60.2) <150FD3D4-7CF5-36FD-811F-A4CE6853FB18> /usr/lib/libSystem.B.dylib
0x9ffb3000 - 0x9ffdfff7 libarchive.2.dylib (41.50.2) <26FD0CF5-9AFA-356B-B893-589342EBA59B> /usr/lib/libarchive.2.dylib
0x9ffe0000 - 0xa0124ff3 libate.dylib (1.12.13) <A27B078E-9361-31FF-8471-F229596AEB30> /usr/lib/libate.dylib
0xa0128000 - 0xa0128ff3 libauto.dylib (187) <C5D7553D-3FA3-3684-BB0A-52017BF911DC> /usr/lib/libauto.dylib
0xa0129000 - 0xa0139fff libbsm.0.dylib (34) <6B938CF1-9249-3466-8A0C-477718FD2C7B> /usr/lib/libbsm.0.dylib
0xa013a000 - 0xa0147ff7 libbz2.1.0.dylib (38) <80BCF93F-B4D8-3DEC-BEAC-D713BE9DEC67> /usr/lib/libbz2.1.0.dylib
0xa0148000 - 0xa019efff libc++.1.dylib (307.5) <B37B3953-651E-3161-9E96-64F7A0219F49> /usr/lib/libc++.1.dylib
0xa019f000 - 0xa01c2ff3 libc++abi.dylib (307.3) <0E02B3E2-234D-3814-8585-31AA601BB02D> /usr/lib/libc++abi.dylib
0xa01c3000 - 0xa01d4ff7 libcmph.dylib (6) <04896475-3BC1-30FC-B34B-F091AF65E1CD> /usr/lib/libcmph.dylib
0xa01d5000 - 0xa01e8ff7 libcompression.dylib (39) <29DB1BE4-E517-3317-BF40-76C4C3754B9A> /usr/lib/libcompression.dylib
0xa01e9000 - 0xa01e9fff libcoretls.dylib (121.50.4) <03981616-D8D7-3A03-BA50-6F7F6682040D> /usr/lib/libcoretls.dylib
0xa01ea000 - 0xa01ebfff libcoretls_cfhelpers.dylib (121.50.4) <5030E367-A1BA-3EE7-A0AA-DF91C6DFEFAC> /usr/lib/libcoretls_cfhelpers.dylib
0xa01ec000 - 0xa028dfff libcrypto.0.9.7.dylib (106) <78211166-7A28-37E8-86B2-F16D4C9E336B> /usr/lib/libcrypto.0.9.7.dylib
0xa028e000 - 0xa037dfff libcrypto.0.9.8.dylib (64.50.6) <1BD055C8-5945-30B9-85E3-F5B20547EDDA> /usr/lib/libcrypto.0.9.8.dylib
0xa052f000 - 0xa0584fff libcups.2.dylib (450) <91544651-1705-3351-9013-BCE3ADA7F0BC> /usr/lib/libcups.2.dylib
0xa05f3000 - 0xa05f3fff libenergytrace.dylib (15) <0A18EAA7-EF49-312B-82A2-31A2A7C93860> /usr/lib/libenergytrace.dylib
0xa0602000 - 0xa0606fff libheimdal-asn1.dylib (498.50.8) <35D06F83-C6E1-3BAC-A0E3-AE7F2E1D41D5> /usr/lib/libheimdal-asn1.dylib
0xa0607000 - 0xa06f7ff3 libiconv.2.dylib (50) <34E6F33E-A727-3A53-8661-3F6380019B65> /usr/lib/libiconv.2.dylib
0xa06f8000 - 0xa0915ff7 libicucore.A.dylib (57165.0.1) <7B3718E8-AFE4-3621-B45E-B105CE9ACA79> /usr/lib/libicucore.A.dylib
0xa091b000 - 0xa091cfff liblangid.dylib (126) <34E46B19-A065-3BBC-BBC0-2BE5E313D444> /usr/lib/liblangid.dylib
0xa091d000 - 0xa0936ff7 liblzma.5.dylib (10) <F1C46DE7-44C7-34CD-A9CF-56B204A31965> /usr/lib/liblzma.5.dylib
0xa0937000 - 0xa094cff3 libmarisa.dylib (5) <8D7F217C-A53D-39A6-A13B-00B901EA1E22> /usr/lib/libmarisa.dylib
0xa094d000 - 0xa0bffffb libmecabra.dylib (744.8) <D21ADFC1-4A7C-3F42-B917-C087FDFA5ACB> /usr/lib/libmecabra.dylib
0xa0c30000 - 0xa0ca9fff libnetwork.dylib (856.60.1) <C9875FC0-2557-358F-B0A6-EEB62DEFA9DD> /usr/lib/libnetwork.dylib
0xa0caa000 - 0xa106ed83 libobjc.A.dylib (709) <A32B2573-CC08-3053-A005-4AFC9FC0E4CE> /usr/lib/libobjc.A.dylib
0xa1070000 - 0xa1073fff libpam.2.dylib (21.30.1) <CF96FBCD-8AD7-3022-BEF4-938DBFA38507> /usr/lib/libpam.2.dylib
0xa1074000 - 0xa10a3fff libpcap.A.dylib (67.60.1) <06086EE9-AE30-3186-A869-D9810AE10213> /usr/lib/libpcap.A.dylib
0xa10a4000 - 0xa10c0ffb libresolv.9.dylib (64) <FC3630FB-0289-3A80-AF06-7F29BD2B9E5C> /usr/lib/libresolv.9.dylib
0xa10c1000 - 0xa10f8fff libsandbox.1.dylib (592.60.1) <06568BBF-EBEA-3971-9A3D-B422FE0420C2> /usr/lib/libsandbox.1.dylib
0xa10f9000 - 0xa110aff7 libsasl2.2.dylib (209) <C2A6EDBD-6DF4-3537-B031-6052505FCDD5> /usr/lib/libsasl2.2.dylib
0xa110b000 - 0xa1254ff7 libsqlite3.dylib (254.7) <677A5EB1-5347-3184-A923-EB917B0A8B07> /usr/lib/libsqlite3.dylib
0xa12b1000 - 0xa1301fff libstdc++.6.dylib (104.1) <8D989D80-AE27-3395-ABDE-6C088F7ED35E> /usr/lib/libstdc++.6.dylib
0xa1337000 - 0xa1345ff7 libxar.1.dylib (357) <5360083D-A282-340D-9D38-78CE4353DE1E> /usr/lib/libxar.1.dylib
0xa1346000 - 0xa142aff7 libxml2.2.dylib (30.16) <8CF7B763-B251-3040-B1A0-97BFDD933327> /usr/lib/libxml2.2.dylib
0xa142b000 - 0xa1453ff3 libxslt.1.dylib (15.9) <7BC6901B-5887-351C-B98A-653DC0F0051B> /usr/lib/libxslt.1.dylib
0xa1454000 - 0xa1462ff7 libz.1.dylib (67) <6545D126-B808-3930-9225-547325D7158E> /usr/lib/libz.1.dylib
0xa1471000 - 0xa1475fff libcache.dylib (79) <9F30A683-710A-3C8D-A2FB-2257836ECCED> /usr/lib/system/libcache.dylib
0xa1476000 - 0xa1480fff libcommonCrypto.dylib (60092.50.5) <A1099282-8E61-39B1-8652-5D83CD3EAB63> /usr/lib/system/libcommonCrypto.dylib
0xa1481000 - 0xa1486ff3 libcompiler_rt.dylib (62) <5D58992A-65F7-3045-91CB-47D044702A95> /usr/lib/system/libcompiler_rt.dylib
0xa1487000 - 0xa148fff7 libcopyfile.dylib (138) <DD413176-AC1C-3CF7-82A4-8A50236F2384> /usr/lib/system/libcopyfile.dylib
0xa1490000 - 0xa14f6ffb libcorecrypto.dylib (442.50.19) <42E85768-EEE7-3350-8A38-7E16634F4483> /usr/lib/system/libcorecrypto.dylib
0xa14f7000 - 0xa1524ff3 libdispatch.dylib (703.50.37) <CDA8DD1F-BE89-3430-AC85-4403AD1E3F22> /usr/lib/system/libdispatch.dylib
0xa1525000 - 0xa152aff7 libdyld.dylib (433.5) <5D921465-7304-3682-A8C0-638D01D0DACA> /usr/lib/system/libdyld.dylib
0xa152b000 - 0xa152bfff libkeymgr.dylib (28) <6629C3DA-A8E6-3FD6-A760-63283F62086A> /usr/lib/system/libkeymgr.dylib
0xa152c000 - 0xa1538ff7 libkxld.dylib (3789.60.24) <8FF88619-B6F0-384D-9E9B-9B29513ABA5C> /usr/lib/system/libkxld.dylib
0xa1539000 - 0xa1539fff liblaunch.dylib (972.60.2) <CDDF7DAB-1BEA-3B44-8190-22B4E53E9F60> /usr/lib/system/liblaunch.dylib
0xa153a000 - 0xa1540ff7 libmacho.dylib (898) <9E1BA433-73C1-3388-B2C7-87E5216A9044> /usr/lib/system/libmacho.dylib
0xa1541000 - 0xa1543fff libquarantine.dylib (85.50.1) <3D26A8FC-1D7A-3794-A64A-7DBDD2D80633> /usr/lib/system/libquarantine.dylib
0xa1544000 - 0xa1545fff libremovefile.dylib (45) <CA000707-14D4-30CB-8F91-4C0C4B53B6D7> /usr/lib/system/libremovefile.dylib
0xa1546000 - 0xa155dff7 libsystem_asl.dylib (349.50.5) <5F395C00-0DC3-3662-A91E-3E39432EED72> /usr/lib/system/libsystem_asl.dylib
0xa155e000 - 0xa155efff libsystem_blocks.dylib (67) <D37B310D-6B17-3C2C-B45D-6A8C5F57CB9A> /usr/lib/system/libsystem_blocks.dylib
0xa155f000 - 0xa15edff3 libsystem_c.dylib (1158.50.2) <34A0572E-FDE9-389D-BABC-AA06A4B41A2D> /usr/lib/system/libsystem_c.dylib
0xa15ee000 - 0xa15f1fff libsystem_configuration.dylib (888.60.2) <F11E1D9E-A2E5-39F7-A5AC-C8707807E611> /usr/lib/system/libsystem_configuration.dylib
0xa15f2000 - 0xa15f5fff libsystem_coreservices.dylib (41.4) <E0C0D5C0-DA1F-3478-8696-0C139CA25F42> /usr/lib/system/libsystem_coreservices.dylib
0xa15f6000 - 0xa160effb libsystem_coretls.dylib (121.50.4) <D8DF4A0A-75E4-3AAB-B2A2-9303558DB3A7> /usr/lib/system/libsystem_coretls.dylib
0xa160f000 - 0xa1615ffb libsystem_dnssd.dylib (765.50.9) <A98E4FD6-23D6-393B-B2DF-D685EA397E16> /usr/lib/system/libsystem_dnssd.dylib
0xa1616000 - 0xa163dff7 libsystem_info.dylib (503.50.4) <10952DC1-D6BB-3658-9C43-54AB68B2017E> /usr/lib/system/libsystem_info.dylib
0xa163e000 - 0xa165fff3 libsystem_kernel.dylib (3789.60.24) <7BE5BB5A-28C9-34BE-AF78-57DD55A4702F> /usr/lib/system/libsystem_kernel.dylib
0xa1660000 - 0xa16acffb libsystem_m.dylib (3121.6) <87B5CD0B-FC37-32B1-BEBB-A06E08BC0803> /usr/lib/system/libsystem_m.dylib
0xa16ad000 - 0xa16c7fff libsystem_malloc.dylib (116.50.8) <6505EA02-4BD6-3A2F-80E8-387D50FBC0E8> /usr/lib/system/libsystem_malloc.dylib
0xa16c8000 - 0xa171effb libsystem_network.dylib (856.60.1) <814835EE-F034-37D2-8FCC-217A8A3C4374> /usr/lib/system/libsystem_network.dylib
0xa171f000 - 0xa1728fff libsystem_networkextension.dylib (563.60.2) <B56AE209-208C-39DE-AF58-DB1157F44BAD> /usr/lib/system/libsystem_networkextension.dylib
0xa1729000 - 0xa1731ffb libsystem_notify.dylib (165.20.1) <7F46FB6C-0826-3506-83A8-7FC3B1518CC0> /usr/lib/system/libsystem_notify.dylib
0xa1732000 - 0xa1738feb libsystem_platform.dylib (126.50.8) <E9DD2D6D-B22D-3F3D-BCED-BB020B5F2F51> /usr/lib/system/libsystem_platform.dylib
0xa1739000 - 0xa1742ffb libsystem_pthread.dylib (218.60.3) <D42E6AC9-BD70-38E6-AE1E-4E525FA9AE84> /usr/lib/system/libsystem_pthread.dylib
0xa1743000 - 0xa1746ffb libsystem_sandbox.dylib (592.60.1) <9AF24074-519C-3964-B51D-65C7BA3B0F53> /usr/lib/system/libsystem_sandbox.dylib
0xa1747000 - 0xa1749fff libsystem_secinit.dylib (24.50.4) <C109B933-EF89-3B0F-B14B-A85649439678> /usr/lib/system/libsystem_secinit.dylib
0xa174a000 - 0xa1751ff7 libsystem_symptoms.dylib (532.50.47) <C6142AA8-242B-35F3-A0FB-9AC078DA090A> /usr/lib/system/libsystem_symptoms.dylib
0xa1752000 - 0xa1764ffb libsystem_trace.dylib (518.60.2) <C785EF31-2A6D-3694-9615-19C33C0EAB97> /usr/lib/system/libsystem_trace.dylib
0xa1765000 - 0xa176bffb libunwind.dylib (35.3) <EDA423D6-B30C-3DF9-AB11-DE09F8BC4573> /usr/lib/system/libunwind.dylib
0xa176c000 - 0xa1792fff libxpc.dylib (972.60.2) <F97C3E5B-07CD-3C42-A614-CED36989E678> /usr/lib/system/libxpc.dylib
External Modification Summary:
Calls made by other processes targeting this process:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
Calls made by this process:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
Calls made by all processes on this machine:
task_for_pid: 861
thread_create: 0
thread_set_state: 0
VM Region Summary:
ReadOnly portion of Libraries: Total=284.1M resident=0K(0%) swapped_out_or_unallocated=284.1M(100%)
Writable regions: Total=210.9M written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=210.9M(100%)
VIRTUAL REGION
REGION TYPE SIZE COUNT (non-coalesced)
ATS (font support) 32.0M 7
ATS (font support) (reserved) 4K 2 reserved VM address space (unallocated)
Accelerate framework 128K 2
Activity Tracing 256K 2
CG backing stores 3456K 6
CG image 24K 3
CG raster data 600K 6
CoreUI image file 176K 4
Image IO 20K 4
Kernel Alloc Once 8K 2
MALLOC 144.3M 36
MALLOC guard page 48K 10
Memory Tag 242 12K 2
Memory Tag 249 2428K 4
OpenGL GLSL 128K 3
Stack 11.0M 8
Stack Guard 56.0M 8
VM_ALLOCATE 532K 31
__DATA 15.1M 283
__GLSLBUILTINS 2588K 2
__IMAGE 528K 2
__IMPORT 12K 4
__LINKEDIT 61.5M 22
__OBJC 4972K 115
__TEXT 222.6M 289
__UNICODE 556K 2
mapped file 129.8M 142
shared memory 16.3M 10
TOTAL 704.8M 983
TOTAL, minus reserved VM space 704.8M 983
mhschmieder
Post by mhschmieder »
If I change the file association of that ACA P7 Preferences file after it is initially created, the association with BIAS Peak Pro 7 sticks and doesn't switch back when I re-launch (and crash) BIAS Peak Pro 7.
Launching and crashing DSP-Quattro afterwards, does NOT change that file back to thinking it should open with Quattro vs. peak.
Trashing this file once again, re-launching Peak with "no" for auto-find Audio/MIDI, canceling the File Open dialog, and then going to the Audio menu to select the Audio Settings dialog, crashes Peak with the same error message as before, but this time no Preferences file is created in the "com.bias-inc.peak" folder even though it did successfully recreate the deleted folder.
At least this seems to be narrowing it down. Something seems seriously wrong with Core Audio.
Could there be something wrong with core macOS on my system that needs repairing? Perhaps I need to download a full combo updater for 10.12.5. I may have just updated via the App Store the last few times.
mhschmieder
Re: Interesting "one time only" success with BIAS Peak Pro 7
I played with the menu system, and most of the app works fine, except of course I trashed all of my 32-bit plug-ins "just in case" those were causing problems with other apps launching. Selecting 64-bit versions gives errors, or processor overload, but doesn't crash Peak.
ANYTHING in the Audio Menu crashes the app! If instead of the "Audio I/O" settings dialog, I click on the "Recording Settings", it crashes and then recreates that Preferences file, once again assigned to open with DSP-Quattro!
Separately, I found a "BIAS" folder in preferences, with "Sound Saver" XML file that was bizarrely associated with East/West QL Spaces. I changed that file association to Peak, but it didn't help.
I still have been unsuccessful in finding any preference files that seem to be related to DSP-Quattro. Maybe since it failed to launch, it doesn't have any preference files yet.
As for Peak, the key is that anything that triggers the need to look up available audio interfaces, crashes the app. MIDI is fine, and even other audio functions are OK as long as you don't try to assign the audio to anything other than the Mac's internal audio.
mhschmieder
I feel like this sort of problem easily self-repaired back in the day when we still had "Repair Permissions" as an available command in Disk Utility (yes, I know there are back door ways to still achieve that, but I looked at file permissions for potentially problematic files and didn't see any obvious outliers).
I have downloaded the Combo Update for 10.12.5 (though 2 GB seems too small for a combo update vs. the updater file that the App Store makes available?). I'm working from home today though so can't afford to interrupt or risk my remote Windows session at the moment.
UPDATE: That is the correct link after all, as it matches the one that was posted on this forum earlier and which Mike Halloran vetted. Also, it is about the same size as the 10.12.4 combo updater that I downloaded and used on my previous machine.
I allowed App Store to do the 10.12.4 update to 10.12.5 on my new machine (which shipped with 10.12.4), so running the 10.12.5 combo updater will probably help a bit, given some potential confusion from the cloning of my old computer.
Nevertheless, all of my problems with DAW's pre-date the new computer and most of them go back to later revisions of El Capitan.
I continue to be amazed at MOTU and Digital Performer, which rarely if ever have any problems, while everything else is a constant battle (including Logic Pro X). Also, DP continues to be the best app for plug-in validation and plug-ins not crashing.
BMilot
Post by BMilot »
SOLVED
You are right about the file "ACA P7 Preferences". The solution is very simple. Bias gave the solution for Mac OS 10.7 "Lion", but it can be applied for any further versions. I just did and it solved the issue right away. Just follow these instructions on the Bias Website: https://www.bias-inc.com/support/faq/cV ... faq_id=231
In the end, all you need to do is create an Aggregate Device in Audio MIDI Setup and select it in Peak. It works perfectly.
I purchased Peak Studio XT 7 in 2020 and installed it on Sierra. I had the same problem as you. Crash whenever I tried to select the audio device, deleted "ACA P7 Preferences", relaunch without selecting audio i/o, and worked until quit. Then on relaunch, crash again. Bias had given us the solution years ago, but it should have been entitled "Peak 7 Crashes when selecting audio device" or something in those lines instead of "Recording Audio in Peak 7 running in Mac OS X v. 10.7 Lion".
