What steps did you do to get rid of MOTU system files?amplidood wrote:Well whaddya know. I did the complete reinstall again for 9.13 (got rid of all MOTU system files) and all the issues I was having from 9.1-9.12 are gone. No more audio dropouts when editing audio, and the pitch editor responds normally to mouse clicks again.
I am happy.
And WHOOOOOOA there's no dropout when opening plugins with Pre-Gen on. Way to go MOTU, you got some things figured out over there!!
DP 9.13 available
Re: DP 9.13 available
waxman
- buzzsmith
I was (well, I guess I am!) gonna ask the exact same question.waxman wrote:What steps did you do to get rid of MOTU system files?amplidood wrote:Well whaddya know. I did the complete reinstall again for 9.13 (got rid of all MOTU system files) and all the issues I was having from 9.1-9.12 are gone. No more audio dropouts when editing audio, and the pitch editor responds normally to mouse clicks again.
I am happy.
Buzzy
Yamaha C7 Conservatory Grand
Hammond B-3 / Leslie 145
Focal Twin6 Be(s)
Focal Twin6 Be(s)
DP Uninstall info http://www.motu.com/techsupport/technotes/uninstalldpWhat steps did you do to get rid of MOTU system files?
- buzzsmith
Thank you.dix wrote:DP Uninstall info http://www.motu.com/techsupport/technotes/uninstalldpWhat steps did you do to get rid of MOTU system files?
I should've thought about Motu.
Buzzy
Focal Twin6 Be(s)
Focal Twin6 Be(s)
I've done so much system maintenance for so many people over the years, I have developed a little routine whenever doing full reinstalls of anything.
1. Create a folder (desktop or wherever) called "*App name* old system files"
2. Create 6 subfolders "System App Support", "System Prefs", "User App Support", "User Prefs", "System Audio", "User Audio"
3. Scour the Application Support, Preference, and Audio folders in both the System and User Library folders for anything pertaining to the app being dealt with. Move anything found to the corresponding folders in the "Old System Files" folder you created. Usually the safest way to do this is copy and paste, then delete the originals from their original locations.
4. Occasionally you have to poke around in the Frameworks and Extensions folders, but not often.
5. Restart.
6. Empty the Trash.
7. Reinstall
8. After reinstalling, you can move certain files you wish to keep back, like Color Schemes and Command Bindings. Most other files should stay newly created. Preferences and MOTU Audio System Files should never be brought back in.
9. Enjoy your fresh install!!
5. Restart.
6. Empty the Trash.
7. Reinstall
Thanks Amplidood!
waxman
Would it make sense to make copies of my prefs preemptively? The last time I had to trash them it took weeks to get things back to how they were.8. After reinstalling, you can move certain files you wish to keep back, like Color Schemes and Command Bindings. Most other files should stay newly created. Preferences and MOTU Audio System Files should never be brought back in.
YEs, that does make sense. Also, if you are using TimeMachine or other incremental backups that allow it, you can always go back in time and restore the plists from there. Just saves you a step...
For me, it's 1) make certain you have thorough Time Machine backups, 2) make certain that Indexing was on 3) know how to search a TM backup 4) use Restore to copy the files overamplidood wrote:I've done so much system maintenance for so many people over the years, I have developed a little routine whenever doing full reinstalls of anything.
Anyone notice that 9.13 now maintains fades when you cut off the end of a soundbite - by making the fade steeper? You use to have to redo the fade. I didn't see this in the release notes, but it's a very nice touch.
...on the downside I'm getting a lot of crashes on Edge-edit with 9.13, so it's back to 9.02 until I have time to see if I can diagnose the problem.
How are cutting the soundbite? If I use the scissor tool, the fade disappears as usual. With edge edit the slope stays the same.dix wrote:Anyone notice that 9.13 now maintains fades when you cut off the end of a soundbite - by making the fade steeper? You use to have to redo the fade. I didn't see this in the release notes, but it's a very nice touch.
I haven't seen this yet on either Mac. They're both on Sierra now.dix wrote:...on the downside I'm getting a lot of crashes on Edge-edit with 9.13, so it's back to 9.02 until I have time to see if I can diagnose the problem.
By using Delete or Cut. If you delete within the fade in/out, the fade gets steeper, maintaining the start point.How are cutting the soundbite? If I use the scissor tool, the fade disappears as usual. With edge edit the slope stays the same.
...and, yep. Might be time to move to Sierra. Thx.
I'm getting tons of crashes using the crossfade tool in the Soundbites window. MOTU tech support was able to verify this bug. If I copy and paste say a bar in the middle of a soundbite and then immediately click the tiny square in the top corner where the soundbites connect I get crashes often. If I either move the edge of the soundbite prior to clicking, or if I click AND drag the crossfade there isn't a crash. Needless to say I am command S'ing before every crossfade.
Mac Studio M2 Ultra 128G RAM OSX 14.3, 16" MacBook Pro M1 Max, UA Apollo x6, UA Apollo Twin, UAD-2 Satellite (x2)
I've never edited soundbites that way. Always used scissors and edge editing. Interesting that select/cut/paste gives different results. I would have thought these are all different ways of doing the same thing. I'll start doing it your way.dix wrote:By using Delete or Cut. If you delete within the fade in/out, the fade gets steeper, maintaining the start point.How are cutting the soundbite? If I use the scissor tool, the fade disappears as usual. With edge edit the slope stays the same.
DP 9.13 STRESS TEST
I just installed DP 9.13 AND 9.02 on my Mac. DP 8.13 is also on this Mac.
As I have some DP projects that require a buffer of 1024 in order to playback properly, I was concerned with DP 9.13’s performance on these projects given that I can not raise the buffer any higher than 1028. Here are the results of my tests.
COMPUTER: 2012 Mac Pro 5,1 2 x 2.4Ghz 6 Core Xeon, 12 GB Ram
OS: Sierra 10.12.4
DP SEQ FILE SIZE: 14 MB
DP SEQ RAM USEAGE: 3.80-4 GB (with about 4GB system RAM to spare)
PLUG-INS IN PROJECT: WAVES, KUSH, PSP, IZOTOPE, XFER RECORDS, KEILWERTH, SPL, EVENTIDE, MDA, SOUNDTOYS, SUGARBYTES
VIs IN PROJECT: VPS, REFX, PAPEN, SYNAPSE
TRACK COUNT: ABOUT 150 (mostly audio and auxes)
TRACK’S BUSSING/ROUTING: Most tracks are bussed to one of five auxes (set A), those five auxes are then further bussed to either one of two aux inputs (set B). Finally, those two auxes are then bussed to the input of an Audio track where the Final Mix is recorded.
BUFFER: 1024 for all DP versions (max my system will allow)
RESULTS:
DP 8.07:
DP Processing Meter: 95%
Performance: Not exactly snappy but works.
CPU Usage in Apple’s Activity Monitor: Around 26%
DP 9.02:
DP Processing Meter: 90%
Performance: Similar to 8.13, not snappy but works.
DP 9.13:
DP Processing Meter: 80%
CPU Usage in Apple’s Activity Monitor: Around 25%
Performance: Plays, but barely.
Selecting with mouse is extremely sluggish, 5 sec or more spinning beachball for anything, including something as simple as changing the cursor type.
STEPS TAKEN TO HELP DP 9.13 BETTER PLAY BACK SEQUENCE:
1) Used Load feature to import into empty DP 9 sequence.
Result: NO PERCEPTIBLE CHANGE
2) Increased prime seconds from 125 to to 500.
3) Deleted unused takes.
4) Deleted all plug-ins from Master Fader.
5) Routed ALL tracks to MASTER FADER OUT, removing all aux bussing in sequence:
Result: SLIGHT IMPROVEMENT
Still sluggish but can change curser type and scroll through input/output lists much faster. Playback is still not as smooth as DP 8.13.
6) Rerouted one CPU intensive reverb (Eventide Blackhole - or a similarly CPU demanding reverb) directly to MASTER FADER OUT:
CONCLUSIONS BASED ON THIS ONE TEST:
1) If you have a project that previously ran at your maximum buffer setting in a version of DP prior to 9.13, your sequence may be unable to play properly in DP 9.13.
Previous to DP 9.13, you could double the Host Buffer Multiplier in order to slightly increase performance. That feature is no longer available in 9.13.
2) As I have noticed in previous versions of DP, extensive bussing comes at a cost.
Bussing auxes to additional auxes, especially if there are intensive reverb plug-ins involved, appears to greatly increase the strain on DP.
3) Unexpectedly, the load on the CPU appears to be slightly less in DP 9.13 even though performance seems to indicate the opposite of that. MOTU tech support previously suggested doubling the buffer setting in DP 9.13 which seems to support the likelihood of increased CPU load. Not sure why DP’s and Apple’s metering suggests otherwise. Maybe there is something on my system that is skewing those particular readings.
4) As usual, Apple’s Activity Monitor shows much less strain than DP’s Processing Meter. I recently read that DP, Logic and Pro Tools are all close to each other in how many plug-ins can be run so one might assume they would also exhibit the same lower than expected Activity Monitor CPU readings - which leads me to:
5) I may need a more powerful computer.
OS: Sierra 10.12.4
RESULTS:
DP 8.07:
DP 9.02:
DP 9.13:
