I'm on a dual 2.4ghz hex-core tower w/64gb, El Capitan OS, standard HD5770 graphics card, secondary 4-port NVIDIA NVS 510 graphics card, all feeding a total of 4 monitors, PCI-424 w/3-2408mk3's (2 wired via 4-TDIF cables to an 02R mixer) & 1-24IO and a 3-slot expansion box with 3 UAD-2 Octo cards. Can't run below 1024 buffer-wise less I get massive dropouts and crackling.
The audio dropout issue can be reproduced simply by dropping a UAD Pultec plugin on the master buss while a mix is playing. The only thing that brings sound back is the aforementioned workaround, "Config Hardware Driver->OK". Wouldn't be that big a deal if it wasn't so slow unloading and then reloading plugins and VI's.
FWIW, I checked out my driver version and found I was not using the latest, 1.6 71459. I went ahead and updated the driver and it had no effect on the dropout issue.
9.12 and 2408mk3 Drops Out
- guitardood
Re: 9.12 and 2408mk3 Drops Out
________________________________________________________________________
Best,
Guitardood
Chuck Fletcher on Reverb Nation
Chuck Fletcher on Facebook
"Life is like a box of chocolates. You know, eventually you're going to get the one filled with alien-like nasty tasting goo and have to spit it out and say YUCK".
Best,
Guitardood
Well, that would be quite handy for diagnosis if I could reliably reproduce the glitch 100% of the time. Unfortunately, this operation doesn't cause the problem on my system. I can drop in in a UAD Pultec (or any other plugin) while playing no problem.The audio dropout issue can be reproduced simply by dropping a UAD Pultec plugin on the master buss while a mix is playing.
No UAD here.
- sonus
El Capitan /DP 9.13 / 8core 3.2KHz Mac Pro / PCIe-424/ 2408,1224,308. I keep having this problem. It happened 4 times during today's session. Very annoying!
MacPro 5.1 2x3.46 twelve core, 64Gig, OSX 10.15, Mac Studio Max 32Gig, DP11.13, RME HDSPe FX, Softube Console 1 & Fader, UAD-2 quad, Soundtoys v5, UVI Falcon 3.0, GForce Mellotron & String Machine , Waves Rennaissance...
Welcome to the club sonus. Someone else should try cody's fix of updating to Sierra. I don't anticipate having the time to install it until June.
...btw as predicted, Mike's suggestion of turning off App Nap didn't help.
