DP 9.13 available
- towerproductions
DP 9.13 available
DP 9.13 is now available . Downloading it now and Hopefully this will fix some of the crash problems.
Digital Performer 9.1.3 Read Me
Thank you for installing Digital Performer 9.1.3.
Complete DP9 documentation
You can find complete DP9 documentation (PDF files) on the DP9 installer disc, and you can also access them directly from Digital Performer's Help menu. Table of Contents entries, index entries, and cross references are live links that will jump to their destinations. In some cases, you may need to click directly on the page number (rather than the heading).
Changes and new features
For a comprehensive list of new features, please refer to New Features in DP, available in Digital Performer's Help menu.
Enhancements introduced in version 9.1.3
Version 9.1.3 provides improvements, optimizations, and refinements. Here are just a few highlights:
• Improved Hardware Insert plug-in latency detection. Added level meters and fixed a bug when pasting settings.
• Allow more than 32,000 MIDI tracks in a project.
• Improved support for Softube when tracks are reordered.
• Improved support for Melodyne.
• Improved latency compensation for VST2 plug-ins.
• Improved support for VEP and virtual instruments that have variable latency.
• Improved support for the RME Fireface driver.
• Fixed a bug where certain plugins (MX4, for example) would not get numbers appended to side-chain bus names.
• Fixed a bug where erasing a selection containing soundbites with fades would sometimes cause a click.
• Fixed a bug where editing the head of a soundbite with a fade on it’s tail would sometimes cause a click.
• Fixed an issue where chased MIDI events would not update faders and other graphical indicators.
• Fixed a bug where the main counter format was not being restored when opening a file in some cases.
• Fixed a bug where Wave files with time-stamps of > 0x7FFFFFFF would not spot correctly.
• Fixed an issue where pasting at an insertion point in a pop-edited soundbite would not place the data at the correct location.
• Fixed a bug where deleting chunks with the track selector showing could cause a crash.
• Fixed some popup menu behavior.
• Fixed a bug that could lead to a crash when edge-editing MIDI notes following the deletion of pitch bend data.
• Fixed an issue where using the scale tool on soundbite volume would not update playback such that the modification could be heard.
• Fixed a crash that could occur when closing various editor windows.
• Fixed an issue with recalling Mixing Board layouts.
• Improved mouse tracking when editing pitch bars.
• Fixed an issue where including Film Scoring Events in a movie bounce could cause frame rate irregularities.
• Fixed an issue with code signing the Windows installer.
Enhancements introduced in version 9.1.2
Version 9.1.2 provides many improvements, optimizations, and refinements. Here are just a few highlights:
• Fixed a bounce to disk crash caused by an issue involving non-active VST effects.
• Fixed a problem where audio would sound choppy after inserting a post-fader effect. • Fixed a crash that could occur if a clipping window was closed while one of its clippings was being auditioned.
• Fixed a crash involving Melodyne.
• Fixed an issue where project VIs would not work correctly when selected as MIDI metronome.
• Optimized code that could impact opening projects with a large number of tracks.
• Fixed an issue where the Ivory Synthogy would hesitate and glitch when beginning playback in pre-gen mode.
• Fixed an issue where recording MIDI data into a track with sustain CC could clear the live state of the sustain pedal.
• Fixed an issue where overdubbing notes in a MIDI track would halt sounding notes already on that track.
• Fixed a case where track sysex data could cause a crash during playback.
Last edited by towerproductions on Tue Apr 18, 2017 8:27 pm, edited 1 time in total.
DP11.1, Mac Pro 3.33 / 12-core, 96GB RAM, Mac OS 10.14.6
2 MOTU 2408 mk3s Black Lion mod, , UA Apollo Quad, UAD 2 Octo PCIe,
a bunch of EW Play,Opus, Spitfire, Sine,UVI, Kontakt Komplete Ultimate, VE Pro 7, Falcon, DSP Quattro, AmpliTube 5,and way too many others.
Re: DP{ 9.13 available
Cool! Thanks!
- terrybritton
- Primary DAW OS: Windows
Holy crap!!! That is the longest list of fixes I've EVER seen!!!! (OK, it covers all versions of 9.xx, but still...)
Super! Gotta love those Cambridge folks!!!
Thanks for announcing this, towerproductions!
Terry
Terry
MOTU 828 mk3 hybrid
MOTU 828 mk3 hybrid
- buzzsmith
I'm anxiously awaiting your reports!
Yamaha C7 Conservatory Grand
Hammond B-3 / Leslie 145
Focal Twin6 Be(s)
Focal Twin6 Be(s)
- terrybritton
"Allow more than 32,000 MIDI tracks in a project."
Damn!!! That arrived just in time for me!!
(I was just reaching close to that limit. Nice to have the headroom!)
Terry
[My "Master Template" has 73 tracks for tubas ALONE, just to give you an idea...]
[Yes - 76 trombones. I'm old school that way.)
Terry
MOTU 828 mk3 hybrid
MOTU 828 mk3 hybrid
Have a look at the Logic fix lists. Maybe 20 times longer, but I guess there's a reason for thatterrybritton wrote:Holy crap!!! That is the longest list of fixes I've EVER seen!!!! (OK, it covers all versions of 9.xx, but still...)
2018 Mini i7 32G macOS 12.6, DP 11.32, Mixbus 10, Logic 10.7, Scarlett 18i8, MB Air, macOS 14.6.1, DP 11.32, Logic 11
terrybritton wrote:"Allow more than 32,000 MIDI tracks in a project."
Terry
- supersonic
I too was beginning to feel a little cramped I was just on the line with Celemony on the crashes of Melodyne Studio in DP 9.12 and was told to use previous versions for now. I guess that solves that . Altiverb was also quite buggy. I hope it straightens out with this version.
Music is movement in silence
- FMiguelez
terrybritton wrote: [My "Master Template" has 73 tracks for tubas ALONE, just to give you an idea...]
Let me guess... You're using one track per articulation per library of the same instrument...
And I thought my template was too big...
At least now, maybe the guy who created that composition with 10,000 tracks a few years ago will go for the 32,000 tracks now!
I mean, NOW we're talking
That list also includes the fixed bugs for earlier DP9 versions. The new update's list is not as long.bayswater wrote:Have a look at the Logic fix lists. Maybe 20 times longer, but I guess there's a reason for thatterrybritton wrote:Holy crap!!! That is the longest list of fixes I've EVER seen!!!! (OK, it covers all versions of 9.xx, but still...)
- terrybritton
Doesn't everybody?FMiguelez wrote:terrybritton wrote: [My "Master Template" has 73 tracks for tubas ALONE, just to give you an idea...]
Terry
MOTU 828 mk3 hybrid
MOTU 828 mk3 hybrid
I just make a little mark near the note and the musicians know what to do. You do have to feed them, however.terrybritton wrote:Doesn't everybody?FMiguelez wrote:terrybritton wrote: [My "Master Template" has 73 tracks for tubas ALONE, just to give you an idea...]
Terry
Wasn't here a recent discussion about a new time stretch algo to be included in a new DP update ?
found it viewtopic.php?f=26&t=63193&p=540284&hil ... ch#p539867
Best
Klaus
Best
Klaus
- FMiguelez
No way! I don't.terrybritton wrote:Doesn't everybody?FMiguelez wrote:terrybritton wrote: [My "Master Template" has 73 tracks for tubas ALONE, just to give you an idea...]
If I did, my template would be as big as yours.
I prefer using one track per instrument per library. I use Keyswitches and CCs to change articulation samples/parameters.
Personally, using one track per articulation feels to me like the old ugly Gigastudio days, where doing that was the only option available. I remember I hated having to "hunt" the score to find melodic lines... Like my flutes... they used to have like 10 tracks, and it was horrible following a simple melodic line across 10 or more staves in the score!
But A LOT of people work like you do and they seem to love it too. Whatever works
Ok... who has tested it? Does it back save if I need to go back to 9.12?
waxman
- terrybritton
I swear, I've been trying to stop! (It was when I ended up with 300 tracks just forFMiguelez wrote:No way! I don't.terrybritton wrote:Doesn't everybody?FMiguelez wrote:
snare rim shots that I began to sober up a little. Don't let this happen to you!!!)
(...and I am so full of it sometimes, aren't I?)
[Believe me, I don't think ANYBODY works like I do! Perish the thought!!! One person is already more than enough!]
Terry
MOTU 828 mk3 hybrid
MOTU 828 mk3 hybrid
