It is currently Wed Oct 18, 2017 9:44 am
Text Size
Hardly any samples, yet snap crackle and pop?
Postby hamburski » Tue Apr 18, 2017 7:55 am
I don't know if this is the proper area for this question, but: Mac trashcan, 16GB memory, terabyte internal drive, samples and sessions on individual terabyte SSD drives in a Blackmagic enclosure, OS 10.9.5, DP 8.07, Kontakt 5.5.2.880. I have four instances of Spitfire Chamber Strings loaded into one instance of Kontakt, with just one microphone setting selected and "purge unused" selected (I know this is very sample-specific, but just in case) - point is, just four VI's loaded) and I'm getting a lot of gnarly digital interruption on playback. Yes, the buffer's set at 64 for doing input and it would sound ok if I went to 1024 for playback, but that's not practical for writing. It seems this shouldn't be such a problem...I have the host buffer multiplier at 1 and work priority at "high." I'll freely admit I've never really understood how those two setting work so before I start messing around with them, too, I thought I'd inquire here: is there something obvious I should be doing to make things smoother? Or, even with this system, do I have to suck this up if I want to use really detailed libraries at such a low buffer setting?
hamburski
Re: Hardly any samples, yet snap crackle and pop?
Postby Kurt Cowling » Tue Apr 18, 2017 8:02 am
Use four instances of Kontakt instead of one, each with just one spitfire strings. Spreads the load across the multiple cores.
DP 9.13, Sierra 10.12.5, 4-core MacPro, 26 GB ram, Omnisphere, Trilian, Stylus RMX, EZ Drummer 2, MachFive3.11, Real Guitar2, Real Strat, Sample Modeling trumpet, saxes, trombone and clarinets, double reeds, flutes and Fr.Horn/Tuba, Kontakt 5.6, UAD-2, Flux Pure Limiter 3, PSP Vintage Warmer, PSP MixPack, PSP StereoPack, Altiverb 7, Yamaha S-90ES, Roland XV-5080, MOTU HDX-SDI, MOTU MTP-AV, Sibelius 7, Adobe CC and Motion 5
Kurt Cowling
Postby hamburski » Tue Apr 18, 2017 8:09 am
I see - well, I've heard of this before, but it seems I'd just end up with dozens of instances of Kontakt before was through with a typical project. Is this how you do it even when you've got a lot of instruments to handle?
hamburski
Postby FMiguelez » Tue Apr 18, 2017 8:45 am
I think you need to do something to Kontakt´s memory management. Something needs to be tweaked so it doesn´t interfere with DP. There´s a recent thread about it.
I can load lots of instruments in Kontakt, spread into one or many instances, and everything is smooth as silk. I do host Kontakt in VE Pro, though.
Mac Mini Server i7 2.66 GHs/16 GB RAM / OSX 10.10.3 / DP 9.02
Vienna Instruments SUPER PACKAGE, Waves Platinum, slaved iMac and Mac Minis running VE Pro, etc.
"There's random genetic variation, and non-random survival, and non-random reproduction, which is why, as the generations go by, animals get better at doing what they do. That is quintessentially non-random". ― Richard Dawkins
FMiguelez
Postby Kurt Cowling » Tue Apr 18, 2017 10:01 am
I think they heavily scripted instruments need to be in their own instance of Kontakt.
Kurt Cowling
Return to General Macintosh
Who is online
Who is online
Login Form
