It is currently Sat Feb 24, 2018 6:32 pm
Text Size
Komplete Pitch Issue
Postby Movies » Fri Feb 03, 2017 7:04 pm
I'm using Komplete as a plug-in with DP 9.02. Absolutely nothing has changed about my set-up for months.
For some reason, in the past couple days, seemingly random Kontakt instruments will just change pitch. Like, the MIDI data is correct, but Kontakt starts transposing the pitches. It's not project-specific (I tried four or five different files). It's just one instrument at a time.
Does anyone have any thoughts on what might be doing this?
MacBook Pro 2.5 GHz Quad-Core Intel i7/16GB, OSX 10.11.5, DP 9.5, MOTU 896mk3
Movies
Re: Komplete Pitch Issue
Postby HCMarkus » Fri Feb 03, 2017 11:05 pm
Possible suspect: Pitch bend CC... Is DP set to chase pitch bend events?
Postby Movies » Sat Feb 04, 2017 5:15 am
Everything is checked in the Even Chasing window, so yes.
But, also, unless there's some key command that would've enabled it by accident, I definitely haven't gone in there for anything.
Movies
Postby Movies » Fri Mar 17, 2017 6:38 am
It turns out that this issue is not only happening in Kontakt. It's happening in pretty much any plug-in -- even MAS plug-ins.
More interestingly, when it happens, if I just save everything exactly how it is, close DP and reopen the project, it's back to normal.
Totally weird.
Movies
Postby mikehalloran » Fri Mar 17, 2017 8:31 am
What does MOTU support say?
July 2010 iMac 2.93G i7 Quad, OWC eSATA mod, 32G RAM, OS 10.13.1
828mkII FW; MOTU MTP/AV USB with Firmware 2.0.1; DP 9.5.1; IK-NI-Izotope-PSP-Garritan Antares, 32Lives, MachFive 3.2.1
LogicPro X 10.3.2, Finale 25.5, 2014.5, Encore 5.0.7, Notion 6, Overture 5, TwistedWave 1.18, DSP-Q 4.4, QuickTime Pro 7.6.6, SmartScore Pro X2 10.5.5, Toast 16
Test machine: G4-1K Dual Processor: OS 10.4.11 / OS 9.2.2; DP 5.13; Encore 5.05 & 4.5.5; Toast 9.07b, legacy apps
Postby HCMarkus » Fri Mar 17, 2017 9:11 am
Is it possible you opened a Transpose window with "preview" checked that is now hidden behind other windows?
Postby Sean Kenny » Fri Mar 17, 2017 6:08 pm
Movies wrote:It turns out that this issue is not only happening in Kontakt. It's happening in pretty much any plug-in -- even MAS plug-ins.
Totally weird.
I have experienced this too, fortunately I don't use MIDI that much these but it's a real pain
Mac Pro 3 GHz 8-Core Intel Xeon E5 - 32 GB Ram 1867 MHz DDR3 ECC - OS X 10.12.4 - DP 9.13 - RME HDSPe Madi card - iz ADA converters 24 i/o - Antelope Orion 32 i/o - Audient desk - M&K Monitors - Wunder Mic Pre's x 8 - very understanding wife!
http://www.ten21recordingstudios.co.uk/
Sean Kenny
Postby terrybritton » Sat Mar 18, 2017 8:15 am
HCMarkus wrote:Possible suspect: Pitch bend CC... Is DP set to chase pitch bend events?
I second this. I have an Alesis QX49 I don't use much anymore because it sends out spurious and random pitch bend messages. Watch your controllers with a MIDI monitor, or screen out pitch bend and see if the issue goes away.
Terry
Computer: Dell XPS 8700-1751BLK | Intel i7 4790@3.6Mhz | 16GB DDR3 1600Mhz | Windows 10 Pro x64 |
MOTU 828 mk3 hybrid-USB
DAWs & Live: MOTU Digital Performer 9.5.1 | Cantabile 3 Performer
Keyboard Synths: Kawai K5000s; Korg Wavestation
Controllers: NI Komplete Kontrol S-88/S-49 Mk2, Maschine Jam;
Akai MPK249/225; Behringer BCF2000/FCB1010; Peavey PC 1600x
Rack Modules: Ensoniq ESQm, Yamaha TX81Z, Wavestation SR, Lexicon LXP-5
Tutorials: https://youtube.com/terryleighbritton
terrybritton
Postby Movies » Sun Mar 19, 2017 1:46 pm
I chatted to MOTU about it and they had two suggestions:
1. My controller could be sending out random weird pitch data, however:
A. The controller that's hooked up (an Akai LPK25) doesn't send pitch data
B. Even if it did, I can't imagine that it would uniformly alter already-programmed MIDI information.
2. Though there's a very, very slim chance, trashing my preferences might solve the problem:
This seems pretty super unlikely -- even the MOTU tech representative was skeptical.
Movies
Postby terrybritton » Sun Mar 19, 2017 1:51 pm
Movies wrote:I chatted to MOTU about it and they had two suggestions:
Well, if the Akai LPK25 you have hooked up sends no pitch data, that pretty much sews up that suspicion!
At this point, I usually consider that it has to be ghosts -- poltergeists to be exact. Software written by common humans could not be this malicious!
Terry
terrybritton
Postby cuttime » Sun Mar 19, 2017 5:56 pm
I'm confused. How does a keyboard controller not send pitch data? Time to beak out the trusty Snoize MIDI monitor and see what's really happening:
https://www.snoize.com/MIDIMonitor/
Traveler DP9.51 Unisyn 10.6.8 and 10.13.3 i7 iMac 16G
Postby MIDI Life Crisis » Sun Mar 19, 2017 8:21 pm
A) How much is it transposing by?
B) Could there be a discrepancy between sample rates?
C) What is you sample rate in DP?
D) What is the sample rate on your audio device/card?
E) Have you tried changing the sample rates in DP and your audio device/card?
F) Does Komplete have a sample rate option?
2013 Mac Pro 32GB RAM
OSX 10.12.6; DP 9.5; Track 16 Finale 2014.5
http://www.MIDILifeCrisis.com
Postby Movies » Sat Mar 25, 2017 6:17 am
terrybritton wrote:At this point, I usually consider that it has to be ghosts -- poltergeists to be exact.
Ha! This issue is almost enough to make me a believer!
cuttime wrote:I'm confused. How does a keyboard controller not send pitch data? Time to beak out the trusty Snoize MIDI monitor and see what's really happening:
The MOTU tech was talking about pitch/mod-wheels on a MIDI controller misfiring. According to MIDI Monitor, there's absolutely nothing coming out of the ol' LPK25 during playback.
MIDI Life Crisis wrote:A) How much is it transposing by?
I haven't measured, but it seems like anywhere from a minor second to a major third.
MIDI Life Crisis wrote:B) Could there be a discrepancy between sample rates?
I don't think so. Kontakt, opened as an instance inside of a DAW, slaves to the DAW's sample rate.
MIDI Life Crisis wrote:C) What is you sample rate in DP?
44.1
MIDI Life Crisis wrote:D) What is the sample rate on your audio device/card?
MOTU 896mk3 is at 44.1
MIDI Life Crisis wrote:E) Have you tried changing the sample rates in DP and your audio device/card?
I'm not sure what you mean here. Like, just trying a different sample rate?
MIDI Life Crisis wrote:F) Does Komplete have a sample rate option?
Komplete, in stand-alone mode, has a sample rate option under the AUDIO tab which is set to 44.1, but the AUDIO tab isn't even available when it's opened as a plug-in.
Movies
Postby Movies » Sun Mar 26, 2017 4:08 am
This just happened again and maybe provided another data point:
I have one instance of Kontakt opened inside of a DP project file. Each Kontakt instrument I’m using, of course, is assigned to its own MIDI track inside of the DP sequence.
At the EXACT same moment that the bass transposed itself a major second down, a super grating, high-pitched, sustained sound (similar to microphone feedback) started in the main Kontakt instrument track. The only way I could get it to stop (apart from muting the track) was to close the file and reopen it.
This sound started out of nowhere -- I had not touched the mouse or keyboard for thirty seconds or so and the sequence was not playing.
Movies
Postby FMiguelez » Sun Mar 26, 2017 7:21 am
That sounds to me lke Banshees, NOT poltergeists. They are different :smash:
Do you have another computer where you can open the project and try it there?
If you apply the transposition MIDI plug to the tracks cursed by banshees, do they stay put with the new interval, or do the change?
Maybe some chanting or dancing around is in order at this point.
Mac Mini Server i7 2.66 GHs/16 GB RAM / OSX 10.11.5 / DP 9.51
Vienna Instruments SUPER PACKAGE, Waves Mercury, slaved iMac and Mac Minis running VE Pro, etc.
"There's random genetic variation, and non-random survival, and non-random reproduction, which is why, as the generations go by, animals get better at doing what they do. That is quintessentially non-random". ― Richard Dawkins
FMiguelez
Return to General Macintosh
Who is online
Who is online
Login Form
