Which drive to use for boot/recording?
chlorinedream
Post by chlorinedream »
Hi - testing out an 2013 iMac for DP. Trying to figure out the best HD configuration.
I have a 1TB Fusion Drive (internal on the iMac), a 1TB SSD (in an external USB 3.0 enclosure), and a 1TB 7200rpm HD (in an external USB 3.0 enclosure). Which config will give the best performance?
1) Fusion Boot / SSD Recording
2) SSD Boot / Fusion Recording
3) SSD for both
4) SSD Boot / 7200rpm Drive Recording
thanks!
__________________________________________________________________________________
iMac 27" (20,1 2020), 3.6 GHz Core i9, 64GB Ram, OS 12.6.1, MOTU 828es, 2TB SSD, DP v11.21+92248
Re: Which drive to use for boot/recording?
chlorinedream wrote:Hi - testing out an 2013 iMac for DP. Trying to figure out the best HD configuration.
1) Fusion Boot / SSD Recording (and Project Data)
3) SSD for both
thanks!
I'd go with the prize behind Curtain #1, and use the spinner for Time Machine backups. You might also want to keep a daily backup of your DP projects on the Fusion Drive.
chlorinedream
Thanks I'll try that first. Was thinking that would be the way to go.
#3 for me. Offload your projects to #1 when done.
Save the spinner for Time Machine.
2023 Mac Studio M2 8TB, 192GB RAM, OS Sonoma 14.4, USB4 8TB external, M-Audio AIR 192|14, Mackie ProFxv3 6/10/12; 2012 MBPs Catalina, Mojave
