EW Play 5.0.1 - confirmed issue with DP 9.12
SchrodingersCat
Post by SchrodingersCat »
This is more of a public service announcement; hope it helps. I'd be curious to hear if I am all alone on this one.
I installed EW Play 5.0.1 and DP 9.12 around the same time right before the Holidays.
Major problems with mouse click interpretation. DP only sees right button release (aka mouse up) sporadically. This wreaks complete havoc on all graphical editing tasks; essentially unusable.
Spoiler alert: this is not a DP issue!
On large template files with many instances of Play that were created prior to this "upgrade" to Play 5.0.1, right mouse button AND qwerty keyboard entry are both completely hosed!
So, when I delete all instances of Play from any DP project, the symptoms vanish. Works just fine with other VI's, but not EW Play 5. Confirmed this happens with projects that have only Play VI's as well as projects with Play and other VI's inserted.
I uninstalled Play 5.0.1, re-installed the most current previous release (4.3.5), and all is well. DP 9.12 working quite well!
Windows 10 (home) 64b
4X 1TB SSDs
64 GB RAM
Intel Core i7-5960X 8-Core 3.0GHz o/c to 3.7GHz
ASUS X99 Deluxe
ASUS dual ThunderboltEX PCIE card
Motu 1248 audio interface via Thunderbolt
SchrodingersCat
Re: EW Play 5.0.1 - confirmed issue with DP 9.12
Ok here is the final resolution to the issue above:
Vienna Ensemble Pro 6
EW Play 5.0.1
Digital Performer 9.12
All instances of Play run inside VEP.
Perfectly harmonious co-existence on 1 machine; all bizarre behavior with the mouse and qwerty keyboard are history. No issues with latency, and the full EW HS Diamond powerful systems patches are running glitch free.
My faith in the universe has been restored.
:koolaid:
etl17
Post by etl17 »
Glad to hear that VEP rescues the day once again!
DP 9, Win 7 64bit, 24GB RAM, RME HDSPe / Digiface, UAD 2, Powercore x8, HUI, 1 million plugins!
