Motu AVB devices for live mixing
My aging Mackie analog mixer and 828mkII are showing signs that they won't be functioning much longer.
I'm looking to replace both of them, perhaps with one of the MOTU AVB units. What are others' experience is with using AVB units for live sound reinforcement? In particular, I'm considering the Ultralite AVB or 8M in conjunction with my Behringer ADA 8000, fed via ADAT, for additional mic pres. How well would they work in standalone mode as a mixer? How stable is the browser-based interface for controlling it (likely with my iPad 2 and/or iPhone 5s?)
Thanks in advance for any input.
iMac 2.66 GHz Intel core 2 duo, 8 gb ram running 10.11.6; 17" Macbook Pro 8,3, 2.5 GHz Core I7, 16 GB ram running 10.13.6; DP 8.07; 8pre-es; 828mkII; 828mkI; microbook II, Behringer ADA8000, Black Lion Auteur 2-Ch. Pre-Amp
Re: Motu AVB devices for live mixing
I just bought a motu b16 stage... I'm not sure about it's stability yet; I've only had it a few days... Check motu tv on YouTube for testimonials.
Corrently I'm trying to create a wireless local network and I'm not sure my netgear n300 router supports it.
Snow leopard; DP 6; DP 9.1
I don't own an AVB i/o, but I've used them in live situations. The browser interface is stable, but is still evolving. It's very basic. Not a lot of features (yet?). As far as mixing goes, nothing beats a fader to grab especially when things get out of control. It's cumbersome to have to mouse your way through a mix. There's no control surfaces available for AVB i/os yet as far as I know. I did just notice that all the connected AVB i/os will follow a laptop's volume control/muting if you want them to. I haven't tried it yet, but if that works that would reduce the risk of deafening anyone if something goes whacky.How well would they work in standalone mode as a mixer? How stable is the browser-based interface for controlling it (likely with my iPad 2 and/or iPhone 5s?)
....my last real hold out of mixerless mixing is safety. Who hasn't been in situation in a home or live when a sudden blast of loud unanticipated sound explodes out of the monitors. A computer gui or WiFi connected app can easily go nonfunctional. A master fader will not.
Unless something is bent or broken, I've not met one yet that can't be rejuvenated by disconnecting the connectors and using a bit of DeOxIt on them. I've brought many back to life and restored missing channels that way. Replacement knobs are easy to get.My aging Mackie analog mixer ...
Problem is that you get it back to perfect and ya just hate to toss a perfectly good piece of gear and...
I think it's the internal effects module that has gone bad. Haven't totally dismantled it in order to fully clean it yet, but everything seems to be routed thru it-- the aux channels provide little but feedback now. Will probably attempt a thorough cleaning when I have the time, but also hoping that MOTU continues to make progress in their AVB units so they can be a viable alternative.
I have used one of the Mackie digital units (the ones that mate up with an iPad,) and thought it worked pretty well. But like the potential expandability of MOTU's units.
...one other knock against MOTU's AVB i/os is that, as far as I know, there's no way to introduce delay to compensate for speaker distance in a venue. Nothing in the hardware and no way to insert
I did a lot of live mixing with 2 896mk3 and additional 8 ch ADAT interface,dix wrote:I don't own an AVB i/o, but I've used them in live situations. The browser interface is stable, but is still evolving. It's very basic. Not a lot of features (yet?). As far as mixing goes, nothing beats a fader to grab especially when things get out of control. It's cumbersome to have to mouse your way through a mix. There's no control surfaces available for AVB i/os yet as far as I know. I did just notice that all the connected AVB i/os will follow a laptop's volume control/muting if you want them to. I haven't tried it yet, but if that works that would reduce the risk of deafening anyone if something goes whacky.How well would they work in standalone mode as a mixer? How stable is the browser-based interface for controlling it (likely with my iPad 2 and/or iPhone 5s?)
Cuemix FX never let me down, I even terminated the app and relaunched and loaded the working preset. Even unplugged the FW connector, the 896mk3 just continued to work...
Don't know the new AVB boxes, but if you can connect multiple remote control clients, there is hopefully always one working...
At least I can do this with the X32cores I now run, and a BCF2000 is still in use for i.e. 8 VCA...
I still use DP 7.24 to record from them 32 tracks live, although I had to separate the FW bus for interface stream only, and use USB2 to record onto an SSD.
The 896mk3s had clearly better ( Motu ) drivers since recording at the same time over firewire worked then...
See my sig pics
Best regards to everybody
Klaus
The inability to delay the signal to compensate for speaker distance isn't a consideration for the way I would initially use an AVB unit, but the system's expandability clearly presupposes its use in large venues (which I currently don't work in.) The most recent release of the stage box would seem to indicate that they intend to provide that capability. I hope so, anyway.
Zombie thread -- curious about folks who use the Stage-B16 or its ilk for live mixing, and how many devices you're able to connect wirelessly. I've been using my B16 in rehearsals with various ensembles adjusting their own custom monitor mixes from their phones. It seems like more than four connections, or thereabouts, I get a lot of glitches and freezing -- not sure if that's because of the number of devices connected, or just because the Motu can't handle more inputs and outputs? I'm hoping it's the wireless device connections causing the issue rather than the Motu being underpowered. Any thoughts and experiences are welcome.
Dear users of Stage-B16, question: at all - are you happy with this device? Especially about stability, live show mixing, working with mac/M1. I attempt to decide, which compact mixer to buy for our group.
